Question about Kenwood KFC-6982ie Car Mid-Range Speaker
Can i run a 4 channel 400watt amp to 4 6x9 speakers?
  • 311 Answers
Yes i dont see why not
they should work perfectly
is the question how to wire it?
if so then reply to this message
LOL
kenwood KFC
Posted on May 14, 2010
I have a total of ten speakers in my van and i want to know the best way to connect these speakers to my after market cd player they are all regular speakers not subs
I would pick the 4 closest ones and connect them..if your radio has rca connectors on it you can hardwire an amp for the 4 back ones..ulimately its up to how you want to hear the radio most of the time..
Mar 15, 2014 | Car Audio & Video
I replaced the 2 ohm 6x9's in my buick with the monsoon amp, with 4 ohm 6x9's. After i put the speakers in, almost no sound came out. I've read that you can wire them in parallel from one...
If you did wire these in parallel to get the 2 ohm load, you will loose your balance. Also, you may have to bridge your amp.
To do this, go from the positive of the amp to both positives of both speakers. Then from the negative of the amp to both negatives of both speakers. If you have a 2 channel amp, you will have to bridge it. Note, make sure your amp is 2 ohm stable.
hope this helps
Aug 27, 2011 | Car Audio & Video
I have 2 Kicker 6x9 450 wat speakers, what is the recomended type of amp.
If you plan to add more speakers to push 4 of the inside the car I would go with a good 4 channel amp at least 150watts RMS per channel. That should be plenty with put worrying about blowing the speakers.
Nov 10, 2010 | Car Audio & Video
What kind of amp do i need for 2 kicker ds6930 140 watts peak and 2 ks6930 6x9 watts peak 150 and 3 Kicker KS350 3-1/2 40 watts each peak
600 Watt to 1000 Watt 4 CHANNEL AMP for the four 6X9's and a less powerfull 4 Channel amp thats at least 200Watts to 400Watts peak for the 3 3-1/2 kicker speakers. Because if you try to connect the 3 3-1/2 speakers to only 1 4 channel amp that the 6X9 speakers are on you risk of overheating the amp and blowing the speakers too!!!
Apr 05, 2010 | Kenwood KFC-6982ie Car Mid-Range Speaker
Ity might not be the best thing to do but if you dont care about waisting anymore money then give it a try..
Mar 21, 2010 | Kenwood KFC-6982ie Car Mid-Range Speaker
I have 2 6x9 speakers up front 4 6 1/2 3-ways
Hello rjmiller4039,
Although amps with 5 channels are pretty rare, you can get one. Alpine, Boston Acoustics, Infinity, JL audio, MTX, and Polk all have 5-channels ranging in price from around $350 up to around $1,000. The Alpine PDX-5 will output 75X4 watts RMS for the front and rear stereo channels and 300 watts to the mono sub channel. It is priced at $599.99 at Crutchfield.
Hope this helps.
Sep 18, 2009 | Jl Audio 500/1 Car Audio Amplifier
Hi,just bought a 6x9 jbl gto937 speakers for my car,each speaker is 100watt rms and 300 max .Can anybody advice on what amplifier should i get for them?I know i can run them without any amp but think they...
Pyramid makes the PB series of amps. I have one that's driving a Sub.
The PB 700 puts out rms 60watts x 2 @ 2ohms, which gives you some "headroom" for your speakers. You don't want to over drive speakers with , for example, a 1000 watts for 100 watt speakers, because that's a good way to blow your speakers.
There are many brands and models of amps that will fit your speakers. Just make sure the amp will drive 2ohm speakers, since your jbl's are rated at 2ohm impedance.
You may want to consider adding a Sub woofer to your setup. A single Sub would fill in the low end very nicely. If you got a 4 channel amp, then two channels will drive your jbl's, and you can bridge the other two channels to drive the Sub. That would be a kick'n sound!
Just make sure the amp is bridgeable
For example, the Pyramid PB 1200 is a 4 channel, bridgeable amp. This particular amp will drive the 2ohm jbl's, but you would want a 4 or 8 ohm Sub connected to the bridged channels.
Jul 05, 2009 | JBL GTO937 Car Speaker
Powering 4 6x9 speakers, need amp
Hi firstof all your deck isnt really putting out 52 watts x4 more like 17-22w rmsx4 ,companies like to throw out some crazy numbers it seems. If your into Kenwood try out a KAC-8404 4-channel on the mids/highs that will put 50 w x4 rms at 4 ohms or if you wanna go a lil louder try the kenwood x600f that will throw 100w rms on each 6x9 at 4 ohms no problem. My system is very similar to yours but running 4 pioneer 5x7's in all the doors and powering it with the 8404 its loud and clean ,fan cooled and no problems at all. My subs are a pair of 15's soundstream t-4's powered by an Alphasonik pma2500a its throwing 800w rms on each sub running in stereo at 2 ohms.It can drown out the mids if i set it that way but my mids /highs cant take as much power as your kenwoods can or else id step up to the x600f too.
May 10, 2009 | Kenwood KFC-6982ie Car Mid-Range Speaker
DON'T KNOW WHAT WIRING KIT TO USE FOR 400WATT 4 CHANNEL AMP
well i will let you know now that 400 watts running into two subs like that will never match. You will want to run only one sub or get a bigger amp. But for that amp a standard 6 gauge power wire will be sufficient to run it. The ground wire about 4 gauge is good.
Feb 23, 2009 | Jensen VM9510 Car DVD Player
Help me...
If you had 4 single voice coil speakers you can create either of those 2 ohm or 4 ohm setups. If you run 2 of them in parallel you will get the 4 ohms. If you run 4 of them in parallel you will get the 2 ohms. In parallel I mean that you connect the positives together and run them to the positive on the amp and the connect the negatives together and run them to the negative on the amp. Let me know if you need more help. Good Luck.
-Andrew Hawkins
Jun 24, 2008 | Cadence TXA 6004 4 Channel High Power...
Kenwood KFC-6982ie Car Mid-Range Speaker Logo
164 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
