Question about Plumbing
The water pressure pushes the faucet spout out of the faucet assembly. I tried to screw it back in without success.
    Scholar:
  • 102 Answers
If you are talking about a kitchen faucet. I would guess that you either have WAY too much water pressure or you are missing the little c-ring clip on your spout. Most are round plastic ring with split on one side. Some are metal. They usualy fit in one of the slots on the end of your spout. Hope this helps.
Posted on May 14, 2010
There is a leak where the spray arm connects to the water faucet under the sink. The connection is a snap connection rather than a screw on type.
With this type of faucet when you push the 2 pieces together there should be a small rubber O ring, if this is not in the correct position there won't be a proper seal. If you have some vasalien rub it on the O ring and it should help it fit better, it also should click when you push it together.
Mar 16, 2013 | Moen Monticello Single-Handle Kitchen...
Faucet leaks when water is turned on at the spout base. I took the set screw out of the back but can,t remove it to access the orings or seals
better turn off the main line first, screw the ring again putting some extra pressure because usually rings are tighten so hard.you have to replace the base of the faucet.
Jun 22, 2011 | Banner Faucets Castille 700 Vintage Series...
I've actually never heard of this problem before. Sounds to me like it is a cheap faucet and replacing it with a higher quality one is the best solution.
Mar 21, 2010 | Plumbing
I have a WH15664 which all of a sudden the gooseneck spout stopped completely. My sprayer works fine. There is absolutley no water comming out of the spout. I can not understand why. can you tell me what...
Try cleaning out the aerator assembly. Not totally familiar with model but the cap end of he gooseneck should unscrew or you may have a screw in insert. If cap unscrews, carefully try to remove the screen and flow reduction insert and clean thoroughly and replace. If cap end does not unscrew look at head where water would normally come out. If notice raised ribs and notches see if you can use a straight edge to un screw the aerator. They make special wrenches but I can remove mine with a butter knife edge. If you get water with aerator removed it's definitely clogged up. I've bet this is the case as sprayer and spout are typically ported from same point in faucet assembly. I had a tennants garden tub faucet that did the same thing and the aerator on the spout was clogged with trash.
Dec 29, 2017 | Whitehaus Plumbing
I have a moen faucet that has a side handle. It has progressively got to the point that it has less and less water pressure. When I take the main hot/cold water lines loose at the shutoff valve I have...
pop the cap at the top w/ screw driver,remove screw. lift handle up and off,take note how it attache's.remove retainer nut,now firmly pull up on spout near base move left and right,to remove.back to center of faucet there is horse shoe shaped clip,w/ a little hole pull it out,take good note of how it goe's in in regard's to the cartridge. now pull up on cartridge,theycan be a ***** some time's get a good grip and nice steady pull.if your's has a spray there will be collar there as well check all this and good luck
Dec 08, 2009 | Moen 7310 Legend Single-Handle Kitchen...
Moen single lever kitchen faucet leaking at base and through spray. Can it be fixed? I lost my installation manual. Are there any online?
base leak is from bad o ring or loose spout very easy fix you can get a washer kit at lowes all you need is a allen wrench(sometimes comes in kit) a pair of channel lock pliers
May 09, 2009 | Moen 7840 Camerist Single-Handle Kitchen...
Water flow is too powerful..
I got you, you want a screen to be put on the spout!
check the inside of the spout. there may be a internal thread, if it is, then you can get a external thread screen from home depot.
Apr 22, 2009 | Danze D405046 Bellefleur Single Handle...
No water pressure at kitchet faucet
alot of times when you shut off valve under sink or in basement when you turn it back on you can get a little debri in faucet i would try cleaning the aireator the little thing on end of spout where the water comes out
Apr 14, 2009 | Moen Plumbing
Kitchen faucet
look under your sink there will be a big nut screw it up toward the counter top this will fix your problem also may want to look into getting a prv for your house this will lower your water pressur in your house
Mar 13, 2009 | Kohler Forte entertainment remote valve...
Plumbing Logo
52 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
