Question about Keurig B50 Coffee Maker
Rubber grommett that goes around needle that punctures K cup missing. Where can is purchase one?
  • Anonymous Mar 17, 2014
    the probe to puncture the k cup has fallen off
    Champion:
  • 213 Answers
Send me an email and I can have you one Today. My websites are listed below. I don't have your part listed but I can't certainly get it and process your order Today.
My shipping is USPS priority mail 2-3 day delivery so you can expect it quickly.
If you need a part just email me at help@igotsweetdeals.com
If you’re looking for Keurig Parts, you can find them on this website.
http://www.igotsweetdeals.com or http://igotsweetdeals.ecrater.com/
We have most parts for Keurig b30, b40, b50, b60, b66, b70, and b77.
If your parts not listed just send us an email and let us know what part you need. In most cases we can have the part pulled and shipped the same day!
Our parts are used and the prices are exceptionally fair. Ask about our scratch and dent parts to save more money!
If you have any questions about your Keurig or your having a problem just give us a call and we may be able to help you.
I hope this helps you. I know that needle seal is essential.
Posted on May 14, 2010
I have a K10 mini cup keurig brewer. It worked fine until this morning. When I try to brew a cup, it comes out the top. It does with this with or without a k-cup in. I tried to clean out the needles...
First: You need to check a Upper Rubber Gasket (fits around the top puncture pin). If it missing you will have leakage because here's no seal to protect leakage. You can buy it online or call Keurig Customer Service (if you still have warranty)
Second: Upper Rubber Gasket not making a seal with the K-Cup or Reusable Filter and the water and/or coffee grounds leak out. To fix it simply move Upper Rubber Gasket 1/4" down. This should close the gap between K-Cup and upper needle.
Oct 27, 2013 | Keurig Coffee Makers & Espresso Machines
Keurig leaking from bottom
Check the Upper Rubber Gasket (fits around the top puncture pin). If it missing you will have leakage because here's no seal to protect leakage. You can buy it online or call Keurig Customer Service (if you still have warranty)
OR:
Oct 07, 2013 | Coffee Makers & Espresso Machines
Grommett fell down intercooler charge-pipe on my 03 PT Cruiser. if I disconnect upper charge pipe and rev engine/spool up turbo will it blow grommett out or do I have to disconect the whole thing to locate...
If it was my car I would be tearing it down because I couldn't afford to buy a new turbo. Maybe it will come out if you spool up the turbo but if it doesn't there will be a new turbo in your future. Hope this helps.
Mar 22, 2011 | 2003 Chrysler PT Cruiser
My keurig B40 coffee maker just pure out water hardly any coffee. It makes it taste like a weak coffee even when it's should be strong. It was blocked and we try vinegar but that wasn't the problem. We...
Look at the top needle, there should be a rubber like seal that sits around its base. This seals the needle so all the water with pressure goes the the cup. If the seals not there, it can't build the water pressure necessary to go through the coffee inside the cup, thus coming out around needle and out around cup, making it mostly water in your coffe cup.
Mar 03, 2011 | Keurig Elite B40 Coffee Maker
Special Edition B60 Coffee Maker: Coffee grounds coming up through the k cup???...
make sure the k-cup is being punctured at the bottom... If the answer is YES... then take the K-cup holder out of the Keurig unit... verify you can put a paperclip into the needle of that piece from the inside of the shell and it comes out the bottom
that shell is actually 2 pieces and unsnaps... making it earier for you to check... once we know there is no obstruction in the bottom needle, then we need to make sure the rubber gasket in the top arm is ok... didnt come off..
the top needle that punches a hole in the k-cup, has a round rubber seal around it..
If it's not there, then it got stuck on the top of a k-cup, and you need to search the garbage for it...
in summary
clogged bottom needle
missing rubber top seal
If the rubber seal is there... hmm. while your making coffee next time....press down on the top arm... just enough to see if the ground stop... id that's the case, then we need to step back and think if we are dealing with either a bad seal, or a fatigued top arm..
My hunch is a bad seal... and possibly try to attempt to reseat it back into the arm... it cound be smashed in and needs to be coaxed back out..
May 06, 2010 | Keurig Special Edition B60 Coffee Maker
Coffee won't pass through pod
the K-cup is punctured at the top and at the bottom.
you can take a corkscrew, and puncture a number of holes in the bottom of the K-Cup... verify there is a hole at the top... just before you start to brew... press down on the black arm over the cup... but not too hard...Lets see what happens... if it all looks good... no problems... then we need to either adjust the arm... or shim the k-Cup up a little bit...
you may also check the rubber Seal around the top pin that punctures the K-cup...
sounds like you lost your rubber seal around the top of the K-cup...
you can re-phrase after looking and testing....
Apr 28, 2010 | Keurig B60 Coffee Maker
Gasket - coffee grounds in coffee
hi! It goes on the top and surrounds the pin that pops the hole in the kcup....the problem I'm having is how do you stick it on? Should we use crazy glue?
Apr 03, 2010 | Keurig B70 Coffee Maker
RUBBER GROMMETT THAT GOES AROUND NEEDLE THAT PUNCTURES K CUP MISSING. WHERE CAN IS PURCHASE ONE?
It cant be purchased you will have to call keurig for a replacment 1800 cup brew
Mar 21, 2010 | Keurig B50 Coffee Maker
K-Cups disappointing
I had same problem and called Keurig. They advised me that the gasket in the upper portion, where the top needle is needs to be brought down about half way, almost even with the bottom of the top needle. Be careful not to poke yourself. I brewed a cup with the resuable filter assembly and it worked great. It should stay in that position until you use an actual k-cup. When using it will push the gasket back up, as it needs pressure to puncture the hole. To go back to the resuable filter, you will need to lower the gasket again. She advised me that they are working on a fix for this issue and will notify you of any replacement parts, as long as they have your current contact info.
Feb 06, 2010 | Keurig 5048 My K-Cup Reuseable Coffee...
Keurig B50 Coffee Maker Logo
604 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
