Question about Thermos QuickSet 462836203 (LP) Grill
We just got a new propane tank and connected it and propane is not coming through
  • 494 Answers
I'll assume you had it purged of air before you had it filled, right? A full 20lb tank should weigh about 35-38 lbs. If so try this: Leave the tank valve closed for a few minutes. Then open the tank valve very slowly. It may have a built-in excess flow valve in the hose that is checking closed and preventing you from getting gas. See if that helps.
Posted on May 15, 2010
I have a Kenmore 14116329 propane grill. The propane tank is full but when I turn on the burners very little gas comes out resulting in a VERY low flame. Is it the regulator or???
It is most likely the saftey check valve in the tank. The procedure is to:
  • Close tank valve.
  • Disconnect hose connection from grill to tank.
  • Wait
  • Reconnect hose connection from grill to tank
  • "Slowly" open valve on tank to release gas back into grill
Through on some steaks
If still a problem replace tank.
The check valve that can cause your problem drastically reduces propane flow in case of an accident and the lines are ruptured
Hope this helps?
Jul 03, 2017 | Kenmore Grilling
Why wont my old grill work with new propane tank
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 13, 2014 | Weber Q Grill
Unable to get gas our of 'Blue Rhino" propane
The problem is an easy fix. Replace the current Hose/Regulator Assembly with a new one. They run about $30.00, at home centers and hardware stores that sell grills and accessories.
Once you install the new one and connect it to the gas tank, open the gas tank valve Very Very Slowly (Slow Motion, Slow) until it's fully open. If you don't do it this, the new regulator will lockup.
Hope this helps you & thanks for choosing FixYa.
Aug 25, 2011 | Weber Spirit? E-310 Propane Grill
Noise coming from tank
Yours is a DOT type tank (portable not fixed)
What is the noise? Is it gas coming from the tank to the burner? Hissssssssssss Are you properly connected? Is this a OPD equipped tank? Is there a hole or crack in the hose letting the gas out before it gets to the burner?
Do not examine it with a match!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If your tank is very old, you may not have a OPD equipped tank (is the handle three sided?) Yes = OPD No = old style. Only OPD equipped tanks can be filled in the USA. Old style tanks can leak if not properly connected.
New OPD tanks will not let gas out unless there is something properly connected to the tank. You are NOT fooling around with the 80% valve are you? If you are - STOP. (small screw on the right hand side of the connection fitting.)
If there is any fault in the equipment, connector, regularor, hose or any fitting - get it fixed! One gallon of liquid propane becomes more than 350 cubic feet of highly combustible gas. If it leaks out and gets ignited, at least it will be quick! Dont become the entertainment!
Any parts that are questionable ... replace them!
Please seek additional assistance from your professional propane supplier.
Thanks for your interest in FixYa.com
May 31, 2010 | Weber Genesis Silver B Grill
New Tank won't light Weber Grill
Try checking the regulator, this is the round metal piece connected to the gas line. If this is not level flat the valve inside will not let propane flow through.
Apr 15, 2010 | Weber Spirit? E-310 Propane Grill
Disconnect and reconnect hand tight, open slowly, if this doesn't do the trick than tank valve is bad. Another thing that could be bad is your regulator, but I would start with tank first is grill worked before new tank.
Mar 21, 2010 | Thermos QuickSet 462836203 (LP) Grill
Hooking up a pool heater to propane.
A pressure regulator and pipe or hose. Whoever is selling you the tank/propane should be able to help you size everything based on the tank hook-up and tank pressure. The heater nameplate will tell you the proper inlet gas pressure that the regulator will need to reduce the tank pressure to.
Sep 07, 2009 | Hayward H Series
The metal tube that connects the propane tank to the unit snapped ON but now won t come off
It has "Ears" on it to prevent it from coming off...to get it off requires pushing in the ears and then sliding it off simultaneously. But then the ears will not snap good into the burner any more...Its meant to stay in after its assembled and just the propane tank is supposed to unscrew and come off. However the tube should still spin to prop the tank in either side for your convenience. its safe to remove and re-install the tank as often as you like.
Its not going to "Spill" but just give a split second "FFFTTT" sound as it is removed.
I hope this helps you out with this...
8-) post comments if you have anymore questions with this. i check on them from time to time.
Jun 07, 2009 | Coleman Propane Grillin Griddle 9931-750
Check light fading in and out
you may need to have te pressure check to 14"waterculum you may have to much pressur or not enouht pressure have it check by tech
Feb 14, 2009 | Dometic RM2652 Refrigerator
Propane will not come thru burners
Most propane problems are due to a new valve on the top of the tank. It is designed to only allow a minimal flow until the line is pressured. This prevents fire flair up from broken or leaking hoses. Always turn the bottle on and wait before trying to light a burner. If the burner is on first, the propane will never come out at full flow or if you have a leak in the system, it won't pressurize sufficiently to allow full flow out of the bottle. There is never "air" in the tank.
May 28, 2008 | Coleman Roadtrip Grill LXE 9949-750
Thermos QuickSet 462836203 (LP) Grill Logo
145 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
