Question about Panasonic NN-S950BA Microwave Oven
My microwave oven control panel works,but when you
My microwave oven control panel worksbut when you turn the oven on it no longer cooks
4 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: faulty microwave oven
So it's dead? (No lights, no beeps when you press a key?)
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
But - this model uses and inverter. Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
But if you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 18, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic nn-p295 blows buss fuse when turned on for cooking
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer. But this is likely an inverter model, so it wouldn't have one and would be some other component in the inverter I'd say.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/mag_test.html
The best place to order Sharp parts is Tritronics. Or you can call them toll-free at 866-779-5835.
Posted on Dec 26, 2008
heatman101
  • 43501 Answers
SOURCE: intermittent heat in microwave
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fgssg
Posted on Sep 30, 2010
My GE model JVM1790SK Microwave randomly died yesterday. I had just finished cooking something, started it again, and while the timer started counting, the over did not start. Any idea what this cou
Had you noticed that it was getting weaker? Taking longer to heat a cup of water/coffee? If so then the magnatron was getting weak and gave up the ghost. They are expensive, probably cheaper to get another oven. the other likely failure component is the capacitor. Careful they contain power even when unplugged. Caps are not that $$. good luck
Jan 03, 2015 | GE JVM1790SK Convection/Microwave Oven
GE microwave :JVM1740DM1BB panel states locked, after unpluging it states short and will no longer work.
Notice that there are few physical barriers to protect the control panel from any cooking fumes from so the "short" could likely be due to some condensed vapors. In order to heat the control panel, tear it down and place the separate elements on the dryer rack for 20 minutes on high. Once it's done, re-assemble and re-install it into the microwave, plug the power cord back and wish for the best. It worked for me, hope it works for you...
Jun 14, 2012 | GE Microwave Ovens
Maytag microwave suddenly stopped working, overheated, nothing was cooking.
It is more than likely the magnetron is fried, to replace fuse! unplug microwave oven, remove top, "several screws" look to the right to the keypad control board, look down to a printed circuit board, clipped fuse should be near by, pop it out and replace with same current rating, assemble before testing, "lethal voltages present"
Apr 22, 2012 | Maytag MMV4205 Microwave Oven
My whirlpool gold gt4175sps lights up and the control panel works but the turntable does not spin and it does not cook. No fan or cooking noise
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 16, 2011 | Whirlpool GT4175SPS Stainless Steel 1200...
Viking microwave has digital lights but will not turn on to cook?
Hi the problem will be with the touch panel membrane or the controller. if yoiu can hear a click when the start button is pressed then the touch panel is OK asnd you should look at the controller which can be replaced as a unit or if you are up to it it's probably the main cook relay that has failed.
Jan 29, 2009 | Viking DMOC205SS Microwave Oven
GE Profile turned off as soon as it start
If you can program it and the problem occures when you push START. Then the problem is a door switch, or the control panel not having a completed circuit. Think of your control panel as an off-on switch.COOK, the control panel switches on for 100% of the time programed. DEFROST,The control panel turns the Cook-Relay on for 30% and off for 70%, on, off, on, off,for the time you programmed for DEFROST. This is how it works. There is no lowering of the output. The output is 100% anything other than COOk is done in % of time on, % of time off. This is why you can hear a "Bump" when Defrosting. The "Bump" is the Cook-Relay sending power to the High Voltage Side, 30% on, 70% off.
Jan 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GH7145XFB-1 not heating properly
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 16, 2007 | Whirlpool GH7145XF Microwave Oven
Display Screen / Control Panel BLANK
Please provide the correct model # complete. It is located With the door open, mounted to the door jamb near the control panel, or Mounted on the rear of the microwave
Aug 20, 2006 | Kenmore 80809 Microwave Oven
Panasonic NN-S950BA Microwave Oven Logo
29 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
