Question about Maxtor OneTouch II external hard drive 500GB 7,200 RPM - FireWire & USB (E04W500)
Want to open my maxtor one touch, any idea of the best way, and what is that small openning at the back
My OneTouch4 had 1 screw on the bottom next to the serial number. I removed that screw then very carefully pried the case open. Once open remove the 4 screws that hold the hold the 4 rubber pads on the drive. Also remove the very small screws that hold the metal case together then "carefully"slide the metal case off. You must remove the 2 small screws hold the small PCB to the front of the drive and move the PCB out of the way while sliding the metal case off.
Posted on Sep 09, 2008
It's a pain but you can do it if you are careful. Remove 2 screws on back panel, then gently remove back panel. Now work on side/front panel (one piece) GENTLY. They have little plastic clips that will pop out if you are careful. The you can remove 2 more screws on side that hold metal halves together. Top comes of clamshell style. Good luck !
Posted on Jul 19, 2008
SOURCE:
Can't open Maxtor one touch 4 mini
If the external hard disks is plugged to a USB port and is not detected anymore, try uninstalling the USB Root Hub devices in the device manager. They will automatically be reinstalled on reboot and that can help fix detection issues.
But did you look in the Disk Management module of Windows to see if the disk is there? Right-click My Computer and select Manage.
Jan 05, 2010 | Maxtor OneTouch II external hard drive...
Problem open up my maxtor one touch 500gb to retieve photos
first, recover your files. You will need to use hard drive deleted photo recovery program like Asoftech Photo Recovery, you can follow this video to recover deleted photo
http://www.youtube.com/watch?v=sNxApz_PBW8
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Sep 09, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Can one use a Maxtor one touch 4 mini to restore data? We need to extract documents from one computer of unknown type that has since disappeared but whose information appears on the Maxtor mini as a...
This depends upon the feature of your PC . Some PCS allow you to boot from and copy data from another USB source.
This is not the best way to do it.
I suggest you burn an image of your drive to DVD (NERO)
I am not familiar with .e01 files...
You should read the manual on you back software.
Sagacious1
Aug 07, 2009 | Gateway Computers & Internet
Just got new computer w/vista. Cant download maxtor software
Try this link. It has a software for Vista for your Maxtor drive. Download the ZIP version and install it. Hope this works for you .
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot3-emc-vista&vgnextoid=b6623428ab622110VgnVCM100000f5ee0a0aRCRD
May 14, 2009 | Maxtor OneTouch III Mini Edition (R01E100)...
How can i open Maxtor one touch 4 plus external hard drive, actually i want to take out the HD out of its casing?
If you must open it, do the following.
On the bottom of the drive there is a little round label that says warranty void if removed. Under this label is one small screw. Remove this screw, cut the lable at the seam of the case with an xactor knife or similar. You can now snap the case apart carefully using a very small screwdriver.
Lou
Aug 27, 2008 | Computers & Internet
Drive won't mount
i had a maxtor one touch go bad and had to open the case and take it out of the external casing and put it into my computer as an internal drive. then it worked fine. it was a single drive.
just today i had a maxtor TB drive go bad, and since i think it has two drives inside it i am very worried that i will not be able to do the same thing.
May 25, 2008 | Maxtor OneTouch II external hard drive...
Maxtor one touch software
John, try this link and see if it is indeed and newer version than what you currently have: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=Retrospect_Express_HD_Update_for_Maxtor_OneTouch-FR&vgnextoid=f0ce8b9c4a8ff010VgnVCM100000dd04090aRCRD
Hope this works out.
Mar 26, 2008 | Maxtor Hard Drive
Maxtor onetouch 4 mini 160gb used as back up
Yes you do. If you don't have them they are available from the manufacturer but for some reason they want you to email them with the serial number of the drive.
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot4-mini&vgnextoid=7fd5783de3444110VgnVCM100000f5ee0a0aRCRD
erch.
Mar 17, 2008 | Computers & Internet
Maxtor Can't Touch
I understand the problem you are going through and it is due to the fact that win xp sp2 install an NTFS filesytem on its hard drive and this file system was designed to be secure in a way that you don't remove disk drive or add disk drives just like that.Now the best solution would be to just reinstall you xp machine with sp2 with the hard drive already in the case.In this way xp will be able to recognize it as one of its own drives and now you will have access to it.
Mar 13, 2008 | Computers & Internet
Drive not functining on new computer
More about the old computer- what system More about the New computer- What system Please
Aug 30, 2007 | Maxtor OneTouch II Hard Drive
Computers & Internet Logo
267 people viewed this question
Top Maxtor Computers & Internet Experts
Ekse
Phil Whisenant
Phil Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
