Question about Dell Inspiron 3800 Celeron 500MHZ Processor (CPU) - 569KW
No boot at all
Dell Inspiron 3800 won't boot with or with out battery. No noise at all, lights come on for a few seconds then back off. With battery installed after the lights go back off, the charging light stays on. I had one latitude that did this and it was the RAM but I've tried 4 different sticks of PC100 that work in other Dells I have.
Hey i had the same problem but i am only 15 years old. Just becuse i'm little does not mean i dont know much about computers. i tried many things and i have found a solution that works for me. Hopefully it will work for you.i first unplugged all peripherals and accessories including the ac charger plug. Then carefully push back the battery lock switch and remove the battery. Since the battery light on the laptop flashes and stays lit i thought the battery is not fully charged or not instaledd properly. So then you remove the battery. Then you plug in the ac charger cable again and power it on. A few messages might appear and starting windows normally is what you should do. Now the sart-up screen should apear and you should be alright. You should re-install a cpoy of your windows though just to be safe. Hope this helps.
Posted on Jun 26, 2008
    Scholar:
  • 58 Answers
Could be a variety of hardware issues ... if you have a modem card remove it first ... leave the battery out as it is not required to operate the laptop as long as you have ac power ... leave all the ram chips out as most laptops have some ram built in ... remove the harddrive and any other internal drives ... also disconnect anything external ... network printers etc... after that yopu are into removing the keyboard and disconnecting the video ...but it gets a bit complicated if you have never worked on laptops before...
Posted on Mar 30, 2008
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
Dell inspiron 1300 won't boot
If you want to keep your important data, use some softwares can solve thewindows won't startproblem most quickly, and no data will lose. Besides, it is very easy, even the people who lack of computer knowledge can deal with windows won't boot issue.
Sep 21, 2012 | Dell Computers & Internet
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Mar 25, 2012 | Dell Inspiron Mini Netbooks
My inspiron 1525 won't boot, the scroll light and caps lock blink
Remove 1 stick of ram and turn on, if no! take out the second one and put back the first, and power on, if okay you know the 1 stick is bad. Remove main battery and power on, "long shot" if no change chances are it is a motherboard issue.
Mar 10, 2012 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Dell inspiron 3800 has power issues. I tried 2 separate ac adapters, took out battery and tried. the light comes on on the ac adapter and as soon as you plug into the back of the laptop, the ac adapter...
you have a shortcut circuit in your laptop. most probably power diodes that is in entering conector of adapter in your laptop have gone or some of rezistances located there. you have to service laptop.
Apr 06, 2009 | Dell Inspiron 3800 Celeron 500MHZ...
Dell inspiron will not boot
Most likely you will need to replace the motherboard. Roughly $100 on Ebay.
Mar 20, 2009 | Dell Inspiron 6000 Notebook
MY DELL LATTITUDE C600 TURNS OFF AUTIMATICALLY
hi there, you can try this unplug the powercord from the pc and remove the battery and than press the power key than replace the battery adn plug in the power cord and let it charge for a hour or so and than try it again. if it boots good if not try to press the del key right after you turn on the unit and check the settings of bios to see what they are set at and try to set it to default or failsafe than save on exit and reboot and see what that does
Dec 18, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dell Inspiron 5150 won't boot
Take out the battery. that hapened on my inspiron 3800
Nov 11, 2008 | Computers & Internet
Laptop wont start
Some problems would be,
1. some hardware loose connection
Feb 13, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dell Inspiron B130 wont boot
First remove the battery from the PC! Leave it off for a short period of time! about 2min. This allows the computer to erase anything in temporary memory. Place the battery back onto th PC and try to boot it up. The other thing you can do is boot the pc up with just the power cord in place. See if it boots just from the power cord. Sometime the batteries from dell causes the whole entire PC to become unresponsive.
Nov 26, 2007 | Dell Inspiron B130 Notebook
Computers & Internet Logo
205 people viewed this question
Alun Cox
