Question about Acer Aspire M1641-U1521A PC Desktop
System appears to come up, but the monitor is like
System appears to come up but the monitor is like it is not receiving a signal from the computer. Monitor works tried on another system. Have tried two different monitors on computer same thing. Also I am not hearing nothing from the computer when I turn on but see all the lights. The computer is Acer Aspire M1641.
  • 38 Answers
Check the connector on the computer first, If that seems steady and solid, you need a repair shop --- it is almost impossible to troubleshoot a computer w/o a monitor. You can't even install a new video card if you can't see to install the software. It could be anything from a loose connection to a fried motherboard. The shop is equipped to deal with that problem. I wish there was a better answer.
Posted on May 15, 2010
Out of range problem on a dell crt monitor
You computer monitor is not receiving a signal from your computer system. Be sure to check that all connections are indeed making good contact.
Go through my published guide in this regard, it is entitled
My Computer is not turning on!!! Is it dead!!! No POST!!!
damnor01
Apr 04, 2011 | Dell P780 17" CRT Monitor
V193W 19" acer monitor is connected to computer
Hi, Try turning off your system, activate your monitor and then activate your computer. Check the troubleshooting section of the manual received with the monitor and if that still does not help, let me know.
Regards, Icom1
Apr 01, 2011 | Acer V193w LCD Monitor
System appears to come up, but the monitor is like it is not receiving a signal from the computer. Monitor works, tried on another system. have tried two different monitors on computer, same thing. also I...
see if one of the little wires inside the wire end from the monitor that goes into the tower is bent or messed up. If one of those are missing, the whole monitor is messed up. Also look on the back of the tower for the |O| picture. It should be blue.
Mar 20, 2010 | Acer Aspire M1641-U1521A PC Desktop
It doesn't send a signal to the monitor
Initially check the monitor whether it is working good you can check it by removing the monitor cable from the system when you remove cable you will able to see question mark in case of crt monitor this ensures your monitor is working good.
when you power the system whether processor works if the processor works means you can conclude that the problem is with the ram or the video parts of mother board.
Clear the dust in the ram slot and reinsert the ram
Then remove the cmos battery of the system and reset the bios settings.
Check whether the power cables are correct.
then power on the system if you receive display the problem is solved.
If the display does not appear check by replacing the new ram then giving motherboard to service centre
Mar 10, 2010 | Mercury P4VM800M7 Motherboard
CHEK YOUR pc OR SIGNAL CABALE
You should Check monitor on different system, after that, although if your monitor is ok then you should check your display your System (CPU) restart the syatem and check display in Key-board by pressing Num Lock Key whether on or off, if key is not working so problem in your system not in Monitor, check then reply
I hope that this has been very helpful for you
Dec 01, 2009 | AOpen A75P Monitor
I turn on my computer but my monitor says there is no signal
hello, try to unplug the cables on your desktop, then plug it again, sometimes its loose, or sometimes the power supply on your computer is not functioning properly.
Nov 02, 2009 | Computers & Internet
Computer randomly fails to boot
how many video cards do you have installed?
Nov 14, 2008 | E-Machines eMachines Desktop PC
Monitor display prob
Here are some basic trouble shooting tips for new monitors: The picture does not appear
Check to make sure the signal cable is firmly connected in the socket.
Check to see if the computer system's power is ON.
Check that the Brightness Control is at the appropriate position, not at the minimum.
The Screen is not synchronized
Check that the output level matches the input level of your computer.
Make sure the signal timing of the computer system is within the specification of the monitor.
The position of the screen is not in the center
Adjust the H-Size, H-Phase or V-Size, V-Center controls.
Check if the signal timing of the computer system is within the specification of the monitor.
The screen is too bright or too dark
Check if the Brightness or contrast control is at the appropriate position, not at the maximum or minimum.
Check if the specified voltage is applied
Especially, check the horizontal frequency.
The screen is shaking
Move all objects that emit a magnetic field, such as a motor or transformer, away from the monitor.
Check if the specified voltage is applied.
Oct 19, 2008 | Computers & Internet
No beep
What indication do you have that the system is on?
Do you have any LEDs active on the front of the system box?
Also, your monitor should indicate whether you are receiving video sync signals from the system by changing LEDs or the color of one and possibly give you an on-screen notice that it is or isn't getting input.
If you disconnect the video cable from the back of the system box, most monitors will post a small notice on the screen that it is working but not getting any input.
May 06, 2008 | Compaq Presario 5000 PC Desktop
Acer Aspire M1641-U1521A  PC Desktop Logo
200 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
