Question about Saws
DEWALT DW933 JIGSAW BLADE HOLDER PROBLEM
On my dewalt dw933 jigsaw after fitting and tightening new blade the blade is not locked in the straight ahead position. It can be twisted clockwise and anti clockwise. i removed the blade and screwed the blade holder/clamp a little further on the shaft and this seems to have cured the problem. How far should the blade holder be screwed onto the shaft? when tightening the knob to lock blade advice is tighten untill ratchet is heard. On my saw i have never heard ratchet when tightening blade. Why is this? as i have no user/instruction manual is it possible to obtain one?
  • 3 Answers
SOURCE: blade wont stay in Bosch 1882VS jig saw
From your description I cannot say for certain, but it sounds as though you are not locking the blade correctly, or the blade lock mechanism is broken. You can tell if the blade-lock is working by clicking it. It should make an audible "click" that you can feel. Also, you can pull on the blade ( with the saw UN-plugged of course!) and feel if it is properly seated. If you are operating the blade-lock according to the instructions and it still doesn't lock positively, see a service center before you use the tool again. A broken blade-lock could be dangerous.
Posted on Apr 10, 2009
  • 583 Answers
SOURCE: can u tell me where i can purchase a shoe
try toolking youdoit
Posted on Jul 26, 2009
  • 2976 Answers
SOURCE: i can't find the lock nut tool
You should be able to use a wrench, unless you have the style that needs a spanner (ring with 2 holes in it). Then, you will need the wrench to fit it. I made one with a piece of 1/8" flatbar and 2 #10 bolts. It isn't pretty but it works.
Posted on Aug 01, 2009
  • 700 Answers
SOURCE: HOW DO I REMOVE THE BLADE FROM A HEAVY DUTY
Commonly tightening/closing of tools is clockwise and opening is counter clockwise on its point of access. I think this reference comes from how we write or our reference on reading, right/left handed standard.
Other countries have different standard.
Posted on Oct 27, 2009
SOURCE: Dewalt DW304 stopped working while sawing 1 1/2
the breaker box started ticking then the red light went out. Is there a fuse in the box?
Posted on Jan 02, 2010
Ks656pe how do i change the blade? i don't have any instruction. Please
Quick-Change Blade Mechanism
Higher-end models, such as the Linefinder Orbital Jigsaw, feature a clamping lever to hold the saw blade. To change a blade, switch off the jigsaw, unplug it, and let the used blade cool down. Pull up the saw-blade locking lever and let the used blade fall out with a slight shake. Turn the jigsaw upside down. Hold the fresh blade with its teeth forward; insert the blade shank into the blade holder as deeply as it will go. Release the lever and wiggle the blade to confirm that it's snugly in place. For models with rollers, such as the Accu-Trak, nestle the blade against the rollers.
Clamp or Hex Screws
Loosen the pair of screws -- on the front of the mechanism of models such as the single-speed jigsaw -- a full turn counterclockwise with a flathead screwdriver, but do not remove them. The used blade will fall out. Insert the new blade fully into the clamp. Lightly tighten each screw alternately and then fully. On older models, you may find a single hex screw on the side of the blade. Loosen this enough to remove the blade, and then insert a new blade carefully so the teeth face forward. Retighten the screw.
Oct 03, 2017 | Saws
I can not find my instructions for the Dewalt321 jigsaw so i therefore cannot replace a blade that fell out
Most Dewalt manuals are available here: https://servicenet.dewalt.com/Home . There are 40 Dewalt power tools with 321 in the model number. Several are jigsaws. There are two types for the DW321 (TO3PAK-2LE JIG SAW) jigsaw. Please look at the label on the jigsaw to ensure that you get the correct model and type. The direct link to the manual for the DW321 Type 1 is currently https://servicenet.dewalt.com/Products/GetDocument?docName=402086-01,DW321.pdf&productId=2841&productType=3001&documentId=24909&translatedFileName=http://documents.dewalt.com/documents/English/Instruction%20Manual/402086-01,DW321.pdf .
To change the regular blade on the DW321 type 1, unplug the power tool. To remove the blade, pull the knob on the top of the jigsaw up about 1/4". Rotate the knob counterclockwise until the clamp opens. Do not force the knob after it stops. Insert the blade making sure that the back edge of the blade fits into the support roller. Rotate the knob clockwise until it clicks and then push it down.
I hope this helps.
May 24, 2017 | Blade Saws
I would like to know what blade fits a dw313 dewalt jigsaw
any multi fit blade
it is only the shank width that may be a problem as some are too wide to fit in the slot
Feb 13, 2017 | Dewalt Saws
How to change a dewalt DW317 jigsaw Reciprocating Shaft
You will need to remove the blade holder then the 4 screws that hold the front cover on. You can go to DeWalt's service site using the link below and view or print a parts diagram which will help.
DEWALT ServiceNet
May 24, 2014 | Dewalt DW303 Heavy Duty 65 Amp...
How do you fit a blade into a dw933 jigsaw
hi, sorry if the text is a bit small :P Full instructions available here: http://service.dewalt.co.uk/PDMSDocuments/EU/Docs//docpdf/dw933_eur.pdf
Fitting and removing a saw blade (fig. A, B & I)
The DEWALT tool-free system ensures quick and easy changing of saw blades.
• Pull the rotating handle (10) up completely. • Unlock the handle by rotating it as shown. • Insert the saw blade into the blade holder (8)
guiding the back of the blade into the groove of
the guide roller (6). • Turn the rotating handle (10) towards locked
position until a click is heard. • Press the rotating handle halfway down
(freewheeling position) and continue rotating the
handle towards locked position. • Press the handle (10) down completely. • To remove the saw blade proceed in reverse order.
Jan 14, 2011 | Saws
Jigsaw dc330 blades keep poping out when used
Hi Paul,
When inserting the blade, turn the saw upside down to prevent the blade from moving while tightening.
Before inserting a new blade, check the receiver for obstruction or debris that may prevent the blade from properly registering with the tightening screw.
Make sure the blade is fully seated in the receiver before tightening.
The tightening screws that secure blades on any type of reciprocating saws (Jig, Scroll, Sawzall, etc.) are constantly under stress and do wear out. If the problem continues, it may need to be replaced.
Best regards
Mike
Oct 29, 2009 | Dewalt Saws
Saws Logo
184 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
