Question about Roper REX4634KQ Electric Dryer
Wont heat up replaced the sencors and heating coil still not working = what do I check next
    President:
  • 1,197 Answers
Unplug the dryer and the first thing to do is check for the presence of 220 volts at the wall outlet. If you lost one leg of the 220 volts, it is possible for your dryer to run but there will not be any heat. Once you verified there is definitely 220 volts at the wall outlet, remove the rear cover. On the lower right hand side you will see a silver canister which contains the heating element. Remove the lower two wires directly from the heating element and check this for continuity. If it is good, on the left hand side of the same canister they often install a thermal safety which may have tripped. Do the same test as with the heating element. Remove the wires and test the thermal safety for continuity. If this is good, move to the blower housing on the left side of the exhaust vent and look for a white piece of plastic which has two wires on it. Remove these two wires and check this item for continuity.
you can follow this link below to find out how to test for individual components to find out what part is faulty...
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
You can also order for any replacement part from the following Websites
www.PartSelect.com
www.SearspartsDirect.com
If you found my solution of any help ... please do not forget to rate the solution
Posted on Oct 09, 2010
My 02 gtp wont start no power to fuel pump but power to coil pac but only dull spark
if you had a broken wire this would cause arking which generats heat so could be short else ware
coil pack will be on same circuit as fuel pump so needs checking
Aug 18, 2012 | Cars & Trucks
Mondeo tdci turns over but wont start
my ford mondeo zetct turns over but wont fire sparks are fine petrol fine leads are fine new battery new coil what next ecu checked cam sencor checked
Apr 04, 2012 | 2003 Ford Mondeo
Wont heat
do you hear 3 clicks when you start it up,these clicks are the gas valves opening to supply the unit with gas for operation,if no clicks are heard it can be the thermal fuse is open,if only 1 or 2 clicks check continuity of the main and secondary gas valve coils as they can open up or get weak from heat during operation,usually just replace both coils on the gas valve as they are inexpensive one has 3 connections and the other has only 2 connections,but first bypass the thermal fuse with a jumper wire (for testing only) then replace the gas valve coils next,unplug both coil connections then remove 2 screws holding the valves to the valve and replace and reverse dis-assembly procedure
Feb 07, 2012 | Kenmore Dryers
Hotpoint dryer not heating, dryer tumbles but no heat.
check the switch is working then go to the heating coils and check there working ok the next thing to go to is the heat censor inside above the door if this is not working you wont get any heats at all,
Jul 01, 2010 | Hotpoint Dryers
Wont start up, just replaced the heating coil and it worked fine for a few days, now dryer wont start
check your wires and fuses next to the heating element. first one i would check is the white plastic one. that is a non resetable fuse.
Dec 11, 2009 | Whirlpool LEB6300 Electric Dryer
TUMBLE DRYER NOT HEATING UP
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil. You should read continuity across the terminals, if not you will need to replace the coil as it is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape. If the coil heats up then replace the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine. I will include these two websites for parts and further help:
Dec 04, 2009 | Dryers
WONT HEAT, DRYER WILL TURN BUT WONT HEAT UP.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Oct 13, 2009 | Maytag PYE2300AY Electric Dryer
Dryer wont heat up already replaced thermal fuse
You gas coils are probably old and weak. check this out
Gas dryer works and quits
Apr 11, 2009 | Whirlpool Dryers
Oven does not heat
i have had a similar problem before and was fixed by replacing a fuse check to see if you have 2 fuses if not then the next step is to measure the resistance across coil it wont be 0ohms cos if it is your back to a blown fuse instead you should have a resistance across it i suspect you will see a open circuit meaning u need to buy a new coil for your top oven
hope this helps
Nov 07, 2008 | Whirlpool Ovens
Roper REX4634KQ Electric Dryer Logo
51 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
