Question about Dryers
I've changed the drive belt, but it seems that the...
I've changed the drive belt but it seems that the drum is now out of alignment because it makes a terrible noise and sometimes jams. The drum sounds better when pushed forwards towards the door. i think something else maybe broken too.
    Novelist:
  • 145 Answers
If the drum being pushed forward makes the problem better, I would say your felt pads under the drum which the drum rides on are either worn down the metal or loose.You need to remove the front casing of your dryer and inspect these felt pads. If they are loose tighten them up and if they are worn they need to be replaced. When you have your dryer apart you may also want to try to move the rear of the drum to the left and to the right and see if the back of the drum is loose as this means your bearings are loose and may need replacement. To fix this problem however the top of your dryer will have to be removed to take the drum out (many times the top will tilt back on hinges) because the bearings are on the back of the drum.
Posted on May 14, 2010
Drum seems to be hard to turn and sqeals ?
Probably the motor and belt alignment, or a loose belt. Remove the access panel to expose the drum and the motor. Check to make sure the belt is not worn, frayed, or showing cracks. You should be able to purchase replacement parts online from the OEM website by referencing the appliance model number.
Oct 20, 2014 | Dryers
The motion drive belt on my husqvarna yth2348 keeps coming off rear pulley above the transmission.
it sounds like an alignment issue check guide pulleys and make sure their not damaged or bent also check for broken parts
Sep 03, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Changing dryer belt for lse7804ade washer dryer stacker
If the washing machine / tumble dryer / spin dryer seems to be making the right sort of noises, but the drum is not turning, unplug it, take the rear cover off and check to see if the drive belt is still intact and on the pulleys.
Mar 09, 2010 | Washing Machines
We have a Frigidaire FER211AS2 dryer that started making a loud humming/roaring noise. Hubs replaced the bearing and drum belt. The noise isn't quite as bad but it still makes the same noise. What could it...
Check the alignment of the belt. Humming/roaring noise usually comes from a bearing, so your husband got it right to change the bearing and belt.
Now, he just needs to make sure that the belt is aligned right and the bearing is properly seated. Also check for rubbing marks around the travel area of the drum.
Oct 09, 2009 | Dryers
HOTPOINT WASHING MACHINE - BELT IS RUBBING AGAINST BACK OF DRUM & WEARING BELT + INTO PLASTIC DRUM CASING. I HAVE TRIED MOVING THE BELT TO THE FRONT EDGE OF THE MOTOR PULLEY DRIVE, BUT AFTER A FEW...
if you have gotten that far your good
now try to look at the motor it sounds like your belt might be a lil off track on the mortor shaft
there is a adjustment srew on the top left of the motro its hidden under things but its there
you can looses this and swing the motor
make sure you have it lined up on the motor shaft and it should stay aligned on the pully
Oct 08, 2009 | Hotpoint Aquarius WD63 Front Load...
I'm having a problem re-fitting the drive belt to my Simpson Sirocco 455 tumble dryer. After installing the belt around the drum, drive pulley and tension wheel, I align the front end of the drum with the...
After some mild swearing, I made sure that I had the belt around the drum aligned (in the same plane) as closely as I could with the drive pulley and tensioning wheel. I think this was partially achieved by placing the belt as close to that position as possible before lining up the front end of the drum with the cabinet opening, and then turning the drum from the front (through the open door) very slowly clockwise (the direction of its normal rotation) to give the belt "time" to align itself fully with the smaller pulleys. A short prayer and a few minutes later, the machine was humming away with all parts playing their "part" in beautiful harmony - without the dreaded sound of a thin black drive belt cluncking to the floor of the metal cabinet.
Cheers,
Andy B.
May 02, 2009 | Dryers
Asko T720 clothes dryer - thumping noise like the drum is damaged and shakes when going.
hi
The drum of the dryer is usually turned by a motor-and-belt assembly. There are two very clear signs that the belt is malfunctioning: You can easily spin the drum by hand when the dryer is off, or you hear a heavy thumping sound coming from the drum when the dryer is running. Here's how to test and replace the drum belt:
Step 1: Locate the belt by removing the back or front service panel. Depending on the type of dryer you own, you may have to prop up the drum to keep it from sagging. Don't let the drum hang; the bolts that hold it in the cabinet could be damaged. Don't remove any more parts than necessary.
Step 2: Identify the belt. The old belt may be threaded around the idler pulley and motor drive shaft. Draw a diagram showing how the pulley is installed so you'll be able to replace it properly. If the old belt is worn or frayed, but not broken, leave it around the drum as a pattern for positioning the new belt; cut the old belt and remove it when the new belt is in position.
Step 3: Remove the old belt from the pulleys and stretch the replacement belt into place. The new belt must extend around the dryer drum and the pulleys. The trick is to align the belt on the drum with the pulleys -- the ribs on the new belt go against the drum.
Step 4: Once the belt is aligned, turn the drum by hand, if possible, to make sure the belt is tracking. You may have to reassemble part of the cabinet to do this.
Sep 13, 2008 | Asko Dryers
My hotpoint vtd20 dryer is vibrating when running. When stopped, with my hand i can barely turn the drum (not sure if it turned easily before) any advice?
hi Step 1: Locate the belt by removing the back or front service panel. Depending on the type of dryer you own, you may have to prop up the drum to keep it from sagging. Don't let the drum hang; the bolts that hold it in the cabinet could be damaged. Don't remove any more parts than necessary.
Some older dryers have a V-belt pulley drum drive. With this system, two or three pulleys of different sizes set the speed of the drum. To change this type of belt, decrease the tension on the idler pulley and install the new belt in the V-grooves of all pulleys. Then place the idler pulley back into position.
With any dryer, make absolutely sure that you replace the old belt with a new one made especially for the dryer. Any difference in belts can change the speed of the drum and cause problems with other dryer components.
thank u................
Sep 12, 2008 | Dryers
Dryer problems
see if belt is off or broken otherwise it would be the motor.
Feb 20, 2008 | Dryers
Drive belt out of alignment
check pulley is fully bolted home. also fault could be due to the bearing spider (on the drum) being broken or cracked on one leg. if this was so, would expect spin with clothes to be very noisy. get gack to me if you want. the belt is a stretchy belt ie no adjustment for tightness
May 13, 2007 | Zanussi F1245W Front Load Washer
Dryers Logo
301 people viewed this question
Top Dryers Experts
