Question about Heavy Machinery
I can't get my mtd yard machine 24A-465E729 to start. It sputters but doesn't start. It doesn't seem to have the choke valve..? its a tecumseh engine.
  • 91 Answers
SOURCE: 5hp b&s mtd chipper wont start
defiantly the carb but its not bad - clean / soak it with some seafoam and blow out all the holes. its just clogged and isnt getting the fuel/air mixture right.
Posted on Mar 30, 2009
  • 153 Answers
SOURCE: Oil? Gas? Additives?
Small engines like to see SAE30 oil. This is assuming a 4 stroke engine of course (if you have an oil filler spout and dip stick you have a 4 stroke engine). Use regular unleaded gas, and personally I mix STA-BIL into ALL of that gas I use with my small engines. I have too many carburetors to take the chance of needing to rebuild them in the spring.
Manuals for MTD products are here: http://manuals.mtdproducts.com/mtd/public/list.jsp
You will need model and serial numbers
Posted on Apr 30, 2009
  • 391 Answers
SOURCE: MTD 12.5 HP Ride On Mower won't stay running
It could be a needle valve sticking or a mal-adjusted float but more common is a fuel filter that is restricted, once you use up the fuel in the line and float bowl it runs out and dies. A less common but easily tested issue is when the mower has run for the amount of time it begins to sputter and die, loosen the cap on the fuel tank just a bit, if it helps or resolves the issue the vent in the cap may be clogged.
Posted on May 26, 2009
SOURCE: MTD chipper shreader
Sounds like the carb is gummed up. Do a complete carb cleaning and see if it helps.
Posted on Aug 08, 2009
  • 125 Answers
SOURCE: yard machine mtd 123cc mower stalls after starting
dirty gas. the fuel bowl likely has junk in it which plugs the jets as soon as it starts. you may get luck just emptying the carb bowl but a good carb clean and new gas will do the trick. (dump out the old gas
Posted on Aug 16, 2009
24a-02d401 yard vacuum by MTD with briggs & stratton engine, fuel tank cracks
Get a tube of Kent's All In One. At the auto parts store. You can beat it. Check all engine and tank mounts.
Oct 28, 2013 | Mtd Garden
Belt diagram for 46" mtd yard machine riding mower
You can find the belt diagram for the MTD Yard Machine mower in the MTD Owner Manual. The diagram is on page 21.
Feb 02, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
Is there a choke setting and throttle setting for best results in getting the MTD yarde amchine started?
Most of the small outdoor power equipment that I have used takes the following to start:
1. Prime 6-8 times, or whatever the manual calls for.
2. Choke the carb to full choke.
3. Pull starter rope. It may sputter and die.
4. After it sputters and dies, put the choke on 1/2. Pull a time or 2 more and should start. Run like that 10 seconds or so, then take choke all the way off.
Oct 30, 2009 | Mtd Garden
Jul 10, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
I HAVE A 660 SERIES MTD YARD MACHINE 17.5HP 42
If the speed seems to be different after changing the belts, it should return to normal after they break in.
The 600 series has a top speed of about 5 - 6 MPH, see:
http://support.mtdproducts.com/cgi-bin/mtd.cfg/php/enduser/std_adp.php?p_faqid=79&p_created=1027096447&p_sid=tq2XafGj&p_accessibility=0&p_redirect=&p_lva=68&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTYsMTYmcF9wcm9kcz0zMDEmcF9jYXRzPTAmcF9wdj0xLjMwMSZwX2N2PSZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PXNwZWVkIGNvbnRyb2w*&p_li=&p_topview=1
Apr 24, 2009 | Mtd Products Yard Machines 158CC Tiller
Owner manaul
MTD manuals are here:
Apr 02, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Heavy Machinery Logo
129 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
