Question about Audiovox AVT1498 TV
I DON'T GET A AC POWER CORD JUST THE DC FOR MY VAN.
PURCHACED A 13' AUDIOVOX FLEVISION TV MODEL #: AVT1498 I HAD IT INSTALED THREE TO FOUR YEAR BACK IN MY VAN I LOST MY VAN LAST YEAR AND I LIKE TO INSTALL THE TV IN MY SHED BUT I NEVER HAD THE POWER CORD FOR THE AC PLUG. HOW CAN I GET THE POWER CORD OR IF I BUY A AC PLUG TO CONVERT TO DC 12 VOLT WHAT IS THE AMPS. MODEL# AUT1498 SER# 14980050200594 DC 12 - 14V 4A NUMBER - N HOW CAN I GET THE AC POWER CORD. THANK YOU FOR YOU TIME. ROBERT WEST VIRGINIA
I'm looking for that TV For my van..we had same tv and now it doesn't work. How much would you sell it for?
Thank you
Posted on Apr 02, 2009
Power connector pinout for CT-13R50 television
Directly from the user manual, Page 5 under "AC/DC Power Sources":
DC Models ONLY
"This TV model operates on both standard household current (120 volt, 60 Hz AC) and car battery (12 volt negative ground DC) through the cigarette lighter. An AC power cord and a car cigarette lighter adapter cord are supplied.
Household Installation
Insert the AC power cord into the connection on the rear of the TV. Connect the two pronged plug into an AC outlet (120 volt, 60Hz). If you are unable to insert the plug fully into the wall outlet, try reversing it. If the plug does not fit, contact an electrician. Do not force the plug or defeat the safety purpose of the polarized plug."
The manual goes on to describe the vehicle installation which is identical to the household, with the only difference being the car plug goes into the DC side of the power connections at the back.
There are several kinds of power cord available for older TV models. Unfortunately, after an exhaustive search, I was not able to locate a photo of the back of that model television.
However, I have included three of the typical US power connectors found on a great many devices and in the majority of cases, one of these cords will likely be the one you need. They can be found at most local stores such as Wal-Mart, or can be ordered online from Amazon. Also, the cored generally only fit in one direction, especially if the cord happens to be polarized (thin blade and wide blade).
I hope this helps!
Panasonic CT 13R50 Manuals and User Guides
Apr 18, 2017 | Televison & Video
Tip
PIC SHRINKING TOP AN BOTTOM
audiovox 13" DC TV MODEL#AVT1498 CHECK VERTICAL SIZE CONTROL BEFORE YOU CHANGE THE IC CHIP LA3830
on Jun 17, 2010 | Televison & Video
We have a 2000 conversion van. The TV will for for about 5-10 minutes then the picture goes out and a white strip appears in the middle. We can still get the sound however. Please let us know if it is...
You'll probably find that tapping on the TV will bring the picture back when it collapses. This is a common problem caused by bad solder connections to the set's vertical output integrated circuit. The connections can develop cracks over time from heat. A few minutes with a soldering iron is all that's needed to fix this. A TV shop could touch up the connections for some nominal charge, but I have no idea what it might be these days. It's been a long time since I worked in a shop, so I don't know what labor rates are now. Shouldn't be more than $50 as a guess. But it's certainly fixable, and less than the cost of a new TV.
Jul 09, 2011 | Audiovox AVT1498 TV
Where can buy a dc power cord for an audiovox model avt-1475?
Tries websites like Amazon.com,Ebay.com,Partstore.com to buy a new a/c power cord.
May 12, 2011 | Audiovox AVT-1475 13" TV
2005 Conversion Van has TV What do I need to do to receive Signal
If the audiovox does not have digital capability you will need a converter. The converter "converts" the digital signal back to the old signal so that your tv will recognize and play it. Thanks for using fixya.
Mar 03, 2010 | Audiovox AVT1498 TV
Is there going to be a converter box for van tv's for digital signal
There are converter boxes that you can hook up in your van: http://www.ezdigitaltv.com/RVs_and_Digital_TV.html There are instructions how to hook up a 12V system too.
Jun 08, 2009 | Audiovox AVT1498 TV
DTV Conversion Question
Yes you can connect a DTV converter box in your van.
If the TV is DC powered you will need to buy a DC to AC inverter, like these http://www.dcacpowerinverters.com/12_volt_power_inverters.html because there are currently no dc dtv converters available.
If the tv is ac powered you will only need to connect the converter to the inverter the tv is connected to.
If you need more help or installation instructions let me know.
Please rate this solution.
Lone99star
Apr 03, 2009 | RCA R52WH73 Projection Television
No picture but have sound
RDD6 - I had the same problem with my AVT-1498. Took it to the repair shop who told me it would cost hundreds to repair. I figured I could find a replacement crt for less but was wrong - they don't make these tv's anymore, and really don't make any 12v crt's anymore period. So I decided on a 15" 12v ready LCD model which fit the hole where the old crt TV use to be. I needed to rig it to hold the LCD bracket but that wasn't too difficult. Then just hooked the wires back up. Good luck with your situation.
Dec 20, 2007 | Audiovox AVT1498 TV
AVT-1498 Tv
Try the Audiovox web site -Technical Support team
May 28, 2007 | Audiovox AVT1498 TV
Audiovox AVT1498 TV Logo
204 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
