Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner III will not drain
Just stopped draining. What should I look for?
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your problem...
DishwasherWhirlpool Quiet Partner III will not drain - 2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on May 15, 2010
5 Suggested Answers
joe_lishman
  • 192 Answers
SOURCE: Whirlpool Quiet Partner III will not drain
The drain pump motor is in line with the outlet pipe. First check if the outlet pipe is not blocked or obstructed. The motor can be tested by removing the 2 electrical push on connectors and connecting mains supply to the 2 terminals. If the motor spinns it indicates that the motor is OK and that the fault is then with the electronic switching circuit (not normaly a home repair). If the motor does not spin it indicates that the motor is open circuit and needs replacing. (easy job). You can also spin the motor small cooling fan by hand just to determine if it runs freely like it should and is not obstructed by dirt inside the water channel of the pump.
Posted on Mar 21, 2010
SOURCE: whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Posted on Dec 29, 2009
heatman101
  • 43501 Answers
SOURCE: Whirlpool Quiet Partner III Will not drain at the
It sounds like the control unit has gone bad and you will have to replace it...the replacement is not very hard, just make sure to mark the wires so you get them back were they belong on the new unit.
How to Buy Appliance Parts Online
heatman101
Posted on Sep 18, 2010
  • 1416 Answers
SOURCE: Whirlpool Gold Quiet partner III Mod GU3200XTPQ3
Everyone expects their dishwasher will work correctly. They can become nonchalant about it until one day it does not function. Sometimes the dishwasher doesn't drain as expected. Most people immediately call the plumber when their dishwasher doesn't work. There are several things you can try at home before having to pay an expensive service fee.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
Instructions
Things You'll Need:
  • Basic Tools,Rags
  1. Check the basics. Make sure that the dishwasher has actually finish the cycle. Your dishwasher will not drain until the end of the cycle. Many things may have interrupted the cycle. Check circuit breaker and reset it if appropriate. Also check the fuse. It is possible that you could have tripped a circuit have way through the cycle. Make sure the door is properly closed. Ensure you have chosen a cycle on the dishwasher. It is amazing the problems children could accidentally cause, that are easy fixes.
  2. Remove any excess food at the bottom of the dishwasher. The best way to do this is with your hands. Large food particles can block from going into the drain.This is also another extremely easy fix to make your dishwasher to drain.
  3. Check to ensure that the hoses are still attached. Use your manual to find where the hoses are. If they are not attached the owner's manual will give you instructions on how the attach the hoses to your specific dishwasher.
  4. Attempt to declog the line. Disconnect the hose from under your sink and check to see if there are any clogs. Use a hanger or towels, remove the clog from the hose.
  5. Remove the dishwasher basket. Again refer to your owner's manual for specific instructions.Normally you will remove it with a screwdriver. Make sure to work slowly. As you take the basket apart, you will be able to see if it needs to be cleaned. If there is dirt or debris, you can clean the parts with a rag or paper towel. After cleaning these parts, you can replace the basket.
  6. Call a plumber. If the dishwasher is still not draining, the problems are a little more complex to fix. It is advisable to call plumber to make your dishwasher drain.
Thanks for visiting .
Posted on Nov 06, 2010
I have a Whirlpool Gold Quiet Partner III dishwasher. When I unload the "clean" dishes, there is some type of film or crud on the dishes. I have to hand wash them to get this off. It seems like a...
You need to check the drain system completely, look for plugged screens, pump impellers, valves and the drain hose. You need to witness a large volume of water flow during drain.
Sep 19, 2010 | Whirlpool Dishwashers
heatman101
Sep 18, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
Mar 20, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner III. Clean light keeps flashing clean.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
My Whirlpool Quiet Partner III is collecting dirty water after the garbage disposal has run. Is this problem the dishwasher or garbage disposal?
The drain hose under the sink needs to be tied up,above the point where it enters the drain pipe or disposal,water is feeding back into the unit,run the disposal more often also this helps prevent this from happening.
Aug 19, 2009 | Whirlpool Dishwashers
RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Mar 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Quiet partner III taking over 4 hrs to complete normal wash cycle
ok check how fast the water is draining,,might be a bit slow...onthejob
Jan 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
6,701 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
