Lcd becomes visible every time i turne lcd on,
Lcd becomes visible every time i turne lcd on stays visible for 2sec and turnes dark
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 15, 2010
Screen blank
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it.
Feb 09, 2011 | Dell Inspiron 1525 Notebook
My lcd does not display anything when turned on
Feb 04, 2011 | Dell Latitude D810 Notebook
When my m45-s331 laptop is turn on for a long time, if i put the monitor off, maybe in not be turn on again and it's brightness become very low and hardly it can be seen! what should i do?
Jan 17, 2011 | Toshiba Satellite M45-S331 Notebook
Compaq presario cq61 screen went dark but can still see window faintly through the dark sreen.
If no luck, try to remove battery and drain the power, then replace battery and turn on.
Jan 06, 2011 | Computers & Internet
Hi, my hp dv2000 screen is blank when I turn it on. It hums and lights up like it's supposed to, but the screen is completely blank! What do I do?
Nov 30, 2010 | HP Pavilion dv2000t Notebook
Blank computer screen
Nov 09, 2010 | Toshiba Satellite Pro L300 Notebook
Lcd becomes visible every time i turne lcd on, stays visible for 2sec and turnes dark
reset the monitor to factory settings
if still the issue remains press the menu button and hold it down for 10 secs
if still teh issue remains issue is with the monitor i.e. hardware
Mar 20, 2010 | Computers & Internet
Blank screen
Oct 18, 2009 | Acer Aspire 3000 Notebook
Dark picture on wega lcd
Yes, if this TV has a bulb it is likely to be the bulb.
I am not familiar with this exact model, but other LCD Projection TV will show dim picture after some time. Expected life of the lamps is about 2yrs. After 2yrs the picture will become dim. After 5yrs I am suprised it is even working.
Dirt doesn't cause this problem unless your are a smoker or have the unit "literally" outside. DO NOT try to clean it or let someone tell you to do it because it will cause more problems than it fixes.
May 07, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Nuvi 200 screen is extremely dark
The screen brightness could be turned down or the display itself is defective. Even if it was turned down all the way it should be somewhat visible, so if the display is completely blank, I would suggest that the LCD display has become defective.
- Jim
Sep 29, 2008 | Garmin nuvi 200W GPS Receiver
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
