Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
Hoshizaki KM-900MAH Ice Maker it sounds like it is making ice and is freezing it but its not dropping ice any solutions?
  • Hoshizaki Master
  • 1,169 Answers
When the machine first starts, it begins it's cycle in the harvest mode. If the float switch is stuck, it stays in the fill/ harvest mode. Compressor runs and water circulates but no ice is being made. I'd start looking there. Turn the machine on, let it run for about 3 minutes, they very lightly tap the float switch. If it starts making ice, bingo, theres your problem. Let me know if I can be of any more help.
Posted on Jun 26, 2010
Why isn't my Hoshizaki km 630 mkh ice maker not making any ice?
that could be a number of problems..is it making any beeps or flashing lights on the circuit board? Have you tried to reset the circuit boards reset button with the machine on. ? If the machine seems totally dead then the bin thermostat is most likely the problem..
Aug 02, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki km - 280 mah ice maker not making enough ice
A few simple things to check is the condenser for dust. Blow it out. If their is a water filter going into the unit change it. Get some ice machine cleaner and follow directions. Do these things before calling anyone out.
Aug 12, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki km-900mah ice maker won't start the freeze process
cycle is, fill cycle for 1 minute first. If there is not water entering the unit when first turned on, look for that issue. Water turned off, water valve not working or some restriction, clogged water filters, etc. That is got to happen first. Don't over look the bin stat being bad. Nothing happens if teh bin stat is bad. It sends voltage to the control board that runs the unit.
Jul 28, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki km-900mah not going into harvest when float switch opens. New circuit board installed still no harvest. I can set an egg timer and manually operate machine but I can't leave it unattended...
Hoshizaki machines must have a very clean evaporater other wise the ice will bind causing a slow harvest. This may be from lime scale build up. "Lime A Way" is recommended for this proper cleaning. After that is done check to see that the water inlet valve screen is clean and that you have a filter installed.
Last check the thermister attached to the suction line.
http://www.hoshizakiamerica.com/techtips/Pdf/All/tips105.pdf
Aug 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
I have got Hoshizaki Ice Machine which makes three beep sound every 2 second continuously. I turned off the machine. It looks it needs to be cleaned. Can anyone help me to resolve this problem so that it...
I am assuming that it has run two consecutive cycles. I would first clean the machine inside and out. it should drop ice once cleaned, if not then open up the control box and find out which lights are flashing. I am almost certain that once it is cleaned it will drop ice.
Jul 21, 2010 | Hoshizaki Commercial Freezer KM-500MAH
Do you hear the machine cycling like normal but just not dropping? Could be the hot gas solenoid. If you never hear it trying to drop that could be anything from a dirty condenser to dirty plates to bad ice thickness control. Run some ice machine cleaner through it and blow the condenser out.
Mar 20, 2010 | Hoshizaki Freezer Commercial Ice Machines...
ICE MAKER WILL NOT MAKE ICE
Check for power supplied to unit.
Check that the bin stat has not been broken and has no ice sitting on it. If the bin stat is clean and doesn't appear to be broken, you can attempt to jump out the bin stat and see if the machine comes on.
If the machine comes on, replace the bin stat. If the machine does not come on and you have shut the machine off and back on, then you will need to call for service.
The check valve is a common issue with the Hoshi line-up. If you know where this is, take it apart, clean it, and re-install it.
Jan 08, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Water leaking onto ice and outside panel on Hoshizaki KM-500MAE
Remove the cover where the persons finger is and check to make sure that it is not covered with ice. Sounds like your machine iced oup and you will need to clean the coils and possibly replace the thermostat
Feb 12, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki ice machine model KM-250BAF SERVICE MANUAL
km-450mwb hoshizaki problem is machine strate is ok but to long time ice making , not dropping, two beeps every three seconds what problem i don't no pleas help mi
Jul 30, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Water runs constantly
Update on the above! The water does shut off, but when the water is running it runs and splashes for awhile down all over the ice thats in there. Water bill is very high when it is in use.
Mar 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
444 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
