Kodak 750H and 760H neither will advance carolsel without manual
Kodak 750H and 760H slide projectors will not advance by use of controls.
    President:
  • 412 Answers
This is a common problem with older projectors like this. There is a "link" that connects the slide cycle solenoid to the slide change mechanism. The "link" is plastic and gets brittle & cracks with age, rendering cycling non-functional. this is a difficult repair, but parts are still available. I recommend you contact an factory-trained repair dealer to get your projectors repaired.
Posted on Nov 21, 2010
Kodak carousel 760h projector
Dirt or dust accumulation can retard the gear mechanism. If you get Canned Air at WalMart, blow out all open areas and see if you can dislodge the material collected inside.
Mar 25, 2014 | Office Equipment & Supplies
HOW TO FIX A KODAK SLIDE PROJECTOR 76H
If you can be specific as to the problem you are experiencing with your Kodak 760H, I will attempt a diagnosis.
Feb 26, 2012 | Kodak Office Equipment & Supplies
Kodak 750h Projector - The Carousel won't advance when the level is pushed?
If the projector fails to change slides in forward or reverse, then chances are that your projector has a broken cycle solenoid link. The link connects the slide change (cycle) solenoid to the slide change mechanism. Over time the link (made of plastic) gets brittle and cracks. The good news is parts are still available ( www.micro-tools.com) The bad news is this is a difficult repair and usually requires a service manual and a factory-trained repair dealer. Good Luck!!
Jan 20, 2011 | Kodak Office Equipment & Supplies
I have a 750H Kodak slide projector. Where do I find a bulb for it?
The KODAK Carousel 750H uses a 300 watt, 120volt lamp with an ANSI code of "ELH". You can order "ELH" lamps from Bulbman (www.bulbman.com).
Aug 19, 2010 | Kodak Office Equipment & Supplies
Focus Lense Will Not move using the remote or the dial - What can I do? Kodak Carosel model 750H
The KODAK Carousel 750H was manufactured from roughly 1971 to 1981.
If you can push the focus knob toward the outside of the projector and manually remove the lens, then the problem is the gear on the focus shaft (the shaft the focus knob turns). The gear has either cracked and fallen off or is cracked and slipping on the shaft. Either way, the focus shaft needs to be replaced by a factory-trained repair technician.
Jul 08, 2010 | Kodak Carousel 4400 Slide Projector
Both of these models were manufactured by KODAK between 1971 and 1981 (roughly). My guess is that they both have the same failure: The "link" that connects the cycle solenoid to the slide change mechanism is broken. This "link" is plastic, and gets brittle & cracks over time. While parts are still available, this repair is best done by a factory-trained tech with the service manuals.
Mar 20, 2010 | Kodak Office Equipment & Supplies
Kodak 760H will not advance slides
If the projector neither advances or reverses, then most likely the problem is caused by the cycle solenoid "link". The "link" connects the cycle solenoid to the slide change mechanism. The "link" is plastic, and over time gets brittle & cracks, rendering the slide change mechanism non-functional.
If the projector cycles in Reverse and functions in Select, then chances are the projector just needs an adjustment of the cycle solenoid.
Either problem can be addressed by a factory-trained service dealer.
Jan 18, 2010 | Kodak Office Equipment & Supplies
Model 750H overheated and guide says
That is correct. There are 2 thermal fuses: 1 near the lamp, 1 on the power motor. This repair should be made by a factory-trained tech.
Sep 17, 2009 | Office Equipment & Supplies
Bought a 760H to show some old sllides, but the tray does not advance. Is this something that can be fixed? Everything else works fine.
In a word - yes. Most anything on a Kodak Slide Projector can be fixed.
If your Carousel 760H will cycle in Reverse but not Forward, then it's an adjustment of the cycle solenoid. If the projector will not cycle slide forward ort reverse, then it is probably the cycle solenoid "Link". The "Link" connects the plunger of the cycle solenoid to the slide change mechanism. The good news: parts are available (www.micro-tools.com). You will need to seek out a factory-trained dealer to make either one of these repairs for you.
Aug 15, 2009 | Kodak Office Equipment & Supplies
Kodak Carousel 760H wont advance or reverse
You have jammed the slide change mechanism. Turn the projector off. Remove the tray using the emergency release slot in the center hub of the projector. Turn the projector on and cycle it a few times in reverse, then in forward. That usually clears a mechanism jam.
Nov 23, 2008 | Kodak Carousel 4600 Slide Projector
331 people viewed this question
k24674
jasbo
jasbo
