Question about Whirlpool Duet GHW9150P Front Load Washer
Our washer received an F11 error message and we can not find our book to find out what the problem is.
  • 15,935 Answers
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 29, 2010
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    My washer stops &and F-20 appears on viewer. Whats wrong with my washer
    water problem check screens in hoses and valves !! rrors F1, F11 and F20
    • Error F1 indicates a communication error between the computer and the washer. Unplug the washer for a minute and plug it back in, as this may correct the problem. Error F11 indicates a motor control error. It can be caused by improper voltage. Unplug the washer and check the connections. This may fix the problem. Error F20 indicates lack of water entering the machine. If there is no water in the washer, check that the water valves are turned on. If there is water in the washer, press "Stop" twice to drain the washer. Unplug the machine and check the hose connections.
    Read more : http://www.ehow.com/info_12006668_error-messages-kenmore-he2-plus.html
    Feb 21, 2015 | Kenmore HE2 Plus Front Load Washer
    I have an F11 error code on my maytag frontload washer?
    It sounds like a control unit has burned out. There is a computer that speaks to the motor to tell it what to do. If you reset it and a part is bad the computer will still recognize the problem and thus resend error message.
    May 04, 2014 | Maytag Washing Machines
    F-05 MESSAGE HAS COME UP ON MACHINE WHAT DOES THIS MEAN?
    hi have a look below hope this helps, then goggle how to fix it!
    Sep 06, 2011 | Hotpoint Aquarius WD640 Front Load...
    Disply screen flashes F-05
    I have a hotpoint waschmachine wt640 since lastweek I have an error on the control panel F5 andnow it changes to F11 .The machine is just working for a few minutesand stop showing the error message F11 . please help
    Feb 28, 2011 | Hotpoint Aquarius WD640 Front Load...
    Error message E11
    STOP the insanity....that's what you're saying if you encounter the F11 and/or fDL error codes on your washer. If you're not there yet, you will be soon....
    The dreaded F11 and/or fDL codes - been there done ALL that!! Our Whirlpool DUET washer is just over 5 years. We experienced our first F11 code 6 months ago (warranty just expired what else is new?). When it first happened, I thought nothing of it - hit the cancel button and the machine reset itself. Then it happened again and again and again. Each time it happened it was more challenging to reset it. I searched for the fix on line - I should have done my research before we purchased the washer.
    I was able to determine the error was stemming from the CCU board. Order a new one at over $300.00 and have the same thing happen again - I don't think so. We tried EVERYTHING suggested on multiple websites.....unplugging the washer, hitting the right upper side, checking wires, wiggling the wires, wedging things to improve contacts, soldering, re-soldering, Vaseline, changed relays....anything and everything was a temporary fix. Contact Whirlpool directly? Tried that too, they apparently don't recognize there is an issue with F11 fDL errors, "not a commonly called in concern". Really?? We started searching washers to purchase....I couldn't bare spending $$$ for another washer, but we are a busy active family with 4 kids - what are our options? Then one night after searching the websites for one last desperate attempt at salvaging our washer, I followed through on a link:
    http://cgi.ebay.com/Whirlpool-Duet-Kenmore-HE3T-CCU-Repair-For-F11-FDL-Code_W0QQitemZ230397337074QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item35a4c05df2
    email: selling.surplus@gmail.com
    Now, I'm the biggest sceptic in the world and the most frugal consumer - really I am. I am posting my testament to this service because I've been there - frustrated, disappointed, angry. I am so pleased with the service Ed provided - from answering all my questions, to the superb job he did on the CCU. You can review all the comments posted by all his other pleased customers on eBay. I had to stand by my washer for the first 6 loads - just in case the beep beep beeps started. To my astonishment, amazement, and surprise - it never happened!! In my opinion, this is the only true fix for your F11/Fdl error!!
    I never imagined in my wildest dreams ever telling anyone how happy I am to be doing my laundry again, but I really am!!
    May 11, 2010 | Washing Machines
    “F” Variables [other than FH, F02, and SUD] (Electrical
    Problem)
    Select PAUSE/CANCEL twice to cancel the cycle. Select
    DRAIN/SPIN if there is excessive water in the washer.
    Re-select cycle and select HOLD TO START. If the problem
    remains, call for service.
    You can download the manual here:
    http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208182748.pdf
    Mar 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Error Code F11
    TRY UNPLUGING IT FOR A MIN OR TWO. I THINK F11 IS A CONTROL MODULE. CALL A TECH
    Oct 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Duet GHW9160PW0 F11 Issue
    not related to shake, issue, but hte f111 and dl issue def sounds as if the connection between the 2 has been compromisdd, in my experience it has been a faulty CCU, losing communitcationsd with the door latch thus the f11
    Dec 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Error F11
    Plug off the wall. Shaking & vibration of your washer causes circuit board connections to become loose; due to faulty manufacture. Remove the 3 or 4 screws from the back & take off the top cover to secure the connections, make sure they are tight. This applies for the F11 & F dl codes. Works for certain machines, dont see why it wont for yours.
    Dec 10, 2007 | Kenmore 46462 Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    26 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
