Question about Plumbing
Freeze proof faucet dripping badly (hardly used 6 yr old) bolt holding plastic handle seems pretty well rusted on. I'm trying toi figure out if there is a servicable washer that needs replacement.
    Scholar:
  • 102 Answers
I assume that you are refering to a wall mounted hydrant. If that is the case, most do have a bibb washer at the end. You have to remove the packing nut and then the stem to get to it. Some brands you can do this while the handle is still on. Hope this helps.
Posted on May 14, 2010
How much water to drip in cold weather
drip 1-2 drip 1-2 drip no less then that or its liable to freeze how cold is it getting ?
Feb 19, 2015 | Price Pfister Plumbing
I need a water proof outdoor time for my overhead drip system. Each season I end up buying a new one. My vigoro 196-036 appears to have frozen and busted an internal gasket. Any suggestions
Water timers are made of plastic.
If water is inside any plastic fitting, and there is a freeze, then plastic will crack.
Raindrip, Melnor, Gardena drip systems are made of plastic.
I don't know anyone making a brass drip timer that could expand instead of crack, because the expansion would damage timer shut off valve.
There are 2 strategies to solve problem:
1) Remove timer from cold area during freeze.
2) Wrap heat tape around timer so it will not freeze.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 29, 2011 | Hardware & Accessories
I have a Delta Tub/Spout Pull Down Diverter that has a pretty persistent drip. The HOT and COLD handles are turned off and seem to be as tight as they can be. After doing some research online I believe...
If your Delta RP17453 Pull-Down Diverter Tub Spout stops dripping after 5 minutes, your ok. If it never stops dripping, you need to replace delta faucet cartridge(s) behind the handle(s). This is were the water turns on and off and stops the water flow to the tub spout.
Delta faucets are some of the easiest to repair, and parts are usually available at any hardware store or home center. If you have a two handle faucet, replace both delta seats and springs and stems. If you have a single handle Delta faucet, replace the entire cartridge.
Jan 26, 2011 | Delta Faucet Delta RP17453 Pull-Down...
How remove the broken bathtub cartridge(Moen 1222)
The exact procedure to remove the old cartridge is with a plastic removal tool.With replacement cartridge you have to buy this plastic removal tool.Also there is same metal removal tool available.With the help of this tool you can easily remove the old cartridge.
Moen Cartridge Replacement Instructions
Moen shower faucet cartridge replacement is a project that will take some time to get done right. When is it time to replace a Moen cartridge? If you are like most people, you won't want to replace your old Moen cartridge until your old cartridge is starting to show its age.
Replacement is necessary, usually, once the old faucet starts to drip. Thankfully Moen faucet cartridge replacement is not difficult. However, if you are uncomfortable with doing the repair yourself, do not hesitate to call a professional plumber to do the job for you. This will guarantee that the job is done right.
If you follow these Moen faucet cartridge replacement instructions you will be able to replace your old cartridge by yourself. First of all, as with any plumbing repair, make sure that the water supply is turned off. Open the faucet to remove water pressure from the lines and let the remaining water drain from the pipes. You will then need to remove the faucet's handle by removing the decorative cover and removing the retaining screw. This will allow you to remove the handle.
Once the handle has been removed, work on releasing the splash plate from the wall. Generally there will be one or two screws to remove and the plate should release from the wall easily. From here the process begins to get a little trickier. Insert a shower stem socket onto the faucet valve's retaining nut and release the nut. Your Moen cartridge removal will be complete once you grab the cartridge with a pair of pliers and pull straight out to remove the old cartridge.
Clean any surfaces that you have access to and replace with the new cartridge. Follow all of the previous instructions in reverse order to re-assemble your shower faucet. Check to make sure that all the connections are tight before turning the water back on and testing the system out.
Now in your case the broken/cracked while removing the old cartridge so try this procedure carefully to get the stuck -up old cartridge out.
TAPPING the Threads into the Cartridge:
Carefully  hold one tab on the cartridge tight against the brass lip on the faucet body with needle nose and try  to drive the 1/2" tap into the smaller bore of the cartridge. It will take  about 15 minutes to slowly work the tap in all the way (maybe 3 turns?). Then  back out the tap... remove needle nose. [remember to turn the tap 1/4 turn back, for each 1/2 turn forward ... this clears the metal particles from the tap and makes the next 1/2 turn forward go smoother].
Next, assemble a 1/2" x 4" threaded rod, so it had threads all the way to the two jam nuts on one end)... If you use a bolt, get one with threads all the way up to the head. you may find it hard to find - so try a carriage bolt and spin a nut all the way up to the head .... continue:
next on the bolt goes a 1/2 nut (this is the "jacking nut") and a flat washer so the jacking nut can spin easily against the next piece, a 1/2 drive socket (7/8" ) with the square hole toward the washer and jam nuts ( bolt head ).
The open end of the socket faces the brass body of faucet and rests on the round brass lip... having the same inside diameter. This allows a space for the cartridge to be pulled into ( a cavity). Thread the bolt into the tapped cartridge and snug it up so the 7/8" socket is aligned with and resting against the brass body. If the cartridge spins smooth, the threaded rod is GREAT. You can just work with the 1/2" rod and use needle nose (or similar) to stop the  cartridge from spinning, to get the rod threaded into the tapped threads in the cartridge... then, slip on the socket, washer and nuts.
Now snug it up tighter. Check socket alignment. Then begin turning the jacking nut ( the "extra" nut) until it contacts the flat washer and 7/8" socket. Now, as you continue to tighten the jacking nut, it will pull the 1/2 bolt (threaded rod) away from the faucet... and the cartridge will come along too. [You have to prevent the 1/2 rod from spinning while tightening the jacking nut. put a wrench on the bolt head.]
This procedure is bit lengthy and requires some appropriate tools,but this will release the stuck cartridge out.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jun 05, 2010 | Moen & One Handle Tub & Shower Faucet
Freeze proof faucet dripping badly (hardly used, 6 yr old), bolt holding plastic handle seems pretty well rusted on. I'm trying toi figure out if there is a servicable washer that needs replacement.
It does have a serviceable washer. Use a 12" crescent wrench on the collar. unscrew the head and pull out. You may ALSO need to unscrew or "open" up the faucet to unscrew the threading in order to put the shaft out of the body. The spray and work the rust off with WD40.
Mar 20, 2010 | Plumbing
I have a 3 yr old side-by-side. The freezer is freezing ice cream solid even though it's turned all the way down. Food in the bottom two drawers on the refigerator side are freezing. Water has dripped...
Hi, this problem is going to be with the running thermostat. (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Faucet was self installed (Loews purchase) last year. Returned to hone after 6 month departure and only cool to warm water will run from faucet. DO I need to clean or replace cartridge? Less than 1 yr old....
Likely rust clogging valve, but remove arator first and clean. Rust accumulates in any metal pipes (coper, or galvinized) when not used for extended period of times.
Aug 05, 2009 | Delta 989-SSSD Allora Kitchen Pull Down...
Clayton mark freeze proof hydrant
You are going to have to dig and replace the entire freezeless faucet. sounds like it either froze or rusted off.
Jan 22, 2009 | Halex Liquid Tight 90 Degree Elbow, 3/4"
Plumbing Logo
122 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
