Question about Refrigerators
Cleaning Glass shelves mold.
I need to clean the shelves in the maytag mzd2766ge. The refrigerator was stored and turned off for a year. The Shelves had mold in them . Can I take the shelves a part? I need to clean all the nooks and crannies. thank you
  • Anonymous Mar 15, 2009
    I have a problem. The edges of the shelves have become dirty, filthy-looking and if there is a seal, it has been broken. How do I clean the shelves? It seems that the soiled part is between the glass. I've tried bleaching and it hasn't worked. Help!
  • 1,314 Answers
The cantilever shelf trims are easily removed
by placing the shelf on a flat work
surface. Raise the front of the shelf, grasp
the right underside of the front trim, and pull
toward you. Next, remove the glass from
the rear trim and remove trim. see if this helps
Posted on Mar 30, 2008
  • 109 Answers
The shelves can be removed not taken apart. sorry they're glued together, just use a bristle brush and some bleach. no problem.
I took my fridge apart to clean it and now I can't recall the proper shelf positions. I have a Maytag RSW2400
the fridge has a number of positions for the shelves to suit different heights of the items you are putting in the fridge
set the shelves that best suit what you have
Dec 10, 2016 | Maytag Refrigerators
French refrigerator has green mold in refrigerator under metal p arts that I can't get to or clean
Children do not create mold or germ problems. Try to make a cleaning tool that does reach into the area, perhaps bending a long metal spatula or a barbecue brush.
Dec 14, 2013 | Computers & Internet
How do i adjust the shelves in my Maytag side-by-side refrigerator?
You should have pins or clips that rest in a standard that you can take out for adjustments. Simply pop them out . If yours are made onto the shelf itself, then raise up on the front side of the glass then pull it out from the post or standard.
Feb 09, 2013 | Maytag 25.1 cu. ft. Side by Side...
Turned it off,Took out glass shelves to clean, now shelves won't slide back in!!
sounds like liner has expanded because it warmed up try turning it back on let it run overnight and try again
Nov 03, 2012 | U-Line 1175BEV Beverage Cooler
How do I remove shelves for cleaning an lg French door refrigerator?
On my Kenmore (795.7555* made by LG) French door, the adjustable shelves are removed by tilting them up and then bringing them forward. The sliding shelves and drawers just pull forward.
Which model LG refrigerator do you have? There may have been design changes between your fridge and mine. Please add a comment with the information for specific instructions.
I hope this helps.
(I didn't bother to give the full model number of my fridge since the directions also apply to the 795.7519* and 795.7554*)
Jul 06, 2012 | LG Refrigerators
How to get glass out of shelves for cleaning
most shelves have the glass attached to the side brackets,, empty the shelf, and at the back of the fridge,, you'll see slotted rails that go top to bottom,, tap the shelf bracket upwards and it should come right out,, be careful,, once off the glass may come out too,,
Jun 13, 2011 | Refrigerators
GSS25LGMCC Side-by-Side. On left freezer side, foam filled walls have contracted and top two wire shelves can no longer rest of molded side supports and fall. Need shelves about 1/2" wider
never heard of that happening,are you sure you're not missing a support that the shelf slides on or you have the wrong shelf for that spot.i'm sure you tried the shelves in all the slots,if the wall did push out like you say the only thing i can suggest is to buy another support and get longer screws and put the screw through both supports and hang them like a single support to make up the what caused this to happen,is the freezer staying cold?if you give a parts store your model number they will sell you the same shelves that you have.
Apr 30, 2011 | GE GSS25LGM Side by Side Refrigerator
What's the best way to remove mold from fridge?
'That is the best way to clean mold is use bleach you will be okay. Just alot of work.
Jul 06, 2010 | GE PSS26SGRSS Stainless Steel Side by Side...
Refrigerators Logo
733 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
