Question about Gateway GT5678 Desktop PC
My Gateway GT5678 system powers up as if normal but no display and no error beeps. Fans are running lights on no image. Checked all components on another computer and they work. Think it is the motherboard but want to be sure before buying a replacement. Any ideas?
    Champion:
  • 218 Answers
Well i think your problem my be the power supply unit i would try replacing it first as its cheeper than the mobo failing that yes it would be the motherboard hope this helps if it does please rate this answer
Posted on May 15, 2010
Tip
Beep code and their meaning: 1 short beep Normal POST - system is ok 2 short...
beep code and their meaning:
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps 3270 keyboard card
on Sep 07, 2013 | Computers & Internet
Gateway wont startup. One beep followed by two short
Not sure where you got your information on the error codes but it is partly correct, it is video related, but it isn't the video card but rather the memory location in the ram that is used by the video card. You could try to remove the ram memory clean and re-seat it on the mother board and see if that fixes it, or if your motherboard has two or more ram memory modules, remove the memory and switch which sockets you replace them in (make sure you keep track of the original position of the modules because on some rare motherboards you have to use the memory in a picky order) after mixing up the memory modules check for a boot again, if this corrects the booting then one of the memory modules is defective and may need replacing. Note when you take your memory into a computer shop be sure to use a static bag and proper static precautions.
Nov 12, 2013 | Gateway GT5678 Desktop PC
I would suspect the power supply or a power connection. The only other issue might be a motherboard, which is a bit more involved. Try another power supply if you have one around.
Lenevo t61 1 long beep and 2 short beeo no display
Standard Original IBM POST Error Codes 1 short beep Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Nov 09, 2012 | Lenovo ThinkPad T61 6457 Notebook
Where I can find Gateway GT5678 Bios update
you can get from gateway website > support
Feb 08, 2011 | Gateway GT5678 Desktop PC
My Gateway GT5678 system powers up as if normal but no display and no error beeps. Fans are running lights on, no image. Checked all components on another computer and they work. Think it is the...
When you say you tested the other components, did you test the graphics card in particular on another computer?
If so, and if it worked, you can try clearing the CMOS. There should be an easily identifiable switch or set of pins with a jumper. With the power cable unplugged, set the switch or move the jumper into the clearing position, leave for about 30 seconds, then move it back into position (important! do *not* power on the system while the jumper or switch is in the reset/clear position). Try booting up the system again.
If it now has a picture, you will probably need to enter the BIOS and, at the least, make a basic change such as setting the first boot device (defaults to the cd/dvd-drive, then the primary-channel+master hard drive).
If you still have no picture, and you are using on-board graphics only, then there is a chance that the on-board graphics chip may have died.
To test this, you can put a graphics card into the system (I recommend a cheap, second hand one that you know is working, in case the motherboard ends up damaging the card), repeat the CMOS clearing process, and then try booting up the system with the monitor plugged into the graphics card.
If you get a picture, there's a good chance the on-board graphics have died. You'll want to go disable the chip to prevent it from causing any further problems by finding it under the 'integrated peripherals' section of your BIOS. If it's not located there, search for an option for the 'primary graphics adaptor', and change it from IGP to PCI-E. Then find any option for 'vga memory share size', and see if you can set that to 0mb. If it is the model with the 2400XT with its own 256mb memory, you'll need to find an option to disable it entirely.
Please post a followup if none of the above was able to help you, with clarification if possible as to what you're using and have tried, and I'll see if I can help further.
Mar 20, 2010 | Gateway GT5678 Desktop PC
Beeps
Code Description
1 short beep System is OK
1 long, 3 short beeps Display adapter problem (EGA)
For more info go here: http://pulonangka.web.id/software/beep-codes-error-codes
Aug 16, 2008 | Dell XPS M1530 Notebook
Gateway GT5678 Desktop PC Logo
330 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
