Question about Pool & Spa
Trips breaker when heater comes on wher can I get a heater
  • 22 Answers
Need to know more information, is this a electric heater or gas heater. perhaps there is water leaking into the heater connections and the moisture is causing the tripper to break becasue of the water this can be cause by a leaking seal or drip into the heater compartment. make sure all connections are clean and free of debris and moisture
Posted on May 14, 2010
The pump shorts out when heater is put on
Electric spa control?
what do you mean pump shorts out? Are you saying a breaker trips or a GFCI trips?
if so, it has nothing to do with the pump, if it's already running. But once the heater engages and the breaker trips, then you have about heater element.
Mar 28, 2015 | Pool & Spa
Wiring schematic for white-westinghouse window air conditioner/heater selector switch
I'm willing to bet that the heater is grounded. Probably burnt up the original switch, heater wasn't getting power, therefore not tripping the breaker. Now the switch works, heater gets power and immediately trips breaker. Unhook the switch and tape the wires, reset breaker and try in heat and cool. If no problems it's likely the heater.
Apr 20, 2017 | Heating & Cooling
Breaker trips; reset breaker at panel and water heater "on" light comes on. Breaker tripped again in 5 min; reset breaker again and water heater light comes on. Cycle continues to repeat. Bad...
It is possible that the breaker is bad. It is also possible that your water heater is overloading the breaker. It is probably easier to try a new breaker to start with. Unless you are familiar with changing the breaker, call an electrician. Your life is a very valuable asset to you!
Feb 18, 2011 | Water Heaters
As soon as I turn on my heating unit, it trips the breaker. The heating unit will come on and in a matter of a second, it trips the breaker. What's wrong and what can I do?
Heating element short circuited. Or wires to heater may be loosen or short circuited. Check your breaker also. Sometime, due to defective breaker also it happens.
Dec 15, 2010 | Heating & Cooling
Trips breaker when heater comes on ,wher can I get a heater
sounds like you need an electrician to put in a higher amp breaker. I'll bet the heater is just fine
Mar 20, 2010 | Pool & Spa
Trips breaker
If it trips the breaker you MUST have an Earth fault and or a short circuit to Neutral/Earth. You must get a Registered Electrician to look at it.
Feb 03, 2010 | Eemax SP80 8.0kW 277V
Unit comes on and runs for 5 minutes, the circuit trips off
30 is the correct size breaker for this unit. It sounds like there is a grounding issue going on in the system. Or off of the Thermostat. Something is grounding out causing the switch to trip. Are you running #10 wire to breaker and the unit? If not you will need to increase your wire size
Jan 03, 2010 | Dayton D-F79 Electric Space Heater- the...
What will cause door heaters to trip breaker.
You have a short some place isolate each component if you disconnect the heater and it does not trip the the breaker replace heater. caseparts.com good luck Tom
Jul 01, 2009 | Victory Freezer Freezer, Reach-In, 2 Door,...
Heater not coming on.
sounds like the heater element is out. if you turn the breaker on and once the tub cycles on it trips the breaker again. it is definitely the heater element.
Jan 31, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
50K BTU Reddy Heater Trips Circuit Breaker
If the unit lights Check the photo cell this can be done with an ohm meter and good light. Should have continuity in light.
Jan 14, 2008 | Dayton E50 Heater
Pool & Spa Logo
70 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
