Question about Plumbing
The pump turns on every 45 seconds.nothing is in use to make it turn on to pump.it's a small Jacuzzi pump that pulls water from a well.started doing this 3 days ago.presuure gauge reads 40 and doesn't fluxuate. No problems in 20yrs.
  • 22 Answers
The pressure guage may be clogged or the tubing that supplies the guage may have something stuck in it. look at the contacts sometimes the ants or bugs hide near contacts due to heat and then get fried and jam the contacts.
Posted on May 14, 2010
Why do jets turn on, then shut off?
the motor protection device is sensing to many amps. could be a flow restriction or the pump motor bearings are going bad.
Mar 06, 2016 | Jacuzzi Home
I have a jacuzzi amiga N890 that when you turn the unit on it just hmmms. It is getting power but does nothing else accept hmmm.
If you turn the Jacuzzi pump on and it just hums and no water flows through the jets then you have a bad pump.
You will need to get the brand name of the pump and the model number before you can begin your search to find the proper replacement.
Bath Pumps each have their own size. You will want to find the exact brand so you do not have to change any of the plumbing.
US Parts Center
Aug 20, 2013 | Jacuzzi Amiga Whirlpool JAC-N890...
My jacuzzi bath tub makes a humming noise when I turn it on, but it will not operate. I tried again later, and still nothing, and not even the hum now.
Pump was humming, suspect air lock, pump could of burnt out, check power to pump and if it blows fuses then you will need a new pump and don't forget to bleed the pump
Jul 16, 2011 | Jacuzzi Home
When i turn jacuzzi on it primes and one of the pumps/jets turns on, then when i try to turn the other jet/pump on it makes a funny sound and blows a fuse i checked to see if any air is in the line but...
This is probally a bad motor, the sound you hear is the motor trying to start but when it can't the breaker trips. If it takes a start capacitor it may be this rather than a motor but you will have to pull the motor to see. It may also be a clog in the pump but the motor sounds like the problem.
Sep 29, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
Jacuzzi pump not pumping
I would probably say that the pump is clogged up or frozen. The motor humms until the heat sensor clicks it off. Try taking apart the front of pump and see if it turns and you should see the problem. Parts are available at most pool stores. Pumps are usually cheaper online.
Jun 25, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jacuzzi Magnum Force Pump not working
The number one problem is air leaks.......check all connections to see that they are tight, and rubber seals. The intake side would give you trouble with air leaks. If you dont find any leaks then I would pull the pump cover and check the impellor. Pool stores have parts and lots of knowledge.
Jun 09, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Plumbing Logo
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
