My computer is not booting, I've researched and
My computer is not booting I've researched and troublehooted but nothing. It will not boot at all. I've done so many things. I did get a error code B10HD-2. I replaced the Hard Drive and still the same. Its not that. I had many people look at it (pc stores). Can you provide any info. It's not reconizing the hd. It wont let you put windows in it or the recovery disk. Thanks in advance. - Susan
  • Pete MacSparran
    Pete MacSparran May 15, 2010
    You posters need to start telling us the make,model & operating system when posting.
  • 66 Answers
You may want to start asking about the motherboard if the socket is bad on the motherboard then the hard drive will not be able to read. ask a tech to take your hard drive and hook it up in another pc and see if it works if it does then you might need to replace the mother board
Posted on May 15, 2010
0x0000007b error windows
You seem to have done all the right things. Although I don't like 'any viruses have been removed' - I wonder what they might have done? Sounds like you sometimes get into Safe Mode. If you can do that once, then go try and get into System Restore and return to an older verdsion before things went wrong. Then re-boot.
Otherwise it may be faults developed in Windows itself. Most OEM installations have a protected copy of Windows on a hidden sector. Maybe get in touch with makers/suppliers and ask how to access it?
Apr 06, 2014 | E-Machines Computers & Internet
C3200 stuck on error screen
did you check the contact from unit 1 and at the back or a connector rest error,power supply board
Feb 18, 2013 | Canon imageRUNNER C3200 Copier
I have a Dell Latitude C610; after initial 'DELL' screen comes up, the laptop gives one 'beep' then black screen and nothing more- power's still there; can get into setup and boot...
This chart details the specifics of what each 'beep code' means. Usually the codes come in series of 2-3 beeps not just one.
http://www.nullamatix.com/dell-diagnostic-beep-code-troublshooting-chart/
You should also make sure the 'dummy' stuff is done, like remove any floppy disks or CDs from the drive if you have one, and remove any USB drives from the laptop as they may try to boot off of them and not be able to. If you've done that, then check the chart in the link for further information. Sadly a non booting, beeping computer isn't a good sign. If I can be of any more help, please let me know.
Hope this response helps you out.
Best of luck!
I strive for '4 Thumbs Up'! If I've assisted you, I'd greatly appreciate you taking the time to provide me with a favorable rating. Thanks so much!
Jun 22, 2011 | Dell Latitude C610 P3 Notebook
I have a N150 plus netbook, 6 mo. old. Using it on the internet this afternoon, it froze up; went to Task Manager, which also froze. I then rebooted and it won't boot--powers up, gives the...
In first remove battery, then one press turn on buttom, then put battery, and turn on.
if will not resaults,
reinstall operating system from CD/DVD
Jun 04, 2011 | Samsung N150 (36725723009) Netbook
My laptop froze. Nothing that I press on it gives a response.
The first step that should be taken is to shut down the laptop. This can most likely be done by holding the power butting down for 10-15 seconds. The next step is to restart the PC and see what happens. If it boots up correctly than this have have been just a one time issue. If after restarting the laptop it will not boot than some trouble shooting steps should be taken. When starting the PC your getting power? If not than there is an issue with the power supply or battery. If you are getting power to the PC than you should listen for the beep code on start up. 1 beep after starting the computer signifys that the power on self test (Also known as the POST) has completed with out issue. When getting any other type of beep code you should research the meaning of the code. Beep codes differ from company to company. The best way to identify the meaning of a beep code is to type the manufacture, model and number of beeps into Google. Another possible issue is that your hard drive is corrupt. If this is the case than your computer will pass the power on self test(POST) but will have a message like MBR not found or one of many other errors. If you are getting an error than it is also a good idea to research the error to determine the proper fix. If the PC seems to boot correctly but there is no image on the screen than the issue may be a result of a bad video card. In that case the video card will need to be replaced.
I hope that information above has helped is some way.
If possible please rate this solution.
Sep 01, 2010 | IBM ThinkPad T43 Notebook
My computer is not booting, I've researched and troublehooted but nothing. It will not boot at all. I've done so many things. I did get a error code B10HD-2. I replaced the Hard Drive and still the same....
sorry for my language
if Your bios not recogn your hdd -that means yoyr hdd is broken - or u must change settings in your bios (older bios) - try change boot settings in Your computer.
Mar 20, 2010 | Computers & Internet
System error
usually at starting up the computer, press either esc, F2 Or Delete.
this has to be done immediately at the computers boot.
there is with certain bioses, a display at boot up, i.e for setup options press F2 Or Delete et,c.
Be careful what you change in the settings, only change what you have to, or make a written note of what you,ve changed, incase you have to correct any errors.
Regards Mike @ Compurepair.
Please rate this Solution.
Thanks for your request.
Nov 05, 2008 | Computers & Internet
Windows XP won't boot and safe mode doesn't work
Well hate to give you the bad news but it sounds like your hard drive as died. The error code you mentioned (0X000000ED) designates file system damage. (Referenced here http://support.microsoft.com/kb/297185). Your best solution would be to replace the hard drive in a repair shop.
Sep 07, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
David Payne
David Payne
