Question about Sewing Machines
I have a Bernina 340 Deco embroidery computer. I am having trouble (lots) with the thread looping on top of fabric.
    Problem Solver:
  • 13 Answers
Either try rethreading machine from beginning... or your top tension is too loose... did you switch it over? I have a Singer futura and I have to switch a couple things around for sewing or embroidery...hope it helps
Posted on May 14, 2010
My bottom tention of Bernina Deco 340 is to loose. How to I correct is. The top treat shows to much at the bottom
Um, the top thread is showing on the bottom of the fabric? The top tension is too loose. The two threads create a tension battle, one pulling against the other. To pull the bobbin thread up, tighten the top tension. The tension is accurate when the two threads meet "in the middle" of the fabric. On thinner fabric, you might see a tiny spot of bobbin thread on the top and a tiny spot of top thread on the bottom.
Aug 24, 2017 | Bernina Sewing Machines
Need for deco magic box for a Bernina Deco 600
You can not connect the Deco 600 to a computer. Buy the Brother PED-Basic software rather than the Magic Box, Brother makes the Bernina Deco...
Jul 25, 2012 | Bernina Bernette Deco 600
Make sure the bobbin case and shuttle are free from any thread tangles.
Thread with the presser foot up.
If problem persists, the machine will need to go into the shop where an authorized Bernina tech can check the timing and do a general service of the machine.
Take a sample of the mis-stitching.
Mar 20, 2010 | Sewing Machines
DOES THE BERNINA BERNETTE DECO 600 ACCEPT .ART EMBROIDERY DESIGNS SUCH AS I USE FOR MY ARTISTA 730E? ALSO, DOES BROTHER MAKE THE BERNINA BERNETTE DECO 600?
Not sure if you found anything out, but Deco 600 uses PES format only.
If you have the software (Deco Wizard) sometimes you can change it to PES and save the design.
Good luck
Jan 05, 2010 | Bernina Bernette Deco 600
Bernina Deco 650 Top thread is winding around the bobbin
You should use some klnd of stabilizer under your hoop. I use the paper kind which is thin or there is a heavier tear away stabilizer. I have used all cotton thread for embroidery or you can use rayon. There is a finer thread called bobbin thread for the bobbin but I gernerally use the same as on the top so it will be the same. Are you using an embroidery needle? .As for your thread getting wound around the bobbin the only thibng I can think of is tht it is threaded incorrectly. if it isn't the lack of a stabilizer. I hope this helps but I think it the the lack of stabilizer that is causingyour problems. The needle is going in and our of the same hole during embroidery and is getting stuck on your bobbin. Let me know if this helps! Suz
Jan 17, 2009 | Sewing Machines
Top color thread showing on bottom of embroidery on a Bernina Deco 330 embroidery machine
Upper tension is too loose or lower tension is too tight.This might be a good thing. It depends upon how much it is pulling the thread under. A perfect tension on embroidery is about 2/3's lower thread and 1/3 upper thread showing on the bottom.
sewman7
Jul 09, 2008 | Bernina Bernette Deco 600
Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
May 19, 2008 | Bernina Bernette Deco 600
Thread loops in top of embroidery
If it was an upper tension problem your loops would be beneith the fabric. Since the loops are on top this tells me the lower tension is too loose. There is a small screw on your bobbincase that you need to turn clockwise to adjust it. Do the adjustment little by little until its good. I would do it like a clock. First turn the screw to one o'clock. Still looping? Go to 2 o'clock etc.
If this doesn't help you, a clean opikl, and adjust by your local dealership could be anywhere from 50.00 to 90.00.
Good luck
Nov 05, 2007 | Bernina Artista 180
Sewing Machines Logo
142 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
