Question about Refrigerators
I have a manitowoc QY0424A ice maker and the water runs over the catch basin but it still makes ice. It doesn't run over all the time but most of the time.
2 Suggested Answers
  • 29 Answers
SOURCE: I have a manitowoc QY0424A ice maker and the water
Turn back the pressure on the water going into your home and or if there is an adjuster on the back of the fridge set it for 1/2 less.
Are you in a house or a flat?
Posted on Mar 20, 2010
Water continuously runs and drips while making ice
water level sensor is bad, check Your lights on control board, it will stay off at water level light when water touches the sensor.
Apr 19, 2015 | Manitowoc SM50 Series Ice Maker
How can i fix my manitowoc qm45a runs water but won't freeze the water?
The thickness sensor is shorting, making the machine continually harvest. Clean it and dry it. If it still happens, replace the sensor.
Aug 05, 2014 | Manitowoc Compact Undercounter Ice Machine...
Icemaker runs constantly but never makes enough ice to shot off. Too much water spraying out and melting the ice. What to do? Have run through cleaner cycle several times. Disassembled and cleaned also.
Process of elimination. ... ice thickness sensor (adjust and clean).... water outlet bar with holes that runs down the ice maker plate (make sure all the holes are not clogged and point to correct angle to keep from splashing) check those 1st.. the other steps are more involve if you have refrigeration tools to check refrigerate level, etc.. let me know if this will help 1st
Oct 31, 2013 | Manitowoc SM50 Series Ice Maker
U line ice maker, the water doesn't shut off after filling the tray.
Change the water inlet valve if it is off and water continues to bypass the valve when off...Sea Breeze
U-Line Refrigerator Parts
Water Inlet Valve 2552A
Mar 25, 2013 | U-Line Icemaker
Manitowoc ice maker does not produce ice
If it doesn't run at all open the front panel and peer inside of the control box. See if there are any indicator lights on the control board lit or blinking. Check the plastic water curtain on the machine and make sure that the magnet is in place on the bottom right. Will need more information as to what lights are lit. Printed on the board next to each light is its corresponding function or response.
Nov 11, 2010 | Manitowoc SY0454A S Series Ice Maker...
Mar 20, 2010 | Refrigerators
Water leaking in the freezer compartment. Water running out of the bottom of the freezer. Does not leak all the time. Turned the ice maker off. Still have water on the floor. This is a Maytag wide by side,...
Are you sure the water is from the water line?
Usually, water inside a refrigerator is defrost water that is not flowing in the direction it is supposed to be going. The defrost water flows into a catch basin behind the inner lining of the refrigerator. From there it goes into a plastic tube which carries it underneath the unit to a pan. The heat from the coils and compressor then evaporate it.
On most refrigerators you can see this tube at the rear. It should exit the unit somewhere and run downward. See if you can detach this tube and make sure it is not blocked. Another possibility is that the catch basin inside the refrigerator is clogged. Checking this would not be easy. The inner lining of the refrigerator would have to be removed. I have seen these basins filled with debris and ice. This can shut of the flow of the defrost water completely. The water has to go somewhere, and it flows inside the refrigerator.
Oct 20, 2009 | Refrigerators
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
