Question about Grundig S350 AM/FM/SW Radio
Clock How do you set up the clock on Grundig S 350 ? It shows me 8 hrs behindand I can't do it.it's plugged in ac socket.
    President:
  • 742 Answers
Ask here:
http://manualfox.com/link/grundig.htm
they can get you every Grundig manual.
Posted on May 14, 2010
I dont no how to set the timer to 24 hr clock
change to 12 clock
however a 24 hour clock has the same times up to midday -- midnight to midday --- the hours are 1 to 12 oclock after midday you take 2 off the reading and it is the same time as a 12 hour clock
so 1300 is 1 o'clock, 1400 is 2 oclock ,1500 is 3 o'clock
1800 is 6 o'clock 2400 is midnight
the minutes are the same regardless so 1.30 is 1.30 after midnight or 1330 after midday or 1.30 after midday now for example --if you want the timer to start at 6am you set the timer to start at 6 am to switch off at 8 am set switch of at 8 am
it you want the timer to start at 6 pm set it at 1800 and switch off at 10pm set it at 2200 hrs
Jan 22, 2017 | Hardware & Accessories
The clock is saying 18:88 and won't brew coffee
Hmmm .... sounds as though it may have encountered a power
surge overnight. Might try the Microsoft universal corrective action:
1. Unplug the device from the wall socket
2. Leave it out for 1 minute.
3. Plug it back in.
4. Re-set the clock and other settings (autostart, e.g.)
If that doesn't work, then I'm sorry to say that it's toast :=(.
- Mike
Jun 08, 2015 | Cuisinart DCC-1200 Coffee Maker
Can I connect my digital receiver to my grundig ghc 1000 home theater? And how I can make the connection?
That depends on the make and model of the radio, and the available inputs on the GHC1000. Does your radio have a line output socket? If not, you can generally use the headphone socket to source a signal. Then all you'll need is a cable with a 3.5mm stereo plug on one end and two x RCA plugs at the other - easily available at low cost from an electronics store. The RCA plugs go to a free line input on the Grundig amplifier and the 3.5 mm plug goes into the radio's headphone socket. HOWEVER some radios require a DC return path to detect that there is something plugged into the socket. You Grundig cannot provide this, and if your radio needs it, this method will not work. So hopefully your radio will not need it.....
By the way, you will have to experiment with the volume setting on the radio if you decide to try connecting it this way and find that it does work. Set too low there will be insufficient audio to run the Home Theater at reasonable volume, too high and you'll get distorted sound. Trial and error is the way to go, but start with the Grundig's volume control set to a low level and the radio's volume control set about half way - to protect your speakers from potential damage if you accidentally drive them too loud
Oct 08, 2013 | Audio Players & Recorders
I have a 1985 Chevy 350 with an ac delco hei distributor and i have the plug wires crossed up somewhere. I need a diagram to show the correct plug wire placement please. Thanks
This should do it.
You can also do an internet search for a standard 350 Chevy engine.
The firing order is 1-8-4-3-6-5-7-2
The order is the same for engines from the mid 1990s back to the late 1970s.
images?q=tbn:and9gctgooegtkmpd2von7rsnyth6zhjrqslhu5zh4othxp_vwy1j9ss
Jan 16, 2013 | Cars & Trucks
I purchase a Grundig S 350 and purchased the sangean Antenna-60, I don't know where the antenna attaches???
The Sangean ANT-60 comes with an adapter that lets you clamp onto the existing antenna on your S350. Using this adapter and the clip provided will be a good enough connection. The S350 does not come with an external antenna connection port for a 1/8" mini plug antenna so this necessitates the use of that adapter and clip.
Jun 08, 2010 | Grundig S350 AM/FM/SW Radio
Grundig TV Model MFW70-3210/8 dolby going black and white
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. ///
Dec 21, 2017 | Grundig GU19WDT 19 in. LCD TV
Does not run on batteries but runs on AC adapter
hello. tjl001
you should look the socket ac plug and try to plug in and plug out ,the socket maybe crack or the
spring not work. I hope this can fix you trouble.
Jan 13, 2009 | Grundig YB 400PE AM/FM/SW Radio
Grundig sonoclock 420 radio/alarm
Hello Sally,
here is the solution :)
https://dex.grundig.de/GIM/internet/document/GKL0151D.PDF
maybe it doesn´t work try this site and choose
http://www.grundig.de/index.php?id=9
Greets
miieke
Jun 21, 2008 | Grundig Audio Players & Recorders
Clock
Radio can be on or off. 24 hour clock only (11:00pm = 23:00hrs). 2 clocks Time I and Time II. Select one or the other by pressing TIME 1/2 button (shows in display at top center). To set, if it is 23:00hrs, press 2 3 . 0 0, then immediately press TIME 1/2 button.
Nov 11, 2007 | Grundig G4000A FM/AM Radio
Grundig S350 AM/FM/SW Radio Logo
191 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
