Question about Microsoft Xbox 360 Console
Disc drive The disc drive has started to lean down so the system can not open while it's standing what shold i do?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 74 Answers
Put it down. They run very badly if they're upright. You need to put it on the floor flat and if needs be, open the door with a paperclip. You'll need a thicker paperclip and have to turn off the xbox first to avoid breaking the mechanism. Take off the face plate and you'll see 3 small holes below the tray. Push the clip in hard on all 3 til you find the right one. No damage will be done to the non tray opening door holes, so don't worry.
Posted on May 15, 2010
Car is cutting off while driving need to know if the codes that are showing is the reason my car is cutting off, p0500,p1131, p0174
P0500 stands for vehicle speed sensor malfunction
P0174 stands for System to lean (Bank 2) so you proably arent getting enough fuel or spark
P1131 = Insufficient Switching O2 Bank 1 Sensor 1 Sensor/Lean
Sep 25, 2012 | 1999 Ford Contour
The disc draw doesn`t open when i press the open button
standing up or laying down?
when standing they sometimes stick, lay it down and if it still won't open then press down on the casing just above the eject button.
if that doesn't work then the unit will have to be opened, the dvd drive taken apart and completely cleaned.
Nov 15, 2011 | Microsoft Xbox 360 Console
Im sorry for a repeated type question but i was hoping i could get some assistance with my xbox 360 problem.. okay, first the cd tray would not open and i would have to jiggle it on the left side of the...
The best way to resolve this problem is to replace the entire drive - you can get a replacement drive online. Use Google to find several vendors to choose from. It sound like the laser lens is trying to focus but cannot and thus you hear the lens rubbing against the disc - this can ruin many of your valuable games you have recently inserted in the drive. DO NOT INSERT ANYMORE DISC INTO IT!
Dec 21, 2010 | Microsoft Xbox 360 Console
I accidently deleteed the sandisk cruzer 1gigs folders with the formatting software in it it now only holds about 157mb of useable memory space how can i reformat it?
Hi There,
I recommend you insert the SanDisk and go ahead with the OS Disc as though you were going to reformat again. When you get to the opportunity to manage drives, choose the SanDisk and reformat it as FAT32. This shold return it to normal.
Or, after inserting the drive to USB, enter Administrative Tools through Accessories>System Tools from the start menu, choose Disk Management from the menu you will see and reformat from there.
Best Regards,
Selk
Nov 12, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Disc drive
i had the same problem i call the tech repair dude
Mar 20, 2010 | Microsoft Xbox 360 Console
Xbox 360 game compartment wont open
if it's standing straight up, then lay it down. sometimes the drive won't open unless a disc is inside the console. this happens mostly when it's standing straight up. lay it down and it should open. if not, you can take tha face off and stick a paper clip inside the little hole to manually eject the tray.
Nov 01, 2009 | Microsoft Xbox 360 Console
I have a dimensionsC521 that has swallowed my cd disc. It is an awkward cd slide since the cd does not stand upright and so I usually tilt the tower over so it doesn't slip out. Now it slipped out and the...
I suspect this is more a mechanical problem than a power or software problem
I suggest powering down your PC,
Laying it down so the CD draw is flat,
Fashioning yourself a home made cd draw ejector device (otherwise known as a straightened paper clip),
Pressing the paper clip quite firmly into the tiny hole next to the CD Draw (it should unlock and open slightly)
Carefully and gently pulling the CD Draw out just enough to see inside and find out where the disc has got to
Physically maneouvering your whole PC to get the disc back onto the tray where it should be
Then you can either manually pull the CD Draw out and remove the disc or start the PC while it's laid down flat and see if the CD Drive auto closes and begins to spin now the disc is properly seated
If your PC doesn't have the tiny hole on the front of the Drive or if the CD Disc cannot be seen at all or cannot be persuaded back onto the tray then it's time to start opening up your PC case and removing the CD Drive for more attention
- NOTE if your PC is still under warranty Opening the Case may invalidate that warranty, check this before you proceed -
Treat Everything Gently and Good Luck!
Sep 16, 2009 | Dell Dimension C521 PC Desktop
Start up problem
Just power down the computer and remove the disc and boot up again, if it's stuck - power down the system ,unplug the power, then open the case, look at the back of the disc drive and remove the black/red/yellow power connector... then boot it up again. Still have it checked out though , but at least you can work now...
Apr 13, 2009 | Computers & Internet
CD/DVD drive stuck CLOSED and NO pin hole
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
Jan 28, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
New PC not accepting mini DVD-R disc
I've had a look at the Acer Aspire X1200 in a photo and it seems to stand upright with the dvd drive coming out sideways. There is no real groove on the inside of the disc tray to keep the mini DVD-R disc held in place.  There may be a way to remove the stand that holds it upright. Then turn it on the side that you lean it on. That would be the way it would have to sit permenantly by the looks of it. If the stand doesn't come off then I'd suggest just turning it on it's side anyway, not ideal but it will read the disk. I dont think there is anything else you could do to make it read the disc whilst standing up, I'm afraid.
Jan 08, 2009 | Acer Aspire X1200 Desktop PC - Athlon X2...
Microsoft Xbox 360 Console Logo
27 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
