Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
My craftsman lt 1000 lawn tractor will not start. When I turn the key the starter motor spins but the gear will not raise up and engage the flywheel. Do I need a new starter? (18 hp b&s 42 Inch cut) If so where can I obtain the part number and purchase the part ? Thanks.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 251 Answers
Starter motor spins, but does not engage
  1. Check the starter motor for a seized or binding pinion gear.
  2. Remove the flywheel inspection plate and check for a damaged ring gear.
  3. Engine stalls immediately when started
    1. Check the ignition switch condition and operation. The electrical contacts in the run position may be worn or damaged. Try restarting the engine with all electrical accessories in the off position. Sometimes turning the key on an off will help in emergency situations, however once the switch has shown signs of failure, it should be replaced as soon as possible.
    2. Check for loose, corroded, damaged or shorted wires for the ignition system and repair or replace.
    3. Check for manifold vacuum leaks or vacuum hose leakage and repair or replace parts as necessary.
    4. Measure the fuel pump delivery volume and pressure. Low fuel pump pressure can also be noticed as a lack of power when accelerating. Make sure the fuel pump lines are not restricted. The fuel pump output is not adjustable and requires fuel pump replacement to repair.
    5. Check the engine fuel and ignition management system. Inspect the sensor wiring and electrical connectors. A dirty, loose or damaged sensor or control module wire can simulate a failed component.
    6. Check the exhaust system for internal restrictions.
Posted on Jun 07, 2011
My craftsman LT 1000 wouldn't start, it's silent. I changed my battery - still the same.
1. try jumping your mower battery with your car/battery and see if it cranks. If it does, charge your battery. If it doesnt
2. try jumping directly from battery to starter. If that works, its your starter solenoid. If it doesnt,
3. change the starter.
I would need engine model number in order to find your part numbers.
Jun 16, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman lt 1000 lawn tractors starter keeps overheating
check the battery cables bypass them with jumper cables to test them that engine needs alot of amprage
May 13, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Do I need to mix oil with my gas for the lt 1000
Simple, it is seperate. There is no need for a mixture
Jul 29, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Adjusting brake on Craftsman LT 1000 lawn tractor manual
underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
May 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman LT 2000 riding mower
Check the motor of craftsman LT 2000 riding mower
Aug 25, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a Craftsman LT 1000 17.5 hp. replaced the battery and cleaned all the cables but it only will turn over once then seems like the battery is dead but in a minute or so it will turn over 1 time again
Sounds like your starter is weak or either your making poor contact across your solinoid. Try the solinoid first and if that doesn't fix it then try the starter.
Jul 15, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Possible carburetor problem? Mower runs for
i have a lt 1000 2005 when i start it with cold engine it boggs for a minute then it starts to run smoothly please help me
Apr 19, 2009 | Craftsman Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
567 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
