Question about Acer Aspire 5100 Notebook
Vertical stripes then system hangs
Like it says. works for a while then the vertical stripes come in, hdd shuts down, dvd turns off (the sound of laser tray being reset to default position) and the vertical stripes remain. If the 5100 is "cold" then it's ok for about an hour or so but when i try to move it it happens all over again. Reinstall does not help. Bios version 3.10a.
If anyone can help I'd appreciate it.
Thanx
  • 1 more comment
  • Anonymous Mar 30, 2008
    acer aspire powers on some times the the f2 key works sometimes it dont. boots up to checkiing file system on C: then goes to dark blue light blue vertical lines
  • Anonymous Apr 07, 2008
    Just had this happen to me for the first time. Very random, and my computer rebooted just fine. Here's a picture of my pretty lines. Any information would be greatly appreciated.
  • RicoJJ May 08, 2008
    imagine that... sicran19's thing-of-a-jig did the trick... to all of you satisfied acer aspire customers, if the vertical stripes is happening to your 5100, PHYSICALLY REMOVE the broadcom wireless card. silly as it sounds, it is THE solution.
    flip it over, unscrew the covers of mobo and hdd, the wireless card is in the bottom right corner. get rid of it and tidy up the antenna cables (yes, they do come off. just pull a bit more harder). spread the word!
    Problem Solver:
  • 9 Answers
Oi vey, so everyones having a problem with this then?
i came up with an odd solution for the crashing, i find if i kept something frozen underneath the laptop, (where the power goes in) or if the room is a cold temperature, it wouldn't crash at all, i would have very few problems at night because of this (i recommend if using a frozen item, such as a sponge that you keep it wrapped up in something such as a small zip lock bag) i also have little to no problems with it is sitting on top of a cold air vent.
i am wondering how heat plays into all of this, but it really does seem that the warmer it is the more problems tend to occur.
Posted on May 08, 2008
I have a aspire 5100-5840 same thing started happening after
5 month into the purchase. I sent it to acer for repair and they just
reuploaded the OS and sent it back >:-< samething started happening till the laptop was not booting at all ( i was hearing 3 beeps which sounded like a faulty graphic card). I sent the laptop to acer again last week and and got it back today, they had replaced
the mother board and HDD. I think all these laptops have faulty
graphic cards; that's why they are so cheap w/ so many feautures. hope this helps and hope you still have warranty on it.
Posted on May 07, 2008
Do you have a Broadcom wireless card? :D :D :D
This could sound silly, but there's your problem.
Physically remove the card out of your laptop.
The video drivers, the LCD, or anything else are not a problem here.
I had the same problem before. Check the pic hereunder to see my "old" stripes:
http://i69.photobucket.com/albums/i78/sicran19/verticallines.jpg
Posted on Apr 26, 2008
  • 472 Answers
Check the cable to the back of the LCD. If it is moved even a little bit they can dislodge enough to cause this. It will not be able to reset itself until it is powered off then back on.
The cables will normally come loose after the lid is opened and closed so many times. It's not really a fault, but the cables have to be kept to an almost exact length because there is no room for extra long cables in there.
The other place to check is inside the laptop base where the cables connect to the motherboard/video card. They can also become loose over time.
Hope that helps =)
Posted on Apr 11, 2008
SOURCE:
My TV is showing only vertical stripes. Audio is ok
Hi Arquimedes,
It appears to be a Tcon board issue. Tcon boards are repairable at times. Please contact some good TV tech.
Jul 24, 2015 | Televison & Video
Black Vertical Stripe Our Hitachi plasma TV has just started displaying a vertical black stripe about three inches wide right down the middle of the screen. This stripe comes and goes every hour or so,...
try doing white wash feture in options see if u can get it out this way 1st before having to take aprt cheak cables are using old style sumtimes they do get glitch do factory reset thx for using fix ya . nick
Feb 03, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
When turned on there is a dark background with vertical and horizontal stripes
Sounds like you might have corrupted your programming. See if you can do an update online by going to the EasyShare website and searching for updates for your model. You maybe able to download and reinstall the software.
Dec 19, 2014 | Kodak EasyShare Z612 Digital Camera
T.V. picture won't come on ( or sound) only vertical stripes.
first thing you need to do open the back cover to trouble shoot, check burnt parts at vertical section and then turn on the TV check voltage going to vertical IC if present.if voltage is present unplug again then check leak capacitor near the vertical IC also open resistor.
Apr 18, 2011 | Zenith Televison & Video
When i turn it on it has an horizontal blue line in middle of screen then comes on, when shut down it has the colors in the middle in tight formation then suts off. is it the picture tube
the set having blue scteen when the nosignal condition so blue horizontal line due to failure in vertical deflection section and system control detect the vertical delection failure . so system control farce to set to shut down pls repair the vertical section and system should be ok
Aug 26, 2010 | Samsung SlimFit TX-S3082WH 30" TV
Switch on. Picture OK for 3-4 seconds then vertical stripes only
IT NEEDS SERVICING, THROUGH THE CERTAIN HEAT ON THE VERTICAL IC, THERE HAS BEEN DRY JOINTS ..RESOLDER IT, FOR BEST RESULTS TRY TO RESOLDER THE OTHER HEATED PARTS..IT WILL WORK
Oct 13, 2009 | Televison & Video
Pale vertical stripe on black prints
It sounds like the black drum unit needs to be replaced.
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
Blue vertical stripe
The bad news, it sounds like tou have a bad plasma panel.One of the vertical drive arrays are in the process of failing.This part is part of the display panel.
Mar 02, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
1998 TV worth repairing?
sound like a vertical collaspe vertical chip...might be more..the fact you still have sound is good.. not all is lost. but technician will have to determine if further damage has occured
Dec 08, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Acer Aspire 5100 Notebook Logo
336 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
