Question about Garden
Will not operate with choke full open
Must run at half-choke/full throttle. Even then low rpms/velocity .(estimate half power) when i restrict flow with my hand at nozzle end rpms/velocity increase substantially. Suspect fuel filter but unable to find part listed in manual
  • 2,100 Answers
It sounds more like the high speed jet needs to be opened. No engine will run with the choke on. Open it up, find the little screw labeled high or fast, you have 2, one low or slow, If opening it up doesn't work, try closing it, turn it a very little bit at a time to see what it does. Hope this helps.
Posted on May 14, 2010
Is there an adjustment to increase hydraulic power on Komatsu pc35mr-2 mini excavator? Or is there a sensor that is responsible for relationship between engine rpm and hydraulic operation?
you assumption is right
the pump is operating at idle as at full rpms and is controlled by pressure relief valves
When demand for pressure is low the valves will be partially opened and will operate when the pressure is reduced ( ram valve is moved)
Higher rpms maintain the pressure for faster ram operation
I would suggest that you have the system pressure tested by a service centre as it could be a malfunctioning valve (solenoid) or a failing pump
Mar 28, 2015 | Mini Cars & Trucks
95 suzuki 250 quad king, at full throttle it runs at half power, choke seems inop
First make sure your choke circuit is working. May be an indication that your carb needs to be cleaned. I wouldn't replace it yet= clean it. If the choke circuits and the carb check out fine. An unresponsive motor/ carb usually means bad valves or valve timing. Example: it runs rich, spits fuel out the carb no matter how lean you set it. Even with the idle air closed it runs rich... intake valve is not closing or closing late. In that case it needs valves serviced.
Aug 26, 2014 | Motorcycles
Yamaha 5200d it starts and runs 2/3 minutes and shuts down oil is full low oil lite does not light up carb is clean
This generator is equipped with an auto choke. What is likely occurring is as the engine warms up the choke is returning to the normal choke off run position leaning the mixture two lean to maintain operation of the motor.
This is occurring because the residual fuel that was left in the carburetor has evaporated and the gum residue is reducing the fuel flow through the carburetor. When the choke is applied the mixture is rich enough to support running and as the choke returns on its own to the run position the mixture leans out and the generator stalls..
Override the choke when the engine is starting to falter to confirm the problem. Continuing to attempt to run the engine possibly adding a carburetor cleaner additive to the gas will likely return the unit to normal operation.
If attempting to enrich the mixture by applying choke when the engine begins to falter does not work then a fuel flow problem to the carburetor may be the root cause. I would look for a plugged fuel filter or restricted fuel flow from the tank to the carburetor. What is happening is when the unit is at rest the carburetor is filling with gas and as it is running because of a restricted fuel flow the level lowers in the carburetor bowl resulting in a mixture to lean to run.
Jun 01, 2014 | Yamaha Ef4000dfw/5200de/6600de...
My 1996 VF 750 C Magna starts fine with the choke open. After a minute or so as I reduce the choke and try to open the throttle, the engine just stalls out. Cannot seem to get the throttle to control
I think you are mixed up. The choke is usually closed to start a cold engine and opened once the motor warms up. The choke is closed to restrict the air flow and make the mixture richer in fuel. You can't open a choke that's already open. It's stalling because it's starved of fuel. Either a blockage or the fuel pump is not supplying enough gas.
May 06, 2012 | 1996 Honda VF 750 C Magna
Hey. i have a 250cc giovanni, how does the choke work ?
The carb choke is a restriction in the air flow before the point where fuel is added to the air flow. When you set the choke, the throttle plate becomes the air restriction because the "mini" carb system feeds rich air/fuel mix in front (engine side) of the throttle plate. If you set the choke and open the throttle, the "choke" becomes ineffective...Hope this answers your question.
Jul 12, 2011 | Indian Cat 125D Motorcycles
Hi - I have a Toro Super Recycler # 20042. Been running great for a long time till today. Now it seems that the engine runs about half as fast as it used to. From what I can tell there are no adjustment...
since you have the cover off, clean and spray the governor linkage with WD40, Often there is a lot of
dirt and grass restricting the movement or airflow to the plastic vane that controls the throttle,this has to move freely in order to engine speed, be sure to clean the inside of the cover,always check the flywheel shear pin, if it is bent even slightly, replace it.this pin keeps the engine in time, therefore if the pin is not perfect the timing suffers, poor operation, hard starting etc
One other thing to check is the choke operation, does it open fully after the engine starts?clean with carb cleaner.
Jul 04, 2011 | Toro Power Lawn Mower
Engine will start but only run at choke or half choke and low throttle sputteres and or dies if you try to increase to full throttle and dies if you take off choke
Check fuel pump delivery for adequate flow. If when choke enrichment is applied and it runs, then dies when choke is off, fuel flow is inadequate and needs choke enrichment to compensate. Also, if engine dies or chokes when increasing rpms, this will be a symptom of too little fuel. Check fuel flow at pump, then, if flow is good, check for carb blockage, unscrew the jet and inspect, check the operation of the solenoid at the bottom of the bowl, it has a wire attached to it. Trace that wire to where it plugs in, unplug it and touch it to the positive pole of the battery, it should retract. If not you need a new solenoid that has the job of metering in gas to the inner bowl below the jet assembly.
Feb 10, 2011 | V-Twin Horizontal OHV Engine with Electric...
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
I have a Coleman 1850 that only seems to run smooth when the choke is set at half way. When I fully open the choke the engine revs up and down and seems to want to stall.
A fuel starvation problem.
Pull the fuel line off the carb..........the flow should be strong from the tank.
If not check for a blocked filter or fuel switch not allowing full flow.
If you do have a good fuel flow.......the restriction is in the carb.......a good cleaning will be next.
Usually it is the main jet that is semi clogged from storing the engine with out shutting off the fuel and running the carb dry.
After cleaning make sure all fuel in the tank is fresh.
Sep 12, 2009 | Coleman Electrical Supplies
2004 Honda Shadow Aero stalls
sounds like bad fuel try adding some fuel stabilizer.
Jul 19, 2009 | 2004 Honda VT 750 Shadow Aero
Garden Logo
354 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
