I have a 42 inch phillips model 42pfl7662d 1080dp lcd tv. today it started making crackling noises at the rear right hand side, then it automatically switches itself off, and then on again after a minute or so, then off again and the same procedure again then finally into standy by mode, please can anyone with technical knowledge shed some light??
  • 8,617 Answers
Sound s like the HV generator (flyback) This is repairable with a new flyback if that is indeed whats happening. Take the back off and dont touch anything but try powering up the set and see if the noise is coming from a part that looks like this with 4I have a 42 inch - 533b6a8.jpg big red wire coming from
Posted on Mar 30, 2008
Phillips 40PFL3505D 42 inch tv stuck in channel search mode , continuous cycle
You can try to go back to factory settings.
After that disconnect the power from the TV and wait for about an or two hours. Then put on the power and try to make the installation complete from the start.
Regards GJ
May 25, 2014 | Philips 42PFL5332D 42 in. LCD Television
My 42 inch lcd vizio tv flashes like a stobe lite after a minute of powering it on then goes black what can i do
That sounds like an inverter problem. Check the capacitors on the inverter boards. There will be two on each board. The master inverter will be on the far left side, and the slave will be on the far right side. You will have to remove the metal covers over the inverter boards. Should be 4 small phillips head screws. If the capacitors have bulging tops, replace them.
Jan 15, 2013 | Vizio VX42L 42 in. LCD TV
Phillips lcd tv model 42pfl7662d/05 set turns on have sound but no picture
Hi.
The problem is the inverter, the psu, or the main board. Repair is done checking power to the inverter.
Please let me know if you need more info on the problem.
Regards.
Ginko.
Mar 08, 2011 | Philips Televison & Video
Philips 42PFL7422D/37 42-Inch 1080p LCD HDTV Picture went out but still have sound. Any tips on how to fix it?
If the backlight of the LCD-panel does not function, (no picture) then Master and/or Slave inverter are defective. Inverter boards are screwed to both sides of the LCD display, if they have revision 1.2 boards then they will need replaced with revision 1.3 boards.
Feb 16, 2011 | Philips 42PFL7422D 42 in. LCD TV
TV makes very loud crackling noise
crackling in the speakers of 42"flat screen tv
Jul 20, 2010 | LG 42LC2D 42 in. LCD HDTV
Philips 42PFL7662D problem
I come across this every day with LCD Tvs.What it is, is dust between the layers of the LCD. When dust particles settle behind the front layer of the LCD, and the LCD is pressed i.e when cleaned, the layers can be pushed together, resulting in a shadowy streak. If the LCD is stripped and cleaned it will be ok.
Feb 24, 2010 | Philips Televison & Video
Crackling Sound
I just bought a used 60 inch rear projection tv. The picture is fine except I have a crackling sound coming from the front of the tv also. What's the deal?
Jan 16, 2008 | LG RU-44SZ51D 44" Rear Projection...
Crackling noise from tv
That crackling noise has nothing to do with the television and everything to do with your antenna. It is merely signal breakdown, when you get signal interference with analogue tv you get snow, with digital you get little squares on the screen and/or sound breaking and cutting in and out, get a licensed antenna repairer to come out check your signal strength as you may need a booster or your antenna could just be a few degrees off....
Dec 08, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony 42" LCD Projection TV Model # KDF-42WE655
Most likely the noises are from the plastic cabinet expanding and contracting.
Apr 16, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Televison & Video Logo
143 people viewed this question
Top Televison & Video Experts
