Question about AOpen AX4SPE-N (91.8AT10.701) Motherboard
Removal of agp card
Is there a trick to removing the card like a clip or should it just pop out
  • 236 Answers
It should just pop out.. Don't force it too hard though, or bend it..
I find the easiest way to remove a card is by pushing up first on the back of the card (where is monitor outputs are) on the bent metal part that where the screw goes.. It helps get the card unseated without pulling on the board itself.
Posted on Mar 30, 2008
  • Dave MacPhee
    Dave MacPhee Mar 30, 2008
    Hrmm.. Didn't see the clip on the board..
    President:
  • 2,351 Answers
Your right, there is a little pice of plastic located near the back bottom of the AGP card. (some colored light blue), just push it towards the bottom of the case as you pull up on the card. That's it.
Mike
My memory card will not stay down in my Kodak easy share z950 how can i fix it so it will stay down
There is a little spring assembly in there that pops the card out when you press a button or something. But if the button is stuck or not working the card will always pop out! If you remove the spring that will do the trick - to remove card in future you use tweezers like I do with my Garmin! Does the trick and works fine!!!!!!!!!!
Mar 07, 2016 | Kodak EasyShare Cameras
How to reattach driver side side mirror to car
there is no limit to damage
is it dmaged?
if not, the side card must come off.
remove knobs, remove side cards on door, and see mounts.
you tube has like 1000 of vids showing card romoval, most
cars are same ,
my suz, you pull from bottom up, pop, pop, goes the friction rivets.
then the rag trick for the knob (manual windows) clip
if electric, see screws, some are hidden.
my 04 has hidden screws behind the door lever plate.
and in door arm rest.
you could just RTM.
http://www.scantool.net/software/alldata-diy-1-month-subscription.html
Aug 04, 2013 | 1996 Geo Prizm
Jimmy 1995 JimmyLift gate will not open. I can hear the mechanism trying to work. I looked up the instruction in a repair manual. It tell me to remove the rug on the tailgate to expose an access hole...
The rug has a cardboard backing with screws and plastic clips holding it on. First remove all the screws you can find in the trim. You will need a tool like a pickle fork to remove the plastic clips without damaging the card board backing (door card removal tool). The trick here is to pull the clips out of the metal and not the cardboard so not to damage it. Start at the top by the window and it is easier to see the clips with the top loose. I have used my wifes two pronged weed puller with no problems. When you get it all apart you will see that plastic clips hold the rods to the latch on each side as well as to the release mechanism. If the clips are bad replace them. It is important not to slam the hatch or they will pop off again.
Nov 20, 2010 | 1995 GMC Jimmy
Sim card location on apple iphone 3g
On the top of your device you will find the SIM tray. There, you'll see a little hole. If you have the SIM eject tool, insert its end firmly into the hole, until the SIM tray pops up (a paper clip would also do the trick, instead of the SIM eject tool). Remove the SIM tray, place your SIM card into it (aligning the angled corner), and carefully place the SIM tray (along with the SIM card) back to its place.
Hope it works for you.
Cheers! Carlos
May 11, 2010 | Apple iPhone 3G
Remove Dell Dimension 2400 Cover - I have been to the Dell site and read the documentation. But opening the cover seems to require two people - or three hands! Are there any tricks of the trade? Thanks!
This is a rather simple case face to remove.
Remove the side cover and place the unit on its side. hold the bottom of the face with 1 hand and pull gently while popping the 4 clips inside the case on the bottom end.
After you have done this there should be 1 on the side you can pop then there is a metal flexible peice at the top, pressing that down will relieve the top clip.
Place the case upright while holding the face out, after this the case will pop off to the opposite side of the case that the case opening is on.
Feb 11, 2010 | Dell Dimension 2400 PC Desktop
Physically remove nvidia 8600gt video card from
The video card is in the AGP slot on the motherboard.
There will be a plastic clip at the back of the slot that needs to be pressed to release the back of the graphics card.
When you insert the new graphics card this clip should automatically lock in the new card.
Nov 02, 2009 | Jaton NVIDIA GEFORCE 9400GT PCI, CTLRDDR2...
Have gforce4 ti video card NO PICTURE of any kind screen says no signal detected
The GeForce4 Ti has two rear ports. 1 HDMI and 1 VGA. Try plugging into each. Video signal should be sending out of one of the ports. If neither port is sending out signal than you'll need to trick the bios.
Suggest you remove the Gforce4 Ti AGP card from the MB so you can regain video display and change the settings within the bios. Once you have display, enter the bios menu. Do you have your manual? Enter bios menu by pressing the "Delete" key every 2 seconds until the bios menu loads. Open, Integrated Peripherals, see top of page 3-11. Set Primary Graphic's Adapter to: [AGP]. Than go to the top of page 3-10. Change the AGP Aperture Size to as low as possible or to: [Disabled] "preferred".
AGP 8x Support set to: [Enabled]. Save your settings and exit the bios. The system will restart. Press and hold the power on / off button until your system shuts off. Install your GeForce4 Ti AGP video card. Double check your video card! Some NVIDIA cards need external power above what the AGP slot can provides. Some use a power connector like the floppy drive uses. Other look just like a hard disk drive power connector: 4-pin Molex. If none is found don’t worry about it.
Cheers!
Mike
Oct 22, 2009 | MSI K7N2 Delta2 Platinum Motherboard
I got beeps on my pc
1 Long beep and 2 Short is Graphics related.
Change GFX card if PCI/AGP
or if onboard install a GFX card and see what happens (with RAM and CPU reinstalled)
if it still bleeps with new card then remove power from PSU, remove BIOS batt and wait 10 mins (or do the bios jumper trick)
(still with new card installed)
just a thought... its always best to remove Data cables from board aswell as power from the devices (hdd,odd etc)
let me know how you get on...
Matt
Dec 08, 2008 | ASUS P5S800-VM Motherboard
RC410M
Usually "on board graphic card" reffers to an internal video graphics circuit intergrated into the motherboard. If your monitor's video cable plugs into a separate card, then you can replace the card. If there is no video card, then only option is to replace motherboard. Might be cheaper to buy new computer.
Oct 16, 2008 | Computers & Internet
AOpen AX4SPE-N (91.8AT10.701) Motherboard Logo
27 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
