Question about Mueller Industries No.104-119 12" 3/4MIP Ff Sillcock
Muellet sillcock - two units-one no water flow at all; one unit very little flow-- less then one year old -- this seems to be a common problem
  • 623 Answers
Either the rubber seal that shuts off the water is stuck or jammed sideways, or the sillcocks are corroded internally, which with everything being made in China is no surprise.
Posted on May 14, 2010
Flooded floor
yes I agree that you should not have layed it down , please wait for 48 hrs now to run it again with unit in upright position
next id go over unit and look all all hose's seems a bit of mold builds up inside of these very often , Wight id always say to give it a little spritz of bleach water every 30-60 days or so to clean it out and keep your pipes flowing freely
one of those little bottles of compressed air for computer cleaning goes 4 miles to cleaning out little holes and such on these things
Jul 26, 2015 | Danby Dehumidifiers
I have a John Lewis baby monitor, which is less than a year old. The parent unit is unable to link to the baby unit. Batteries seem to be in working order. Thanks. Jackie
Less than a year old = go for a warranty repair or replace, Use the warranty while you can as you'll end up with either a working or new unit.
Jan 07, 2011 | Computers & Internet
My Tefal Classic Express Steam Generator Iron is less than 1 year old. I switched it on earlier this evening and although the base unit power lights etc are on and the water tank is full, when I press the...
AS the appliance is less than a year old and you say it is a common problem, take it back under warranty to the supplier and get them to replace or repair it free of charge. It is your right after all, if you are within Europe that is.
Hope that helps.
Oct 28, 2010 | Microwave Ovens
The unit starts for a few sec then shuts down.ptg 74.
A couple of things could be happening.
1. There needs to be more water flow at the faucet, a minimum of .75 gallons per minute. Low flow and pressure balance faucets and aerators will not work well with tank-less water heaters. You need all the flow you can get.
2. The flame sensor in the main control unit is week, this is a common issue with your water heater.
Clean the unit to establish adequate water flow. Remove all faucet aerators and turn the faucets on to activate the unit. If you still get the on and off problem you need to call the company for a new flame sensor and/or control valve.
Sep 02, 2010 | Rheem Paloma Tankless Water Heaters...
Just stop working less than A YEAR OLD.
Seems to be a common problem for the looks of it. Mine was only a month old. Defect maybe?
Jun 08, 2010 | Danby DMW799 Microwave Oven
Model PTG-42PVN
According to the symtoms...sounds like you have a problem with the flow control valve. If less than 3 yrs old, contact Rheem Customer Support at (800-432-8373) and they can an authorized tech in your area to service the unit.
If the unit is out of warranty, I reccommend you still call customer support to find a local technician. Unless you're highly technical/mechanical, this is not a problem you should attempt yourself.
Thanks for trying Fixya.com
Mike...
Jan 30, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Our rinnai tankless water heater is a year old and we have just started noticing temperature fluctuations when in the shower; any ideas.
Possible flow switch problem, debris in the filter, bypass valve issue or water sensor. These are pretty complicated little units so I suggest calling your contractor. The unit may still be under warranty!
Nov 11, 2009 | Rinnai Toyostove Direct Vent Heater:...
No cool air comes out of our unit even though it's running. System is about 2 years old-a little less. Filter regularly changed. The pan underneath is also full of water.
are the unit is upflow (on the closed) or horizontal (most like it on the attic)
if is horizontal and the drain pan is full seems the main drain is clogged can you blow air thru drain?  make sure you dont have a flow swith on the drain pan that prevent the condenser to come on
Sep 27, 2009 | Carrier Heating & Cooling
My water dispenser flows very slowly. The unit is
Check for clogged output valve. Second the filter candles require an annual change as they also get clogged from filtering water.
Thanks for using fixya
proton
Aug 14, 2009 | Refrigerators
Mueller Industries No.104-119 12" 3/4MIP Ff Sillcock Logo
919 people viewed this question
Top Mueller Industries Welding Tools Experts
Bill Boyd
Are you a Mueller Industries Welding Tool Expert? Answer questions, earn points and help others
