Question about Canon imageRUNNER 5000 Copier
What is E000584-0001
My IR5000 gives error code E000584-0001 each time I connect the sorter. What is the problem?
  • 23 Answers
M8 ( 2nd feed moter) or MS4 (limit sensor) is bad. Unless you know how to trouble shoot this finisher. There is no quick fix I could help you with.
Posted on May 17, 2010
2 Suggested Answers
  • 109 Answers
SOURCE: What is E000584-0001
E584
Main Cause The shutter open sensor (PI5) is faulty. The safety area detecting switch
(MS3) is faulty. The shutter closed detecting switch (MS4) is faulty. The
No. 2 feed motor (M8) is faulty. The finisher controller PCB is faulty.
Mode of
Detection
0001 The shutter closed detecting switch does not turn on when the No.
2 feed motor has been rotated CCW for 1 sec or more.
0002 The shutter open sensor does not turn on when the No. 2 feed motor
has been rotated CCW for 1 sec.
0003 While the tray lift motor is in operation, the shutter closed detecting
switch is found to be off when the tray 1/2 is at OFF position
of the safety area detecting switch.
Posted on Mar 21, 2010
Lanier 5635 Sorter
Under user tools, system settings make all prints, copies to come out in internal tray, the front and rear covers have to come off to remove screw 1 each side the SC code is shift tray motor error
Dec 18, 2013 | Lanier Office Equipment & Supplies
It says error code C0b63 what does it mean
All Cob codes on this series of Minolta copiers pertain to the sorter. Most all of the time you can simply open and close the sorter to reset the code. By open and then close I mean that the sorter must be pulled away from the copier then closed back.
Make sure there is nothing interfering with the movement of the sorter bins.
If opening/closing does not reset the code or if the code comes right back after resetting then the sorter will need service as dis-assembly/repair/re-assembly will be required. You can also unplug the large connector going from the sorter to the machine and use the copier without the sorter. If you have a 10 bin sorter that "hangs" from the side of the machine then you can leave the sorter attached and it will work fine unplugged. If you have the 20 bin sorter that sits on the floor then the sorter will have to be moved away from the copier if unplugged to prevent the machine from jamming. If you unplug the sorter be sure to turn the copiers power off before disconnecting the sorter.
Good Luck and Thank You for using Fixya.
WheatlandService
Nov 11, 2010 | Minolta EP4000/5000 CS/PRO Copier
Error c0b31. can someone tell me how to fix this error?
The code to refer the staple sorter unit malfunction.Check the sorter motors and sensorrs,clean it and disconnect and connect the sorter plug on the copier machine for reset the problem.If to work to disconnect mode your problem in the sorter unit.
Jul 19, 2010 | Minolta EP4000/5000 CS/PRO Copier
E584
Mode of
Detection
Mar 20, 2010 | Canon imageRUNNER 5000 Copier
Error Code 00532-0002 (Canon Copier IR5000)
The problem is in the stapler unit which is in the sorter unit. If you are tech savey then pull it out and removed all of the bent staples.
Dec 15, 2009 | Canon Office Equipment & Supplies
Error f1
How do you do. You should check join from the main of the charge to device сортера.If connections is checked and where are no mistakes in join no pay attention to mechanical possible damages, findings scrap papers and stranger subject in sorter device. Recall, pr what circumstance appeared the fault.Error code F1 for sharp copiers sf 2020.2030 Sub code 00: Communication error between main board and sorter. Sub code 02: Sorter transport motor drive.
Sep 23, 2009 | Sharp SF 2020 Copier
Sharp copier model SF2530 F1 flasing and copier
Hello sir; F-1 is sorter problem, did you connect sorter with machine, turn power off and check th connecter .
May 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error code E522. How to fix this?
You have an issue with your staple finisher, probably need to inspect the stapler unit itself to make sure nothing is jammed in it and it moves freely. If you can't clear the error then most likely the unit is defective.
Hope this helps,
TankMurdock
Apr 24, 2009 | Canon NP 6551 Black and White Copier
Serice code 792
E721 Sorter stapler bin lift sensor E722 Sorter stapler jogger sensor E723 Sorter stapler grip sensor E792 Sorter stapler error
Mar 20, 2009 | Office Equipment & Supplies
Np6545- erroe code e522
Hello Good Day amazingfirst! you problem for Canon NP-6545 error code E522 according to my Service Manual the problem is the Sorter push bar motor. try to check the sorter motor, add grease if needed so. just focus on the sorter motor ok! there is no need to reset the error code just on and off the machine and it will automatic reset the error code but make sure that the sorter motor will works ok!
Christopher
Jul 15, 2008 | Canon NP 6545 Copier
Canon imageRUNNER 5000 Copier Logo
483 people viewed this question
old marine
old marine
