Question about GE PFS22SBSSS Stainless Steel French Door Refrigerator
GE PFS22MISBBB freezer not cold enough. Temp won't reset.
This is a 2 year old french door, bottom freezer refrig. I noticed that:
(1) the ice holder had a lot of water in the bottom, with the ice frozen together;
(2) temp setting for freezer is @ 19 deg vs recommended 0 deg (fridge part proper @ 32 deg);
(3) resetting temp to 0, it still reverts to 19 deg.; and
(4) the main housing has warm spots on right & left sides just behind the drawer front for the freezer. The comparable strips for the fridge part are cool.
I slid the whole unit out and took off the aluminum cover over the compressor motor and coils in back -- which are hot.
Can't find the manual at present. What to do?
Am I simply not resetting the temp properly?
  • 3 more comments
  • someconcerns Mar 30, 2008
    I also noticed the fan by the coils at the back is not turning. Now, the display of the temp settings is not lit up, tho it beeps when I press one of the buttons.
    I put a table fan where it could blow on the coils in the back, running it overnight. The stuff in the freezer is now rock hard, the temperature display is back on and the perimeter of the housing next to the freezer drawer is now cold, instead of hot. The built-in fan still is inoperative.
    Does this mean it's simply the fan or are there some control electronics regulating the fan which are bad?
  • someconcerns Apr 02, 2008
    The repair guy who came out said Dawnn is right. We will see for sure when he comes back with the new control board and fan. Thank you Dawnn!!
  • roeogrady Jun 11, 2008
    Please help same problems freezer gets very warm 16-19 deg should be 0 deg, also very hot in front by freezer draw and side of fridge draw.
    Pulled out fridge to clean, still clean, but fan not turning. Do I just replace fan? Is that the problem?
  • Anonymous Mar 21, 2014
    new unit runs almost constantly, doors are fully closed, temps indicated at 0 in freezer and 40 in fridge. this is side by side with water and ice in the door.
  • 109 Answers
Replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Posted on Mar 31, 2008
  • CHRIS KLINGER Apr 03, 2008
    you're very welcome, glad everything is o.k. now.
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
Water leaking into bottom of refrigerator section
Make sure you dry everything in the freezer when you have the door open and remove ice. It won't be a leak it will simply be the warm air inside the freezer that has turned into condensation. Double check the seal around the door to see if it curled up as that could be letting warm in and cold out giving same results.
Mar 02, 2012 | GE Profile PFSS6PKX Bottom Freezer French...
Items in refrig are freezing when they're not supposed to.
thermostat has failed i'd say..its not turning off at the requested temp.
Jul 24, 2010 | GE Profile PGSS5PJXSS Stainless Steel...
My model is ARB 1914 CC nine years old.
your "damper vent door" located between the refrigerator and freezer compartments is frozen open or the cold adjustment contron in the refrige is bad and not powering the door as you change the temp set for the refrige and leaving it open,if the door is frozen from ice/frost just de-ice it with a hair dryer and then set the temp adjust and see if it opens and closes with any adjustment
Apr 03, 2010 | Amana ABB1927DE Bottom Freezer...
Bottom freezer temperature rises as high as 35 degrees and drops only to a low of 15 degrees continually. ongoing for a month now. french doors fridge now has temp. fluxes within this past week. temp. goes...
check the defrost thermostat , and any temp sensor that can determine the freezer temperature.
If this fridge temperature is electronically controlled, the freezer control board must also be tested.
Click here to get all parts and diagrams for this fridge.
Regards.
Jul 09, 2009 | GE Profile PFS22MBW French Door...
Roaring sound
I have had the same issues. I have owned my LFX25960 for 18 months. All the cooling, noise, and condensation problems are related to 2 fans. One for the freezer/refrigerator compartments and One for the Ice Maker. The fans, apparently, are not sufficient to move enough air through the coils located behind a plastic panel in the freezer compartment. The part numbers for my fans are 1. Ice Maker 4681JB1029E and Refrig/Freezer 4681JK1004E. It is not impossible, but fairly difficult to replace them yourself. You have to remove the large slide out freezer drawer and glides. Then work the back freezer panel loose from the bottom. Be careful not to break it. It is plastic.
Routine maintenance: Pull the refrig out from the wall and blow-out the coils and fan located on the lower right rear. You might find it easier to do this by removing the cover on the lower, back of the refrig.
Apr 17, 2009 | LG LFX25960ST Stainless Steel French Door...
Kitchenaid ice maker not making ice
first check the tube running to the ice maker where the water flows in see if it is frozen if not take the cover off the ice maker front and see if the little tabs in the middle of the gear is broken there are two one might be broken off
Mar 30, 2009 | Refrigerators
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Fridge on top of freezer is not chilling
if you have a french door (also known as bottom mount, freezer on bottom) and your fridge sections(cold air blows from freezer to refrig) is not cooling try this
1. ensure you hear the fan running, its it not, thats it(most likely fan motor
IF fan is running check these things
1. ensure refrig section light shuts off by holding down the switch
2. ensure door shuts
3. clean conderser coils (usually accessed from front through base grille)
4. check for icing in vents, freezer section contain them at top or back, and for a bottom mount the refrig sections vents are under your BIG drawer. if iced try a hair dryer from distance. or empty food into another fridge unplug open doors, and plug back in two days later this should defrost all ice build up
May 02, 2008 | Refrigerators
Open Questions:
See all GE PFS22SBSSS Stainless Steel French Door Questions
GE PFS22SBSSS Stainless Steel French Door Refrigerator Logo
1,040 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
