Question about Cameras
Problems with my Sony cybershot Dsc-s600
My digital camera suddenly stopped working. When I turn it on it beeps and on the screen it says: "Turn the power off and on again".
When I do so it does the same thing over again.
I also noticed that when I turn it off the lens cover does not close over the lens. It makes a little movement like it tries to but it doesn't.
Any help I can get I am grateful for!
Ingrid
  • 2 more comments
  • Pacis Mar 30, 2008
    Ok. Where do I start? Do I have to open the camera? there's 2 small screws at the bottom.
    If I can get it open I suppose I should look where the lens is, correct?
    Ok. I got it open and as I pulled the two parts apart the lens cover closed. I see no damaged gears... I blew into the camera and now I am trying to close it... which is proving to be a doozie of a job.
    When I get this done I can tell you if it worked or not. If it doesn't work I think I will just buy a new one.
    It is not working because the lens juts out... Probably the mechanism that makes the lens go back inside is not working.
    Is this repairable?
    Thanks for your help.
    Ingrid
    :-) I understand about the ****
    I think I will go ahead and get a new one. I saw on the internet that a new cybershot costs about 120. That isn't so bad.
    Anyways, thanks ALOT for your help!
    Ingrid
  • 3,037 Answers
The mechanical part that is trying to close the lens cover is having a problem
Possibly
1. a lodged piece of foreign material
2. A broken piece within the camera is interfering
3. A piece in the camera that helps control the lens or another piece by the lens is out of place
Please check this out if you are comfortable doing so and let me know what comes of it
Thank you
Posted on Mar 30, 2008
  • 5 more comments
  • Benjamin Patri
    Benjamin Patri Mar 30, 2008
    you could also first try forcing the cover to close, but be careful not to break it, this could correct it right away
  • Benjamin Patri
    There is a motor assembly that is part of the lens assembly in the
    camera. Inside this motor assembly there are a few custom gears that
    are hard to find. When a gear gets damaged, the camera is able to
    detect the motor spinning and monitor that the lens is not moving. This
    causes that error message to display on the screen.
    Depending on the extent of the damage of the gear and which gear
    broke (their are two typical ones, which are replaceable), some users
    may be able to get passed this occasionally. This can occur if only 1
    tooth of the gear is broke. Eventually the teeth next to the broken
    tooth will break because of how the gears are connected to each other.
    This usually can be noticed by a grinding noise when you turn on the
    camera. If all you hear is a motor humming, then one of the gears is
    damaged as well.
    Unfortunately, the fix depends on how the gears where damaged. If
    the gears were damaged because the camera was dropped on its lens, it
    could be possible that the lens itself is now crooked and even
    replacing the gears will not fix the problem (the lens will physically
    get stuck and redamage the replacement gears). If the gears broke over
    normal use (which is what happen to me), they can be replaced and all
    should work again.
  • Benjamin Patri
    If it is a piece of sand or something else small, you can first try blowing it out with a can of compressed air or gently bumping the camera a little otherwise the above problem is common also with this camera
  • Benjamin Patri
    I would try to first move the lens cover back
    if this doesn't work then I would try a can of compressed air and gently bumping it even though moving the cover may dislodge any piece first.
    Otherwise I would open the camera by unscrewing the screws that you mentioned and yes should should look where the lens is, mainly around the motor and gears that control the lens cover
  • Benjamin Patri
    It is repairable but will be a pain in the **** because of how small the parts are, if you want to repair it I will help you with what I can, but if you are having too much trouble, new cameras aren't too expensive anymore and if you can't fix it and still want to keep it, a camera repair shop should be able to help you out
  • Benjamin Patri
    sorry about the ****, I was try to express what I was trying to say
    Let me know what you plan to do
  • Benjamin Patri
    no problem, have a good day
I have a sony cybershot and the backlight wont turn on
When i turn on my sony cybershot the lens keeps going in and out and it stops and on the screen it says turn off and on again but it doesn't work
Jan 02, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Is there any way to turn off the shutter sound on a sony cybershot camera?
Go through the system menu of your camera. Though I don't know the cybershot: on all cameras I had and have there was / is a menu item "Shutter sound on/off"
Sep 24, 2009 | Sony Cyber-shot DSC-S600 Digital Camera
Stuck power button on my Sony cybershot dsc-s600
Hi!
Yes, power buttons do break on these cameras. Contact your local Sony service center and see how much will it cost to replace the top panel. If they ask too much, feel free to contact me at toms.safranovs@gmail.com
I work in a Sony service center.
Tom
Jul 19, 2009 | Sony Cyber-shot DSC-S600 Digital Camera
Sony digi cam dsc-s600 my video screen too small
Go to Menu and Initialize your DSC-S600 camera. Problem will resolve.
Oct 22, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Sony DSC-S600
If you have a memory card in the camera, take it out before turning the camera on
Aug 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
DSC-W50 sony cybershot
I had the same problem with my DSC-W55. I actually just called the customer service number on the sony website and they told me how to solve the problem.
- Take your battery out
- Press and hold the power button for 60 seconds
- Re enter your battery
- Voila.. it should work when you turn it on. Mine did.
Nov 19, 2007 | Sony Cybershot S650 Digital Camera
Format error
Before buying a new memory card, try to use your card in another camera. When you say you tried to format it through a card readr, do you mean that the card reader was connected to your PC?
Aug 19, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Hi, here is a temporary solution that might work for you as it did for me:
1: turn on the camera in picture/movie review mode
2: turn the screen off (not the camera)
3: change from review picture/movie mode to take picture/movie mode
4: turn the screen back on.
You should now be able to take pictures and record.
Hope this is of some help.
Apr 09, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Cameras Logo
64 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
