Question about Belkin (F5D5010) (F5D5010AU) Network Adapter
Windows xp identifies Belkin f5d5010 Network card as a generic ethernet controller and is unable to find a driver to install properly this adapter
  • Belkin Master
  • 7,733 Answers
If you find that you can not connect to a wireless base station (such as Apple's Airport) because of issues with the configuration software provided by your wireless adapter's manufacturer. You may wish to uninstall that software (but keep the drivers) and use XP's native support for wireless networking.
In order to do this you may need to turn on XP's wireless zero configuration.
Start -> Run
Type in services.msc
zwc001.gif Click the OK button, which will bring up tWindows XP identifies Belkin f5d5010 Network card - zwc002.gifng dialogue.
zwc002.gif You may want to maximise the screen. Scroll down to Wireless Zero Configuration Windows XP identifies Belkin f5d5010 Network card - zwc003.gif and select it.
zwc003.gif You now have the option to StartWindows XP identifies Belkin f5d5010 Network card - zwc004.gifce.
You also need to change the Startup Type from Manual to Automatic
Action -> Properties
zwc004.gif Click OK.
You can now use XP to manage your wireless connection.
Posted on Apr 13, 2013
2 Suggested Answers
etaf
  • 779 Answers
SOURCE: Windows XP identifies Belkin f5d5010 Network card
the drivers are available here - select the version you have and load these drivers http://en-us-support.belkin.com/app/answers/detail/a_id/543/kw/f5d5010/p/182,183,189,191/r_id/166
Posted on Mar 20, 2010
Acquiring network address xp
You must have at least the date right and the time otherwise you get this response. Set the time and date on your computer to solve this issue. Let me know if this works.
Dec 05, 2013 | Belkin (F5D7000) 802.11g/b Wireless...
My Dell desktop using Windows XP can't connect to my Belkin 5720 router but my laptop still works?
This sounds like a hardware failure, but just in case go to your computer Control Panel-Network Connections(Network and Sharing Center for Vista and above), and check your Network adapter settings. If your Network card is not showing, you may have a driver issue, or a bad NIC (Network Interface Card). It shouldn't matter that your router says" wireless hardware not detected", because you are hardwired from the computer to the router. I would check to see if you may have turned off, or blocked Ethernet connections on your router, I would then change my Cat5 (Ethernet) cable, and finally open the desktop and change out the NIC (Network Interface Card).
Mar 24, 2012 | Belkin Computers & Internet
My Belkin USB 10/100 Ethernet adapter is detecting as a buetooth device when I connect to my laptop... I am using Windows XP as an operating system. I guess WIDCOMM in windows is causing that...
Wireless Zero configuration is a utility that connects your computer to a wireless network.
If Wireless Zero configuration is not enabled, the following message will appear: "Windows cannot configure this wireless connection."
Note: If you have the Belkin utility installed, you'll need to change the Program Choice in the Options tab so the Windows XP Utility is selected.
Setup steps:
  1. Go to the XP Start menu and select Control Panel.
  2. Change the view to Classic View.
  3. Double-click Administrative Tools.
  4. Double-click Services.
  5. Find Wireless Zero Configuration within the Services list.
  6. Right-click Windows Zero Configuration and select Properties.
  7. Select Automatic from the drop-down menu next to Startup type.
  8. Click Apply and restart your computer.
Jun 06, 2011 | Belkin Ethernet Adapter F5D5050 Network...
F5d5050 Belkin USB 10/100 Ethernet Adaptor - Does it work with Windows 7 64 bit OS? I have spent hours trying to install a Swann and a Digitech product but none seem to work with the above OS. Any...
You cannot install this adapter in a Win 7 computer because the drivers are not compatible with Win 7.
So far Belkin haven't updated the drivers for win 7 OS. The latest drivers for this adapter is compatible only with
" Windows 98SE, Windows Me, Windows 2000, Windows XP 32-bit, Windows Vista 32-bit "
Click here to see the belkin compatible drivers in the website.
With Regards,
Prema.
Jan 06, 2011 | Belkin Ethernet Adapter F5D5050 Network...
Windows XP identifies Belkin f5d5010 Network card as a generic ethernet controller and is unable to find a driver to install properly this adapter
Mar 20, 2010 | Belkin (F5D5010) (F5D5010AU) Network...
I reinstalled Windows XP to my computer and now i cant get the internet. There is a yellow question mark and exlmation point next to Ethernet Controller and it has a code 28 error.
You should have had 2 cds that came with your computer. The 2nd one has all the drivers on it. Install the drivers and your problem will go away.
Nov 19, 2009 | Microsoft Windows XP Professional
I need a ethernet controller driver for xp so i can get on the web
There's a lot of Ethernet controller driver for xp on the web, please identify which one and model to provide the exact driver for your Windows XP.
Sep 29, 2009 | Sun Micro QUAD ETHERNET CONTROLLER Micro...
Need driver for airlink 802.11g ethernet controller.
1. Go here: http://www.airlinkplus.com/downloads.htm2. Click on the device you have3. Download and install the Windows XP drivers
Regards,AbdielPC repair fort lauderdale
Apr 12, 2009 | Belkin (F5D7010) 802.11a, 802.11g/b...
Ethernet driver
For dwayne12, on the installation CD of XP, you must have the driver.
Jun 15, 2008 | Belkin (F5D7010) 802.11a, 802.11g/b...
Belkin (F5D5010) (F5D5010AU) Network Adapter Logo
51 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
