Question about Whirlpool Duet GHW9150P Front Load Washer
Keeps saying HF
My machine quit mid-cycle and says HF blinking on the screen,,dont have a manual because I bought it second hand,, please help!!
    President:
  • 1,314 Answers
First go here and download a manuel http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=GHW9150P&siteCd=WHRCOM then at the bottom of the page download a parts list and keep them both the parts list will show you how the machine is put togeather and are you sure the code is not fh .fh is the code for not enough water in the machine its not filling in the time alloted check the screens on the water valves make sure the lines are open all the way and the hoses arent kinked get a bucket and open the hoses in it to check your water flow out of both lines look for slow fill or weak pressure let me know what you find it could also be that one of the water valves are bad if its not filling in rinse and you have hot wash cold rinse selected then the cold valve could be bad
Posted on Mar 30, 2008
What does it mean when the machine stops mid cycle and H and then F displays in the digital window?
I think that means NO, Hot water Flow (HF)
Try this Hold the "Start" button IN while you Switch ON.
Also check this out pull the water lines filters to check the screens, and the cold water line for crud in it
Feb 16, 2010 | Frigidaire ATF6000ES Front Load Washer
Stops Mid-Cycle: Error code is blinking ?H? then ?F?
FH, in mid cycle most likely your pump is blocked, hit drain/spin and see if water drains, if not clean pump
Dec 17, 2009 | Kenmore Elite 45986 Front Load Washer
Hotpoint wm53 unknown problem
Hi.
Unplug the motor and try it again, if it does not trip, then the prob is the motor, could be worn carbons.
Re the noise, remove belt, and spin drum round by hand, if it is noisy and rumbling, then main bearings have failed, quite a big job to put right.
Please rate my comments.
Thanks.
Jun 17, 2009 | Hotpoint Washing Machines
Door Locked. Cannot open. Washine inside.
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Machine keeps stopping
i bought a new washing machine but thanks anyway
Jan 22, 2009 | Creda W100FW Front Load Washer
HF alarm
1st ck all hoses and screens for blockage be sure you have good water flow to washer next remove top ck flow meter left side 2 small hoses 1 in one out may be able to tap it on the side and temporaily correct problem best bet is to replace it
Oct 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Cant get games to play on my sons psp
This may be a number of problems. The disc might be scratched or damaged. Or there could be dust on the leans.
You say it's a second hand PSP? In that case, you may need to repare it. I'm not quite sure where to go to get repares. Sorry.
Dec 18, 2007 | Sony PlayStation Portable (PSP) Console
Manual
Here is the link to the user manual for your machine - sorry i couldnt find one for free, but this one is only $14.95; http://www.sew4less.com/product_details.php?ProductID=3237 hope this helps :)
Apr 18, 2007 | New Home HF-1012 Mechanical Sewing Machine
Whirlpool Duet GHW9150P Front Load Washer Logo
285 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
