Question about Microtek ArtixScan 120tf Film Scanner
Clean Sensor on 120tf
Hi I would like to try clean the scanner glass and get some dust off the sensor in the 120tf with the proper brush. Has anyone ever attempted this before? Do you know how to do it?
SOURCE: Glass Dirty on the Inside
its easy. the top is held on by double sided sticky tape and two plastic tabs only.
use a small screw driver to break the tabs (located near the hinged end of scanner).
prise the edges of the plastic at the sides with a small screwdriver and slide a thin knife slowly along until they release.
remove glass and clean.!!!
Posted on Jan 27, 2008
Roonie Tunes
  • 136 Answers
SOURCE: I need to clean the underside of the glass on my Canonscan Lide20
How on earth did the underside of the glass get dirty?
Ok, never mind that... in the end, it's NOT worth it. In the old days, you could have since scanners were as big as printers are today... but now they are definitely NOT designed for the consumer to service. The scanner is designed for accuracy, even if you were to get it all apart, the odds that you maintain the precision and integrity of the bulb, the track on which the bulb moves, etc, are very slim.
Suggestion... How is the printer you have holding up? If it's getting on in age, it may be a wise investment to purchase a dual scanner/printer (as long as you are spending the money).
Hope that helps :)
-- RT
Posted on Sep 03, 2009
SOURCE: How do I clean the inside of the glass on the Epson 3490 Scanner?
Disconnect and remove the lid. Remove the two screws on the back of the base. Then use a screwdriver or flat blade to slightly open the back seam. Beginning at the back, run a blade up inside the upper part of the side seam. You will need to release three catches on each side. Once the sides are loose, raise the back of the top, while pushing forward, and the two snap catches at the front will release. The top then lifts off and you can clean the glass. Reassemble in reverse order.
Posted on Nov 17, 2009
  • 857 Answers
SOURCE: need to remove top of scanner microtek scan wizard
Follow these steps to clean the scanner :
Open up your scanner's lid. It does not matter if the scanner is on or off for this basic, regular cleaning.
Wipe down the glass surface with a dry, lint-free microfiber cloth. This will remove any dust or other fine particles that have accumulated on the scanner. You should remove excess dust every day or two.
Scan a blank sheet of white paper into your computer and look for visible discoloration. A white sheet will provide a clean, blank slate to view the scanner's overall quality. If you notice any irregularities on the white sheet, you need to do more thorough, semi-regular cleaning.
Semi-Regular Cleaning
Turn off the scanner and open up the lid.
Spray a small amount of "mild glass cleaner" on a soft, clean cloth as recommended by Scanner-Magic.com.
Wipe the scanner's glass to thoroughly clean the area. You should perform this semi-regular cleaning at least every two weeks or sooner if a white sheet of paper indicates discoloration.
Keep the scanner's lid open for a few minutes until all excess glass cleaner has dried.
Posted on Nov 26, 2010
SOURCE: scanner glass clean
Cleaning the glass is rather simple. Take the 2 screws under the cover out. Now gently lift the top part of the scanner (some force may be needed). Then the scanner is in 2 parts and the glass can be cleaned inside and outside with a wet wipe glass cleaning pad. Dry the glass with a towel and inspect the glass with a lamp, that no cleanser remains are left. Now install the scanner in reverse order.
Posted on Feb 14, 2011
SAYS STAPLE DETECTED BUT NO STAPLE
Try cleaning the staple detection sensors in the machine. Most of the time if you blow air gently into the machine to clear dust from the sensors.
Feb 11, 2014 | Canon DR-7580
Pictures scan with a dark line
Hi ,
can you please specify your printer model for more appropriate solution Buddy!..Thank you!..
Jul 19, 2008 | HP Office Equipment & Supplies
Tip
How to Clean Scanner Glass
Steps how to clean scanner glass
1. Unplug the power cord.
2. Clean the outer case with a cloth dampened with a mild detergent and water.
3. If the document table glass gets dirty, clean it with a soft dry cloth. If the glass is stained with grease or some other hard-to-remove material, use a small amount of glass cleaner and a soft cloth to remove it. Wipe off all remaining liquid.
4. Ensure that there is no dust on the glass of the document table. Dust can cause white spots in your scanned images.
*** CAUTION: Do not press on the document table glass too hard.
5. Be careful not to scratch or damage the document table glass, and do not use a hard or abrasive brush to clean it. A damaged glass surface can decrease the scanning quality.
6. Never use alcohol, paint thinner or corrosive solvent to clean the scanner. These chemicals can damage the scanner components as well as the case.
7. Be careful not to spill liquid into the scanner mechanism or electronic components. This could permanently damage the mechanism and circuitry.
8. Do not spray lubricants inside the scanner.
9. Never open the scanner case.
***NOTE: Wipe the inside of the document cover and the scanner's document table before scanning transparencies.
on Jul 19, 2008 | Epson Perfection V200 Flatbed Scanner
Hp 7210 rinter will not align properly
Hi Melvin,
This could be due to faulty, low ink level or Scanner glass not clean.
Remove the cartridge and Clean the electrical contacts ( tiny golden contacts ) with lint free cloth. Open the scanner glass and wipe the glass for any dust particules.
Turn off the printer ( without cartridges )and turn on. It should prompt you to install cartridges for alignment.
You can also try cleaning Cartridges from Front panel
Press Setup button ( menu button )
Scroll to Tools - Press ok
Check for Clean Cartridges/Printhead - Press OK
IT will clean the cartridge contact and print the alignment sheet which you need to place face down on the scanner glass and press OK
Regards,
Sean
Apr 21, 2013 | HP 7210 OfficeJet All-In-One Printer
CF1501 error code c0650
C 0650 Scanner home sensor malfunction.
Remove the original glass and clean the home sensor(the sensor is dirty,paper dust) located in the rigth rear corner.Move the mirror assy to maximum right position and you located the sensor.
Feb 13, 2013 | Minolta CF1501 Copier
How to removed error E000202-0000 for ir 5800
unplug the copier .remove copyboard glass,slide scanner towards right side, under copyboard glass on left side rear corner there is a black sensor which will look the shape( 'F'-side view) clean the cavity between two horizontal arms of 'F' shape sensor with a soft painting brush(10 mm).replace copyboard glass ,swich on the machine.
Jan 21, 2011 | Canon imageRUNNER 8500 Copier
HP All-in-One 3055 "Scanning Error 6" What can we do?
Hi Cherylanne, Give this a try: Scanner Error 6 Turn off then on
1. Clean Glass Scanner Bed.
  • If the glass scanner bed is too dirty or smeared with fingerprints and such, you may get this error. It will not clear itself simply by turning off and on the printer such as the message suggests. Even a build up of dust can cause this. It is triggering a reaction caused by a sensor in the scanner. If you clean it good and then power cycle it, the problem should go away. THIS PROCEDURE FIXED THE PROBLEM FOR THE AUTHOR.
2. Try the NVRAM INITZ reset procedure. REF
  • switch off the printer, then remove all cables connecting to the printer but just the power cable.
  • then press and hold the *(start/symoble) and 5 button togather and turn on the printer.
  • continue holding the button till you see "perment storage init" displayed and releas the button.
  • then at a given point of time the printer will ask you to change laguage,time,date etc.
3. Remove paper scrap or dust obstructing scanner or sensor. REF
4. Clean sensor / remove the glass and clean the bulb and mirrors. REF
  • turn off power
  • remove ADF and inspect blew out any dust
  • unclipped control panel cover and removed top platen cover 4 torx screws
  • inspected and dusted (blew out) the scanner
  • put platen cover back again and placed 5 sheets new paper over right side (where scanner is) and turned on came up happy
  • turned off reinstalled ADF (cleaned the white surface first) turned on again
5. Scanner Bulb is not getting to the alignment area.
Information found @
http://wiki.robotz.com/index.php/HP_LaserJet_3055
Regards
Mike
Oct 12, 2010 | HP LaserJet 3055 All-In-One Printer
Light flashes and it says the scanner door is open but everything is closed
More common reasons are paper jam, dust/dirt, or a faulty sensor.
So, check for even the smallest pieces of paper, especially in the scanner area, use compresser air if necessary and clean the scanner glass.
Your sensor could also be broken/faulty. Not certain if the sensor is a user-replaceable part.
Hope this helps.
Aug 10, 2009 | Canon DR-2580C Path-Through Scanner
Canon Scanner
Scanners can be taken apart to be cleaned:  'You want to clean the inside?' 'Well, its dirty ikayak, thats why.' Ok take it apart, remember the screw sequences; that aint hard normally for scanners.
Put it this way there aint any little brushes or nanobots to clean it for you in there... you gotta do it manually. Use something alcohol based to lose smears and actual residue. It its dust then use a hairdryer and a soft SOFT brush that doesn't have any dust on it itself... you'll just make it worse.
I hope your scans are clearer now!
Jul 12, 2008 | Canon CanoScan D660U Flatbed Scanner
Dirty scans
Small white dots would indicate progressive failure of the CCD[sensor] or perhaps ingress of dirt to the inside of the glass. hard to say exactly with out seeing the machine.
Jan 13, 2008 | Epson Perfection 3200 Photo Flatbed...
Microtek ArtixScan 120tf Film Scanner Logo
43 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Alun Cox
Tony
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
