Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
  • 150 Answers
Very simple system my man. the brake handle connected to the master cylinder connected to the brake line connected to the calipers via the plumbing in between. so check your fluid level first if its low then top off and bleed those babies. also check the pads because as the pads wear the piston in the caliper moves further out so more room in the system so lower fluid level or you got a leak. or the master cylinder is bad. start with the obvious and dig deeper good luck and let me know tell me more about the malfunction too
Posted on Apr 21, 2008
Brake lights are out on a 1999 infiniti I30
99 infiniti i30 brake lights not working - Nissan Forum ' Nissan ...
Apr 13, 2015 - hi, so my rear stop lights stopped working recently. but the brake light inside the rear window above the trunk works fine. that makes me ...
images for 1999 infiniti i30 wiring
Oct 02, 2015 | Infiniti Cars & Trucks
To adjust back brakes
The best method for adjusting your rear brakes assuming that they are of drum type, is to jack up the rear axle one side at a time and remove the rubber cap on the inner brake plate.Block your front wheels forward and rear. Then with a brake adjustment tool available at most auto part stores, turn the adjuster in the "only" direction that it will turn. The vehicle must not be in park to do this, so make sure she's on level ground. Once you've done this, spin the tire of the wheel you are working on and adjust the brake until you feel a slight drag on the tire. You can also listen to hear the brake shoue touching the drum. You also might want to have someone press the brake pedal occasionallly to "center" the the shoes. Thank you, Dana
Mar 04, 2010 | 1999 Chevrolet Malibu
I have a 1999 gmc sierra .the front brakes lock . its a 2 wheel drive . what is the problem
Could be the proportioning valve, master cyliner or the front calipers going bad. You didnt say the milage or if you have had the brakes serviced.
Feb 16, 2010 | 1999 GMC Sierra
Front brake ok until you move the bike then it just goes
try bleeding the front brake pull brake lever 3 times hold lever loosen bleeder screw on caliper retighten bleeder screw this takes 2 people just make sure you dont release brake lever while bleeder is open you wanna repeat this acouple of times untill nothing but fluid comes out bleeder also keep an eye on fluid level in master cylinder you will want to make sure to refill it with proper brake fluid
Oct 10, 2009 | 1999 Honda CBR 900 RR Fireblade
Replacing front brake line
its really easy your gonna need a line bender they are cheap about 10 to 15 dollars and some line and wrenches dont forget to get help bleeding the brake line after replacement.
May 22, 2009 | 1999 Isuzu Rodeo
Changing brake pads on 1999 focus
if you arent sure how to change the pads then dont! brakes are the most important part of a cars safety and if you dont no what your doing then you could put yourself and others lifes at risk spend a few bucks and take it to the shop one stuff up and it could cost you more
May 20, 2009 | 2000 Ford Focus
Brake pad replacement problems
get haynes repair manual.dont cost much .it got pictures .and it show you step by step .to change front disc brakes.
Jan 16, 2009 | 1999 Kia Sportage
ABS braking
have you check? the master cylinder. sometine when you get the rotors cut they dont come out right because they may be warped or to thin. if you did the job yourself you might have put the calipers in on the wrong side. this happens alot . if your rotors front and rear are fine then switch the calipers to the other side.
Dec 11, 2008 | 1999 Ford F150 Regular Cab
1999 oldsmobile cutlass
you should have two bolts on your 1999 olds dont forget to push your calber can use a srewdriver for that.. before you lossen the bolts or your new pads will not go on.if you thik it might be four then look at a brake diogram on line. just type in brakes for a 1999 olds or something to that effect and it will show you the bolts good luck............
Oct 07, 2008 | 1999 Oldsmobile Cutlass
Lands Phones Logo
103 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
