Question about LG WM-2277HW Front Load Washer
Lg front loader not drainig, error code comes up.
Lg front loader not drainig error code comes up. Checked filter also pulled hose off underneath to and from pump checked for debri found large button pink almost exactly size of hose. Removed pump just hums no spin no drain. Obviuos problem of pump but where did the pink button come from no one n my house has anything that would have this large half dollar size pink button. And even if we did how would something this large get in there i woud ave 20 bucks in change if it was an easy task. Factory installed pink button conspiracy! please help
  • 343 Answers
Humming usually means that the motor is being physically prevented from spinning. Check that there isn't a small coin or similar jammed in the impeller blades...The motors on those pumps also can collect debris INSIDE the pump motor behind the impeller seal..That would require a new pump motor. Check impeller first!....Good luck.....Nomess
Posted on May 14, 2010
Why doesn't it rinse?
see the square box on the front bottom?,that is where you access all of that
Jul 27, 2015 | LG 4.0 Cu. Ft. TROMM Front Load...
LG Tromm wm1815cs front loader washer error message 1e. Have cleaned filters, checked hoses,and supply source, I still get message,
R u sure it is not an (LE) error code. Kinda looks like an upside down (F)? Very common on older LG washers. Indicates a hall sensor/ motor position sensor error.
Mar 22, 2015 | LG Washing Machines
Have a load of washing in my front loader and now my LG wasing machine says 'UE'. What does this mean and how do I fix it?
is this an Lg washer ie error code is an water inlet error machine notices low water pressure , you either have kinked fill hoses , plugged screens in fill hoses coming to you watervalves or watervalve is damaged from foreing debris coming into watervalve .........
Jan 24, 2011 | LG Washing Machines
Lg washer front loader ( oe) code
Hi
Thanks for using FixYa. OE is a Drain Error which indicates that the water was not fully drained within 10 minutes. To start with check the drain pump filter for any clogs/foreign materials and try to clean the filter. Also if you have already checked the drain hose for any blockage then check the pump for any blockages, if still its not resolved then it seems to be the pump that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 25, 2010 | LG WM-2277HW Front Load Washer
My LG Front Load washer starts to wash, then when it tries to drain, it stops and shows error code OE. I checked back drain hose and they are not kinked. I removed front filter in bottome left and water...
Hi dear.OE code meaning on Lg washer's"machine unable to drain in 10minutes". You can make a little test.Please remove the filter & pour some water in side drum ,watch for water coming out of filter.If it's slow, tub to pump hose clogged.(there must be some sort of fluff or coin clogging hose)if it's not slow,waters comes out freely, run machine on drain cycle & check the pump motor is it running smoothly?If not change the pump.I hope that helps.Thanks.
Aug 23, 2010 | LG WM2487H Front Load Washer
I have the LG Tromm 27'' Front Loader model WM2277HW
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!
Oct 07, 2009 | LG WM2688HWM TROMM SteamWasher
The front loader for lg washer won't drain
Mar 29, 2009 | Washing Machines
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG WM-2277HW Front Load Washer Logo
182 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
