Question about LG WM-2077C Front Load Washer
Sounds like a bearing is going out howls when spinning
  • 343 Answers
You're probably correct...Get quotes to replace seal, bearings and probably the pulley shaft as well, because the shaft may be grooved and the seals may not last......Good luck...Nomess
Posted on May 14, 2010
I have a honda pilot when I start off the left front whell makes a howling sound. That sound even gets louder going 50 mph around a slight right turns. I changed the tires at 10K and the sound went away no...
This might be a wheel bearing problem. All of your symptoms point to this except for the noise going away when the tires were changed. If you jack your car up and spin the tires by hand sometimes you can find one that is louder and sounds rougher than the rest. This indicates a faulty wheel bearing.
Sep 19, 2011 | Honda Pilot Cars & Trucks
Put car on jack stands and A howling noise comes from passenger side when spinning at 10 mph and gets louder at 20mph
Sounds like a bad hub bearing ! This is the bearing that the cv axle goes through ! If bad you will need in most cases to remove the k uckle and take to a machine shop to have a new bearing pressed in ! Some hubs are a bolt in which you can do at home !
Mar 15, 2011 | 2001 Oldsmobile Alero
JUST GOT TWO NEW FRONT TIRES,(AND BALANCING). NOW THERE IS A CONSTANT NOISE COMING FROM THE FRONT END AND GETS LOUNDER AS ITS ACCELERATED. SOUNDS LIKE A RUBBING OR HUMMING NOISE.
Sounds like a wheel bearing or bearings going bad.
Humming or 'howling' noises are indicative of a bad wheel bearing especially on acceleration.
Good luck on this repair.
Oct 12, 2010 | 1999 Ford Taurus
Why does my car make howling noise that sounds like its coming from either front right or center of the car, it doesnt pull while going straight, the engine is newer with 40,000 miles on it, the wheel...
You probably have a bad hub bearing.If you can change the noise by slightly turning the vehicle one way or the other it is a hub bearing.If you turn left and the noise is still there then it is the right front bearing.If you turn right and the noise is still there it is the left side.If it makes the noise both ways it could be both front hubs.Hope this helps.Good luck.
Mar 23, 2010 | 2000 Chevrolet Malibu
The car makes a howling noise while driving it
well did the noise start after the tires were rotated?could be choppy tires,,,if not ,i strongly think it sounds like a bad wheel bearing,,,,if you drive and while its making the noise turn left and right quick and see if the noise gets louder and which way turning makes it louder,,if you turn leftand it gets louder its usually the right wheels bearing as you are putting load on it, if it makes the noise louder while turning right its the left wheel bearing,,,got it
Oct 08, 2009 | 2000 Pontiac Grand Prix
Anyone solve the howling problem please share.
sounds like the fan bearings are wearing out. this causes imbalance and makes a vibrating howling noise.
Aug 26, 2009 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Strange sound Maytag top load washer about 4 yrs old
It sounds like your bearings went bad. Using powder soap kills the bearings. THis also depends on the model of maytag. IF you lean the washer back look to see how many belts it has. if it has one it is really a maytag made by amana. Those are known for bad bearings. So good luck with your bearing problem. You will probably have to call out a technician Its a big job.
Nov 18, 2008 | Maytag Washing Machines
LG WM-2077C Front Load Washer Logo
89 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
