Question about Grilling
Viking grill burner is clogged and fire is shooting out of knob. How do I clean my grill from excessive grease.
  • 494 Answers
Is it still under warranty? I'd call Viking or a qualified repairman to fix it. If your burners are clogged, the flames should be coming out the venturi tube and flaming towards the gas valve knob. If the flames are coming out of the gas valve itself, then it will need to be regreased. If the burners can be removed without too much trouble, soak them in the sink with hot water and dishwashing detergent. Be sure to remove the knobs, so no one turns the gas on without the burners connected. If it's difficult, call a repairman.
Posted on May 15, 2010
Viking grill burner low flame
If this burner has tube type, You can loosen a screw in the front of burner and slide open air rater vent just a little just make sure not to open to far. blue-ish/orange flame is what your looking for
Apr 10, 2015 | Viking 500 Series VGBQ53002RELSS 30"...
Rotisserie burner has to be lit with a match and will not stay on by itself. I have to push control knob in, even after it is hot. Also looking to replace igniter for left burner. Thanks.
From what you are describing, it sounds like your rotisserie burner may have a bad thermocouple. You can order the parts from Viking, the igniter for the left main burner will require you to remove the front panel to replace, but is fairly straight forward after that. To replace the thermocouple, you will have to fish it down from the burner and under the grill to behind the front panel, not hard, just time consuming.
Jun 19, 2011 | Viking VGBQ410-3RT Grill
Viking gas grill - when I turn the knobs to lite up one of the burners, it rushes out the gas with a loud hessing sound. also there are flame coming out from where the gas comes out and goes into the...
What you have described sounds like a clogged burner as well as the venturi valve on the burner. Your will need to remove the burner to clean it and the venturi valve on the open end of the burner, that goes over the burner orifice. Spiders like to build nest in them and clog them up. The venturi valve will look like two slots, cut in to each side of the burner, at the open end. It's function is to mix air with the gas, for proper combustion.
Hope this helped you to troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 16, 2011 | Viking Grilling
Firemagic ECHELON E660i - flames shoot out around the orfice heat stressing the front panel, making controll knobs too hot to touch and allowing flames to shoot up onto the lid, grill is 20 months old. ...
Has this been happening since new or did it just start?
Either way, you need to check the burners for proper placement over the burner orifices. Are they fitted snugly? Are they running perfectly parallel to each other and resting properly on the back inner cabinet of the grill, in the burner holders.. Also, make sure that the orifices are screwed in tight and are not clogged. Check the burners for clogs and if found clean out the burners, by gently tapping them on a firm surface.After doing that, turn the up so the orfiice end is down and see what falls out of the burner(s). If the burners or orifices were clogged or the orifices not tight, it may be backfiring into the control panel. This can also indicate a gas pressure problem.
If you can remove the front control panel (remove the burner knobs, first) you can access the gas fittings to each burner's control knob and it's gas fittings. Without lighting the grill, turn each burner ON and check for leaks with soapy water at all the connections. Then turn it off and check for leaks again.
If you found any leaks, check each fitting to make sure it's not cross threaded and re-tighten.
If none of the above solves the problem, contact the Fire Magic Dealer you purchased it from or the R H Peterson Company (they make the Firemagic Grills), as it may be a manufacturer's defect. They have an excellent warranty program. For a warranty claim, you will need your Proof of Purchase.
Hope this helps to get you back grillng>
Feb 21, 2011 | Fire Magic FireMagic Grill
My knob was on fire today and fire beneath it melted knob sticking out
burner is clogged or faulty and allowing flame to "back up." If it is a Jenn-Air, call them to replace all burners. You may have a damaged valve(s) now due to the excessive flame being where it should have not been. I would not use grill until further inspection.
Aug 08, 2010 | Grilling
Side metal pieces that cover the Viking grill burner are rusted. Do I need to replace the whole burner or just use until burner holes become clogged that then replace?
I would suggest first lifting them out, give them good brush with wirebrush, check if holes are not clogged, check for any not surface damage, they ususally rust bit over on the surface and that is all.
If grill flame is working correctly, and grating have still "decent" thickness and is not falling to pieces, I would still use them normally.
Rust on the grate is usually caused by not using it and exposure to rain/water, as this grating is usually rather solid, surface rust will not affect it. If you have model with stainless graing - there should be no rust on stainless...
That is one of the reasons why you should not wash your grill after use! Fat from cooked food is protecting it from environment.
Hope this will help your worries at bay :-) Enjoy your grill!
Aug 08, 2010 | Viking VGBQ410-3RT Grill
I have a Viking Grill model VGBQ530 with cast iron burners that need replacement. I cannot find the exact model no. with these replacement burners however it appears that Viking now have a replacement made...
That is correct. Viking no longer supports the Cast Iron Burners. There is an aftermarket Burner VIKU1 that comes with mounting brackets to convert older Viking Grills that used a Cast Iron Burner to be able to switch to the stainless steel burner. The large bracket attaches to the center tube and has two screw holes and screws for mounting to the rear of the housing. The two smaller brackets mount to the two holes at the rear wall of the housing and create a ledge for the end of the two tubes to rest on.
Jun 11, 2017 | Viking Grilling
Hello. Use ammonia. If you can remove the burner, wrap it in ammonia soaked newspaper layers and slide it into a large plastic bag overnight. Joe
Mar 20, 2010 | Grilling
Viking stove right burners won't light
can u see the burner spark if not then ht lead at fault of electrode
Aug 21, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Grilling Logo
306 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Grilling Expert? Answer questions, earn points and help others
