Question about Taylor 632-33 Ice Cream Maker
Taylor 8756. Electrical service too high???
I have a Taylor 8756. The electrical service is recommended at 208/230V. My service is 241V. Is this a problem? I have lost several components over the last couple of years and have been told that this is probably the issue. What can I do?
    Scholar:
  • 81 Answers
This is your problem! There are solutions available for this problem. I recomend a Buck and Boost Transformer. You will have to purchase one sized correctly for your machine. Be prepared to spend a little money as they are not exactly cheap. Get the transformer from a local electrical supply company. Take them all the information on the data plate and your existing voltage readings. They should be able to determine what you need. The buck and boost can be wired to "buck" down the voltage to a more suitable voltage for your machine. You need to be within the electrical range stated on the machine or you will continue losing controls etc. This can be very expensive as well. Please note: you will need a skilled technician to wire and install the buck and boost transformer. They can be complicated.
Posted on Jun 18, 2011
  • Allen
    Allen Mar 01, 2014
    FYI - I experienced this problem as well. I started a business in an older building which had older / higher voltage. The voltage to my Taylor 8756-27 (air cooled / single phase) was about 248. After a couple months of unknowingly operating at this high voltage it blew both logic boards, fuses, etc. It cost $968 in parts and labor to repair all of this. For $800 I had an electrician install 3 buck boost transformers which knocked down the voltage to an acceptable range. High voltage runs your machine hard and will cause problems. Also, try checking with your electric provider. If the voltage is within their range considered high, they may help you fix the problem. I checked with my provider (Duke Energy) and although my voltage was high and causing me problems, it was not high enough for them to assist me.
I have a taylor ice cream machine (DQ) model 8756. new at this. getting constant beeping and no idea why. can you help?
Since you didn't report any other problems, I am going to assume the machine is working otherwise. In that case, it is usually a bad logic board. Since the left and right side logic boards are the same, you could swap the two boards and see if the issue follows the board.
Most people will order the logic board and replace it themselves, avoiding a service call.
We have reconditioned logic boards available here.
http://www.softserveparts.com/i-26471526-x36641ser2refurbished-gen-2-logic-board-this-item-is-sold-with-exchange-only-you-must-return-the-no.html
We have new logic boards available here.
http://www.softserveparts.com/i-26471706-x69571-ser2-logic-board-gen2.html
I would be happy to put a technician on the phone with you for this issue or any in the future. 1-800-879-7839
Jul 02, 2017 | Taylor Ice Cream Makers
Does the taylor model 8756 put out a substantial amount more product than the 754?
Absolutely! The Taylor 754 and Taylor 794's are capable of 284 3 1/2oz. servings per side / per hour. The 8756 is capable of 426 of the same 3.5oz. servings. The 8756 packs more air into the product making it easier to freeze and reducing recovery time.
Soft Serve Parts Taylor Machines
May 07, 2017 | Taylor Ice Cream Makers
Taylor 8756-33. Which components operate in standby mode?
In standby mode, the machine just wants to keep the product refrigerated until it goes back into auto.
So, the mix cabinet needs to keep the product cool in the bottom of the machine, that requires the mix compressor and fans to run. The mix cabinet temperature is read by a thermistor probe and regulated by the (left side) logic board.
The product in the cylinders should go back to liquid form in standby, but we still have to maintain that safe food temperature, the motor and compressor will run periodically. If the machine is air-cooled a fan will run anytime the compressors run. If it is water cooled, water will flow through the machine when the compressor runs. The temperature in the freezing cylinders is read by a different thermistor probe and regulated by the logic boards.
Here is a link to all of the parts in a Taylor 8756.
http://www.softserveparts.com/c-1335911-parts-8756.html
Jul 20, 2015 | Taylor Ice Cream Makers
Manual and guide for Taylor ice cream machine model 8756-33
For Taylor ice cream machine maintenance, please see our Support page or our Youtube channel. Providing ice cream equipment maintenance to you for free!
Slices Concession
Aug 07, 2013 | Taylor Soft Serve 8756 Three Phase Water...
Pump loses prime causing ice cream to spit out.
If it is "spitting" you might want to check all the components from the mix container all the way up to the door where ice cream is dispensed. Check for leaking mix hoses as well as broken or clogged diaphragm (inside fitting in mix cabinet). Refer to the manual to find the diaphragm.
Aug 26, 2012 | Taylor 2009 Model 8756 Soft Serve Ice...
Owners manual taylor ice cream machine model 8756-27
Slices Concession
Apr 25, 2012 | Taylor 2009 Model 8756 Soft Serve Ice...
Taylor 8756 bottom cooler too warm
have you cleaned the coils in the top of the unit, the fridge one is the little one on the side.
Jul 07, 2010 | Taylor 632-33 Ice Cream Maker
As a general rule, most unit can handle a voltage of =/- 10% of rated voltage. I would call Taylor to be sure. You can get a "Buck and Boost" transformer that would lower the voltage but you may not need to.
http://www.taylor-company.com/
Go to this web site and look up your local distributor or contact them directly.
Mar 20, 2010 | Taylor 632-33 Ice Cream Maker
Taylor 8756 ice cream machine clogs at face
i need to know where i may go to get directions to put this taylor 8756-22 ice cream machaine back togeather if you can help please e-mail me at johnjohnson1967yahoo.com thanks
Jun 01, 2009 | Taylor 632-33 Ice Cream Maker
Spares for Taylor 8756 ice cream machine
you must buy replacements from your local tatlor dist. 700-900$
You will find that responce from all of thier part suppliers carrier is a very well insulated company.
Jul 29, 2008 | Taylor 632-33 Ice Cream Maker
Ice Cream Makers Logo
180 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
