My wife's Fujitsu Lifebook A6120 has lost power. I suspect the problem is with the power cord or post as it is mounted on the side of the laptop. Is this a common issue with this model?
    Champion:
  • 218 Answers
Yes very common i would take it to a pc shop to have it check with one of there cords hpe this helps
Posted on May 15, 2010
How to reset the user authentication password on fujitsu A6120
password authentication system please for fujitsu siemens S7110
Apr 16, 2012 | Fujitsu LifeBook A6120 Notebook
Shut down pc and moved to another room. When I plugged into wall, no indicators of battery charging or even that there is an outside power source. Tried new battery, lifebook shows no signs of life.
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Feb 04, 2011 | Fujitsu LifeBook A6120 Notebook
Hello, i have a Fujitsu A6120 laptop and the options for adjusting brightness (thru control panel and manual adjustment by key-function) are not working. the brightness is just set to maximum. I?d like to...
Either adjust them with your graphics cards control panel(right click desktop and screen setting should be there, or from the control panel)
or adjust it through the power options menu in control panel
Jul 10, 2010 | Fujitsu LifeBook A6120 Notebook
Yes, as a PC Tech, I have seen many Fujitsu Lifebooks, all bearing the same problem. The A/C power jack mount where the power cord connects to the notebook is very fragile and seems to become unusable after a period of time.  I repaired a whole sales team fleet of 19 units that were all Fujitsu Lifebooks and all with the same problem . . . damaged or broken AC adapter jack.
The solution is to reorder the power jack component (usually less that $10.00) - remove the faulty jack and replace it with the new one - however this is not an easy task unless you have good soldering skills.
You will need a low-temp soldering Iron and a service manual to show you how to dismantle the laptop and access the power jack.
I don't recommend novices techs to try this. The good news is that most PC repair places will fix the problem for less than 100.00. The bad news is you will eventually have this issue again in the future.
Hope this answers your question!
Mar 20, 2010 | Fujitsu Computers & Internet
My lifebook s7010 won't startup. After put the on button the screen still remains black. The fujitsu logo will not appear on the screen.
Unplug the AC adapter from power cord, then remove the battery.Wait 30 min and put the battery back.Plug the AC in power cord and try again.If not start you need check AC adapter with voltmeter.If the AC working your computer need service.
Nov 10, 2009 | Fujitsu Siemens LifeBook S7010 Notebook
Touchpad stopped working on my Fujitsu lifebook
You need to re-enable it. Hold Fn and hit the F5 or whatever key is appropriately assigned to the touchpad. This should enable it for you.
Oct 19, 2009 | Fujitsu LifeBook A6120 Notebook
Fujitsu Lifebook T Series wont power on at all
1) Remove battery and power cord  2) press power button several times  3) Whack laptop on the bottom center 2 or 3 good times with the palm of your hand  4) Replace battery and plug  5) Power it up (may have to hold the power button several seconds)
Aug 06, 2008 | Fujitsu LifeBook T3010D Tablet PC
Computers & Internet Logo
David Payne
David Payne
