Question about Plumbing
New KOHLer toilet, worked great 2months... now
New kohler toilet worked great 2months... Now fills slow 4-5 minutes for tank to fill all the while it never quits filling also water runs from the little white tube into the overflow tube all the time...can you tell me what to do...woman of the House
  • rockscookin May 14, 2010
    Sounds like your fluid level control valve has some debris in it. If I new what kind of valve it was or what it looked like. I might be able to better guide you in the direction you need to go. IE fix or replace.
  • 349 Answers
On top of the valve in toilet it has a cap that you can remove. It may have sometime obstructing flow.
Also on top it will have a screw for adjustment you could try to run it in a little. This is for valve 's with arms that extents float ball in tank. Just make sue that it is not touching any where in tank, causing it to hang up and run.
Posted on May 18, 2010
  • Randy Marshall May 18, 2010
    Make sure you turn water off first before removing cap. and on top it will have a washer remove it and make sure there is nothing there to obstruct flow.
Water is not coming out on the top of the fill tube that connects to the overflow tube
It doesn't usually have water coming out. If it fills the tank, it is ok. The water is coming out at the bottom anyway. However, the adjustment on the tube is off and not allowing water in .
Feb 16, 2013 | Kohler Toilet - One Piece with Ingenium...
The toilet flushes but it won't fill. I can turn the water supply off and then back on, then it fills normally.When the tank is full, I can push the float down and no new water enters. when I flush,...
Hi!please kindly check your fill valve if it is working correctly.I thought the problem is in your fill valve.Kindly adjust the floater of your fill valve.
Aug 24, 2011 | Kohler Home
I have Kohler 3386-6 Rialto Skylight Round Front Toilet problem is that tank filling is very-very slow, perviously it used to fill in few seconds now it is taking 15 min. please let me know how can...
There is a screen @ the inlet to the vavle where the water connects that may be plugged or contact Kohler they will send you a repair kit for the fill valve.
Dec 12, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
New KOHLer toilet, worked great 2months... now fills slow 4-5 minutes for tank to fill, all the while it never quits filling, also, water runs from the little white tube into the overflow tube all the...
the fill assemly ( called the ball and ****) is bad cost about 8.00 at the hardware store, take about 10 min too replace,
instructions are in or on the box!!!
Mar 20, 2010 | Plumbing
Kohler Highline Class V tech toilet. Bowl does not fill. Why? What can I do to fix it?
Check tank for fill line running from fill valve to overflow tube. It will be a 1/4 " line that allows the tank and bowl to fill. It should be connected from fill valve and connected at the top of overflow by a clip or hanger.
Check out the water level in tank to make sure it is filling to line on overflow or within 5/8" to top of overflow pipe.
Feb 06, 2010 | Kohler - Toilet - Two-piece - Highline -...
New water valve makes ahigh pitched whistling
I had exactly the same problem. Just turn down the water pressure @ the valve on the water inlet line. While you have the toilet lid off, you may want to remove the fill valve (1/2 turn counterclockwise on the plastic nut attached to the water-in line), and clean the rubber diaphrams (there are 2). They will sometimes get gritty and this will cause some fill noises and leaking.
Oct 25, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Toilet fill runs periodically works well but wastes water
Sounds like your flapper is leaking causing the water in the tank to lower until it triggers the fill valve. Replace the flapper (they're cheap and wear out easily).
Jul 03, 2009 | Kohler Toilet - One Piece with Ingenium...
Valve adjustment
You need to replace the flapper and you will need to purchase one specifically for the Kohler toilet. I have the same toilet and tried using a generic flapper and from experiance, it didn't work until I bought the correct one and I'm a plumber! Have a great night.
Apr 01, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Plumbing Logo
177 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
