Question about Frigidaire FGQ332ES Gas Dryer
My dryer flame lights then goes out after a little while. It does this on timed as well as amount dried cycles. Drum still turns but heat goes out. I can usually get it going by starting the dryer again. But not always.
  • Frigidaire Master
  • 43,501 Answers
Hi, If you have a gas dryermy dryer flame lights then goes out after a little - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
my dryer flame lights then goes out after a little - 2_bing.gifour dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bingmy dryer flame lights then goes out after a little - 2_bing.gifs= Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 15, 2010
Whirlpool dryer heating sporadically?
Remove the lower front panel and turn dryer on. The ignitor should glow bright orange first. After Ignitor glows brightly the next thing will be the flame lighting as the gas valve opens with a click. All this should happen within about a minute or so.
If flame comes on but goes off quickly It's likely one of the Gas valve coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The coils are purchased as a kit.
If ignitor goes off and no flame comes on the coil kit is likely needed because one coil is fully broken inside its case. If flame goes on but shuts off shortly the problem is as described above and the kit is needed.
There is a flame safety assembly on the can above the burner. If the airflow is poor. the flame tip may activate that safety and turn the flame off. Or the flame switch may be open and not allow the flame to come on at all.
The Flame switch can be tested for continuity with an ohmeter but the valves may ONLY show bad with power applied and can not be tested with a meter as they will test good.. Good Luck
Nov 18, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
Series 80 dryer not holding a flame. the flame lasts 1-2 minutes then goes out. IT IS NOT the gas coils because i just replaced them. the thermal fuse gives me a beep from my multimeter. i ordered one
Must be the control thermostat. Note: them coils only stay on a brief period of time. They do not stay on indefinitely. The duration depends on how many wet clothes are in the dryer etc. The least amount of resistance to heat the quicker they shut down. The way it works is temp is maintained between 140f and 105f by doing a series of burns for breif amount of time. The coils do not remain on for very long. If they did the clothes would burn up. You need to remove inspect and clean the filter chute. Probably clogged. The dryer must be put back together for testing with damp clothes in the drum and the door closed.
Nov 20, 2013 | Kenmore 75944 Gas Dryer
Gas lights up for about 5 minutes and then burns out. Try to turn on dryer again, but flame won't light. I let dryer sit for aout 30 minutes and turn on again - flame starts up, but will only last...
If the flame is shutting of before it reaches the operating temperatures the likely failure is a restricted venting system. There is a high limit thermostat that will cause the flame to shut off if there is a lack of airflow due to a restriction in the vent system. Remove the lint filter screen and clean in with soap and water. The filter may appear clean but it could have a clear film of fabric softener residue covering it causing a restriction in the air flow too. After cleaning the filter reinstall it before running the next test.
For testing purposes only, disconnect the dryer vent hose from the back of the dryer and put a normal load of clothes in the dryer and start the dryer. If the clothes dry in the normal amount of time that would confirm a restriction in the vent hose or the venting system. NOTE: Do not leave the vent hose disconnected after running the test. Reconnect the vent hose.
You will likely find the clothes drying in the normal amount of time indicating a restriction in the venting.
Aug 02, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
When i turn on dryer the flame comes on for about 5 seconds and then goes out and tries to light again in about 40 seconds
I assume that since you're stating that your dryer has a "flame" that it is a natural gas or propane dryer. Is this correct? If so, you might have a problem with the dryer's pressure regulating device which limits that amount of gas that is supplied to your unit. You will most likely need to have someone certified to work on your natural gas appliance if this is bad or to check the unit any further. If you don't have a true "flame" within your dryer, your dryer is heated by an "element" that is electrical. This element may be going bad if its no longer heating. If you are somewhat handy, you can replace this element but will have to find one that fits your unit. It may be difficult to find one but you may find one on-line. Good luck.
Jan 06, 2011 | Dryers
I have a roper gas dryer model rdg4440sq0, the igniter glows then the flame lights. Then the flame goes out and doesn't light up again. When it cools down and i restart the dryer the igniter glows and...
If when the flame goes out ...Check to see that the igniter glows...If it glows and the gas does not light then replace the valve coils...Very common problem.....The coils are to weak to hold the valve open..
Apr 20, 2010 | Dryers
My dryer flame lights then goes out after a little while. It does this on timed as well as amount dried cycles. Drum still turns but heat goes out. I can usually get it going by starting the dryer again....
if the dryer runs fine for the first 15 to 30 minutes then no flame you have bad gas coils located on top of the gas valve.when the coils heat up they fail when they're on there way out.just remove the two phillips screws,take off the cover and you'll see the coils,change them out watch out on the larger coil there's a metal sleeve that needs to stay on the post,if you don't see it look inside the old coil,if it's in it push it out and slide it back on the post and then slide the coil on,plug the harness back on put the cover back and reinstall the two screws,let me know how you make out,also while your in ther vac out the dryer,you should clean out the duct that the lint filter slides into and clean out the vent line,i use a leaf blower to blow out the line if it's a long run,do this once a year so you don't have a fire and the dryer will last longer,just like an oil change on your car.good luck
Mar 20, 2010 | Frigidaire FGQ332ES Gas Dryer
Maytag gas dryer ldg7314aae my flame will not stay lit. Heats up flame kicks on then goes for about 20 seconds then shuts off. The dryer runs for about 20 more seconds and then the same thing happens...
you have done a lot . try running the dryer off the vent . when the burner is short cycling it a air flow problem . if off the vent does not solve problem ck the fan for a bad center . very common problem . and clean vent . ck outside for air flow and condition of vent hood .. hop this helps ..
Dec 03, 2009 | Dryers
I have a Neptune Gas Dryer MDG300AW and the flame goes out.
Well, first of all, the flame is not supposed to be continuous... it cycles on and off during the dry cycle because it staying on would incinerate your clothing. However, there are magnetic coils that do often go bad and cause the valve to stop opening after the beginning of the cycle... so you get a flame in the beginning, but if you were to sit there for 5 minutes with the dryer running, you would find that the flame stopped lighting completely.
They are pretty easy to replace... you will have to unscrew the little plastic pieces from the inside edge of the door, and unscrew the hinges and remove the door, then pull the front panel off (pull at the top).
Of course... UNPLUG before opening any appliance.
here's a picture of what you are looking for... they are completely outside the gas line, so changing them is very simple and doesn't require any handling of the gas. they are held on with a small metal plate.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500-%3d%3dd563888i3479&PartID=3479
Jul 26, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Frigidaire FGQ332ES Gas Dryer Logo
284 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
