Question about Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television
Fuzzy Picture when souce is not HD
My Toshiba 65HDX82 works great when the source selection is HD. So, when viewing the television the picture is fine. When I select another source, for example Video 1, Video 2, etc., to play a DVD or video tape the picture is fuzzy. I have tried different DVD players, different cables, and even connected a DVD player into the front panel to eliminate the possibility that it is my receiver. I have also checked settings on the TV which all appear to be correct. I am truly puzzled and would appreciate any help you can give.
  • Jackman96 Oct 18, 2008
    I have the same problem. It just started doing this about 2 months ago.
  • Anonymous Mar 20, 2014
    I have a Toshiba 22dl704b tv/dvd combi & the dvd part of the tv has just stopped working. The colour has changed to black & white & the none of the 'play', 'fast forward', 'rewind' etc buttons work anymore. The tv part of the television still works perfectly, its just the dvd part that has stopped working, any ideas?
    Sergeant:
    Champion:
  • 301 Answers
Sounds like you may have a problem with the digital scan card or next hyper module. i suggest calling your neighborhood tv repairman
Posted on Mar 31, 2008
Toshiba 65hdx82 has a squiggly distorted side to side picture from all inputs. It gets slightly better after it is warmed up but still very bad. When you go into a menu screen that seems to be OK.
Ur convergence is the problem.U know how to solders?Tries websites.Tv repair World.com,Tvrepairkits.com for convergence kit,replaced what in the kit.
Dec 15, 2009 | Toshiba 65HDX82 65" Rear Projection...
Fuzzy picture
Tryi going threw video jacks instead of coax cable see if that works better
Jul 18, 2009 | Mitsubishi VS-5047 50" Rear Projection...
New vizio 26'' hdtv seems sharp from a distance, but pixalated and
it is important to understand the difference in digital cable and high def. high definision is on a fiber optic display alwing milions of pixels per square inch on your tv. the resolution effects your fuzzy picture you are recieving . the only real way to fix that fuzzy dull picture is to get a HD box from your cable provider and an HDMI cable to conect it to your HD TV. this is the only connection you will need for picture and top line sound. In the end the fee is usually $9.95 or less a month and it is well worth the difference in quality of TV viewing.
Mar 16, 2009 | Vizio VA26L 26 in. LCD HDTV
65 hd projection tv -no picture-red power light is flashing-help
There are many circuit failures that can cause the TV to do this. By far the most common issue is a failure of the convergence output ICs. Expect to spend $350-450 to fix this.
michtech
Feb 18, 2009 | Toshiba 65HDX82 65" Rear Projection...
Card reader replacement
I suspect that it won't play any source that uses progressive scanning. The likely problem is the hyperboard or scaler board. This component allows the TV to switch from sandard definition TV to HD. Typically, the hyperboard will cause shaking and wiggly images especialy noticeable at the top of the screen. It will generally work better the longer its on. Expect to spend $400-500 to resolve this.
michtech
Dec 09, 2008 | Toshiba 65HDX82 65" Rear Projection...
Distorted Picture
the hyper module is defective needs to be repaired or replaced.
Aug 03, 2008 | Televison & Video
Warped picture Toshiba 65HDX82
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2008 | Toshiba 65HDX82 65" Rear Projection...
Fuzzy picture
You can't make SD look like HD thats why HD came out, the best you can do is adjust the picture controls to get the optium picture
Apr 11, 2008 | Sony KP-57WS500 57" Rear Projection...
Arcing Picture tube
get a different tech from a different store to come out, needs to replace convergence ic's good luck
please mark the post with a fixya
Feb 16, 2008 | Toshiba 65HDX82 65" Rear Projection...
Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television Logo
170 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
