Question about Cal Flame 5-Burner
Gas regulator won't let gas flow
I have a Calflame bbq (ng) equipped with a gaap poppet gas regulator. Every time I use the grill I have to reset the gas regulator by unscrewing the cap and pushing the spring controlled diaphagm back down. The grill works fine for the day but I have to repeat the process the next time I use the grill. What cause the regulator to act this way?
    Guru:
  • 1,051 Answers
Turn gas tank off and disconnect connection fron tank valve. Re-connect and turn gas on. Check for leaks with soapy water solution. Tighten if needed. Some regulators will detect leaks and cut off gas.
Posted on May 14, 2010
2 Suggested Answers
gcken
  • 140 Answers
SOURCE: gas regulator won't let gas flow
Replace the regulator it is bad
Posted on Apr 04, 2010
My 12736 has a propane regulator. My old bbq had a butane one and a nearly full butane cylinder. Can I switch regulators?
Of course, you can change. Regulator to stabilize gas flow.
All gas BBQ product can suitable for both propane and butane
Jul 19, 2012 | Landmann 12376 Gas Grill
Can i get parts to convert my capn cook 4 burner bbq grill to lp
The BBQ's Galore grills are the only ones that are approved to be field converted. All you need a 4 LP Gas Burner Orifices and a Hose Regulator Assembly to hook to a LP Gas grill tank. You can buy the orifices from BBQ's Galore and the Hose/Regulator Assembly from any hardware store or home improvement center that sells grills & accessories for about $30.00. Gas grill burner orifices are pretty universal, so any LP Gas ones should work.
Hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
I have a Weber Silver B grill that I purchased 12 years ago.I would like to convert it from propane to Natural Gas. I have been told I cant! Is this true? If not, where can I get a conversion kit? Thanks!
Weber stopped selling conversion kits due to some legal action in 2008. There are no longer kits available. What you would have to do to covert it is order a replacement gas valve for the NG version of your grill just to get the orifices. Then you have to replace the LP regulator with a NG regulator. Typically most NG grills do NOT have a regulator but local building codes will require a NG regulator and a different gas line hose.
Conversion of a BBQ gas valve to NG is a matter of drilling out the orifice to a larger hole in an LP orifice.
You will not find anyone that will perform this conversion for you due to legal liabilites.
If you want to convert it... you will either have to order the whole gas control valve for NG or drill out the orifices yourself in your current gas valve hoping your got the orifice hole size correct when you drilled it. Mind you all liability for doing this lies solely with you.
This site has all weber parts:
http://www.clagrills.com/allgrillparts/weber/weber-models.htm
http://www.clagrills.com/gasgrillparts/weber/weber-gas-grill-parts-home.htm
Thanks for choosing FixYa,
Kelly
Apr 29, 2011 | Weber Genesis Silver B Grill
Can a weber kettle be run on natural gas
They can be run on natural gas however since 2009 Webber stopped selling conversion kits for their grills. (Liability issues) Anyway the regulator in most cases and all of the burner orifices need to be changed. On high end grills it is a matter of changing the regulator and adjusting the burner orifices and air flow to obtain the proper burner fire. You may be able to contact a BBQ specialty shop and they may sell you a conversion kit after you sign a liability release form. Most will insist that you bring the grill to the store for conversion AND that they install the NG regulator at the place of use. By law.... all gas conversions must be performed by a licensed technician.
Kelly
Dec 30, 2010 | Weber Grilling
Grill won't turn on
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Mar 29, 2010 | The Great Outdoors TG475N-2 (NG)
Mar 20, 2010 | Cal Flame 5-Burner
DCS BGB30 BQAR doesn't appear to be getting an natural gas flow
its most likely the ng regulator has gone bad you can get one from most grill stores if you dont know of any call bbq galore 214 696 0030
Jul 03, 2009 | DCS BGA27-BQ (NG) Grill
Converting Weber Genesis Silver B from LP to Natural Gas
Hello...I have the same grill and want to do the same conversion...From my research, you need to drill out the three orifices with a size #53 wire gauge drill bit. ( this resizes each orifice to 12000 BTU's each, which the grill is rated at 36000 BTU's).Then remove the existing hose and regulator. Replace the hose with a Quick disconnect compression fitted hose. The NG supply needs to have a pressure regulator installed, with a shutoff and quick disconnect fitting installed. Connect the hoes from the grill to the supply, and fire it up...THIS IS WHAT I INTEND ON DOING TO MY GRILL,BUT YOU DO THIS AT YOUR OWN RISK>>>
May 07, 2009 | Weber Genesis Silver B Grill
BBQ Galore Capt'n Cook 4 burner gas grill won't get hot.
Most modern gas regulators have a safety feature to prevent gas left on. If you shut off the tank first and then turn off the burners, it will trigger and keep the gas flow at a very reduce flow to prevent you from turning on the tank again with the burners left on and not realizing it. Turn everything off and then turn on tank first, followed by the burners and this will solve most problems of a low flame or a bbq that won't get hot.
Dec 05, 2008 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Cal Flame 5-Burner Logo
882 people viewed this question
Top Cal Flame Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
richie46
Are you a Cal Flame Grilling Expert? Answer questions, earn points and help others
